Question about Nordic Track NordicTrack T9.1 Treadmill Walking Belt
Increase speaker volume
My nordic track T9.1 when connected to my ipod which is on max volume, has a max volume of 16 on the treadmill display, is it possible to increase the volume?
    Top Expert:
  • Nordic Track Master
  • 12,223 Answers
You must read your owner manual. or download from
www.fitness.manualsonline.com
God bless you
Posted on Jul 29, 2013
  • 16 Answers
SOURCE: Need to put together a Nordic Track Elite 2900 treadmill.
Type into the serch, icon health and fitness, then click on the customer service, then click onto the manuals and the instructions should be in the owners manual.
Good luck.
Posted on Jun 29, 2009
SOURCE: Buttons doesn't work...
you more than likely need a new keypad
www.AtlantaFitnessRepair.com
Posted on Aug 24, 2009
Gackmaster
  • 12 Answers
SOURCE: I have a Nordic Track EXP 1000X treadmill and the
Probably 85% of the time, it's the sensor.
1. remove the screws from the bottom of the enclosure case. 2 or 3 in the front and 1 on each side
lay it back down, and power it up, and actuate your incline. watch the end of the motor, to see if the shaft is moving. It probably IS turning but only a little bit. NOT enough. In this case I'd say it is the sensor.
2. Unplug the unit of course.
3. the incline motor is in the middle of the pack,..you'll see a black tube looking thing sticking up.
4. on the bottom side of this, you will see,..or feel for a black square sensor attached to bottom of the motor casing.
5. follow the wires and unplug this.
6. pry it off with a screw driver. Remove incline assembly, if you cannot reach it.
7. replace sensor and try it again.
if the MOTOR does NOT turn when using the incline buttons, the problem backs up to possibly a bad control board. or a bad motor on your incliner, however, i'd say that's the last thing to go.
Order of failure: 1. sensor 2. control board 3. motor.
good luck
Posted on Jan 26, 2010
  • 34 Answers
SOURCE: Nordic Track Ifit Treadmill has power but walking pad not working
If everything on the display console is working correctly then we know it is either a problem with the wires from the console to the controller or the controller itself. In most cases this means you need a new controller. To verify, take off the motor hood and find the green circuit board called the motor controller. With the power on go into manual mode and push the speed up button to a slow speed. If you see an LED light with "spd ctrl" next to it flickering but the belt still does not move then we know the problem is with the controller sending the signal to the walking belt, in which you should check the wires that go to the motor. If they are connected correctly then we know a new controller is in order. If you do not see a flickering light then it means the speed signal never got there and the problem will be with the wires going from the console to the controller. This is called an upright wire harness.
Posted on Aug 18, 2010
SOURCE: our belt is slipping on our nordic track c1900
I have the same unit. First, remove the hood. Then, the motor has an adjustment screw on the belt side of the motor. Loosen the nut a little, adjust the motor up or down to make the belt as tight as you can by hand, then re-tighten the nut. This always fixes mine.
Posted on Jan 03, 2011
I need BC 887 manual
[DOC]Nordic Track Achiever Manual
188.166.107.131/nordic-track-achiever-manual.doc
... owners manual pro achiever etc ebay , nordic track achiever bc 887 manual ...nordictrack treadmill achiever reviews viewpoints , nordic track skier exercise ...
[DOC]Nordic Track Skier Manual
188.166.107.131/nordic-track-skier-manual.doc
... treadmill manual google sites , ntl nordictrack nordic track c manual sears , nordictrack ntl 1 user manual pdf download , nordic track achiever bc 887 manual ...
achiever bc 887 Treadmills Questions & Answers - Fixya
www.fixya.com > Forum > Tags > achiever bc 887
Treadmills achiever bc 887 questions and answers. Ask your ... Where is the ENTER button? please follow the instr.manual if you do not have it download it from ..
Jan 14, 2016 | Exercise & Fitness
I have a Nordic Track A2350 treadmill and the display is blank. Anyone fix this yet?
If you wish to get some details; check the site linked here. Pull up older posts Nordic. Surf the site with patience.
http://electro-medical.blogspot.com/
Jan 10, 2016 | Nordic Track Exercise & Fitness
Turn on treadmill, display lights go and than immediately go out
Arduino + U-MC 2100-WA Treadmill Motor Controller ...
? 5:16
www.youtube.com/watch?v=rAZ8FCzOuxE
May 27, 2013 - Uploaded by Grant Brown House came with a broken treadmill, but the motor/controllerwas still ... pin 13 referenced in the code is the arduino pin, not one on the board.
Sep 13, 2015 | Nordic Track Nordictrack Exp 1000...
Nordic Track T9.1 INCREASE speaker volume
reset the treadmill, and try again.
However you must read your owner manual, download from
God bless you
Jul 29, 2013 | Exercise & Fitness
How to troubleshoot Nordic Track X7i Console not turning on
In normal operation you put in the key and display should light up. Also there is a reset switch on the frame near the power chord which might be off. Below is link to the User Manual for NordicTrack x7i. I got that info on pg 16.
http://www.sportsmith.net/images/product_support%5CNordicTrack%5C248194%20-%20NORDICTRACK%20INCLN%20TRAINER%20X7I%20INTERA%20TREADMILL%5CNTL20909.3-299073.pdf
Jun 19, 2012 | Nordic Track Incline Trainer X7i...
How to activate my ifit
I will try to help you, the feature of software is the same. you can do it, activate your ifit. Nordic Track C2050 ACTIVATE IFIT -The Nordic Track C2050 is a treadmill that was targeted toward the budget-minded fitness enthusiast. It is a model of treadmill that is no longer being manufactured by the company. When it was still being manufactured, it developed a reputation for being an entry-level treadmill that featured a console that was easy to read because of its brightness. 1. Incline Change
o The Nordic Track C2050 allows users to change the incline of the treadmill with a simple touch of a button. This treadmill features both increase and decrease buttons for the incline. The incline of the machine will change by .5 percent every time the buttons are pressed. With each press on the incline buttons, the machine will take a moment to actually reach the incline setting that was just selected.
Capacity of Weight
o Users who are larger than or weigh more than the average person will be pleased with the added capacity of weight that the Nordic Track C2050 allows. Unlike most treadmills in its economy class that only allow a weight limit of 200 to 250 pounds, this model lets users who weigh as much as 300 pounds use the machine safely. Larger people can get the benefits of a cardiovascular workout on this treadmill without worrying about damaging it.
Heart Rate Measurement
o This Nordic Track model allows users to measure their heart rate. All the machine requires is for users to place their feet on its foot rails and grasp the metal contacts with their hands. The Nordic Track C2050 then works to determine your pulse, and the symbol of a heart will eventually show up in the display. After a couple of dashes show up, your heart rate will be displayed. Users who want to be certain of getting an accurate reading should ensure their hands are clean when gripping the metal contacts.
sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 22, 2011 | Nordic Track NordicTrack Treadmill, A2550
The Nordic Track machine's controls seem to be stuck. If I press any button other than "3 mph", it fails to respond and nothing happens. However, when I press the 3 mph button, it will only stay at the 3...
Remove the console from the treadmill and remove the back
remove and replace the ribbon cables that run from the keypads to the control board (they are flat plastic strips that push into the board).
remove and replace all the connections on the console
reattach the console and calibrate by doing the following:
1. With the key off press the speed + and stop buttons at the same time and hold
2. place the key on and release the buttons
3. press the stop key once
4. press the speed up til it reaches 85
5. if your max speed is 10 mph then it should read about 9.8-10.2
If the keys will not work then the console is bad and would need replaced.
Jul 22, 2010 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track treadmill trips GFI.
Have you lubricated the the running deck? The lack of lubrication can increase friction thus causing the GFI to trip. simple test start the treadmill do not walk on a see if the GFI is tripped in it does trip then lubricate, then if after lubricate it still the you have a worn belt and possibly damaged deck depending replacement price and on what you paid for the treadmill it may or may not be worth fixing.
May 20, 2010 | Nordic Track NordicTrack Treadmill, A2550
Manual
You can purchase anything you need including the manual at www.treadmillpartszone.com Your manual will cost $4.99
Jan 05, 2009 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track NordicTrack T9.1 Treadmill Walking Belt Logo
97 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
