Question about Polaroid Cameras
Polaroid special event 4
I can't seem to find a polaroid special events 4 camera and it uses 708 and it lens is a 180mm Tominon tomioka Japan 1:56 s/n f5147j can't seem to find this camera any where.
  • Melanie Mejias
    Melanie Mejias Jul 31, 2013
    The Polaroid land special events 4 is a model 20-85 non battery operated camera listed 223b and it has a marker on it that says zip low and inspected by 8115. Uses the 708 pack film and it has 180 mm tominon lens from tomioka Japan. Please help me find information and worth of the camera. It was bought many years by a store called Bradley and it has a sticker on it that says that it comes from The Polaroid Corporation 5601 Fulton Industrial Blvd. Atlanta GA 30378. Attn. Industrial Repair call 1800-343-5000. I call and is no longer in service.
  • Stephanie Luzny Sep 29, 2013
    I think I just found your camera on top of a trash an in Beaufort, SC. Matches your description exactly, and I cannot locate any other info on it, either.
I have the special events 4 Polaroid land camera and I'm willing to sell it. It you have further questions text 567-4493
Posted on Aug 13, 2013
  • 6 Answers
SOURCE: My polaroid i633 won't work!
YOur camera is looking for verification that the lens is extending. Once it sees the lens has extended when you power on, the sensors in the lens tell the Operating system that the lens is Ok.
If it does NOT see verification from the lens, it shuts down. Never force your lens back in. You may have to take the camera apart to reset the lens. you do this by removing the Zoom gear drive assembly and free you lens up by hand. 1 grain of sand or grit is like a Monkey Wrench in a Gear cog. Clear the obstruction with a can of compressed air, and work the lens with your hand. once you can that put it all back together and it should work.
Posted on Mar 15, 2008
whitetiger93
  • 141 Answers
SOURCE: PINK POLAROID CAMERA
Regional Headquarters: Polaroid Corporation
Corporate Headquarters
300 Baker Avenue
Concord, MA 01742-2131
Phone: +1 781-386-2000 Digital Cameras phone: 1-877-388-3779
Polaroid Support
Hope this helps
Posted on Mar 29, 2008
  • 11967 Answers
SOURCE: polaroid i733 digital camera lens stuck open
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 29, 2010
JackHeath
  • 1049 Answers
SOURCE: Polaroid i834 the camera beeps
There could be something obstructing the lens. Camera turns off if it can't extend and retract the lens. Turn it downward, try helping the lens in as you turn it on, try blowing compressed air around the lens itself, or if all else fails spraying around the base with a light dusting of CRT cleaner (90% isopropal alcohol spray)
Posted on Apr 30, 2010
  • 3230 Answers
SOURCE: polaroid digital camera
Well it's just because of lens errors, they are very common in these digital cameras. Usually it's sand or grit interfering with the lens extension mechanism. Follow the below steps to do a try to correct it -
1. Remove the batteries from the camera, wait a few minutes. Put a fresh (or new) set of batteries back in and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on. (We know that you camera battery's are in good condition but the newest battery help better).
2. Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
3. Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins back into their slots. If further you have the same problem it means there is a gear-motor alignment of the lens which moves in and out with the help of motor.
Thanks for using FixYa!!
Posted on Jul 07, 2010
Polaroid L9
This means there is a software conflict or that there is a circuit board shorted. In any event a new one is the least expensive way to go.
Jul 06, 2016 | Polaroid Tablets & eReaders
My polaroid dvg 1080p camcorder is great except there's no lens cap. how can I get one?
Lens caps for this model camera are not available from Polaroid, unfortunately.you could certainly fashion one from a used medicine bottle cap. Find a one that fits over the lens, paint it black, and add a string or take a lanyard from your old camera and use it! It's a cheap alternative, but an alternative nonetheless!
Apr 06, 2010 | Polaroid DVG-1080P HD Camcorder
Where can I find a (download)driver for the Polaroid t730 camera?
Polaroid does not supply drivers on their support pages...
Try this one. Version 1.0 from July 5, 2007. Nothing newer seems to be around.
http://www.downloadplex.com/Drivers/Digital-Camera/Polaroid/polaroid-digital-camera-t730-driver_176507.html
Dec 12, 2009 | Polaroid T730 Digital Camera
My polaroid camera i835dosent show images when switched on either on camera or vidieo screen is blank model no ciu00835B Thanks
If you are seeing a completely white or blank screen, the internal lens has failed. Remember, Polaroid has a 1 yr warranty from date of purchase. If you don't have the receipt, they can possibly use the serial # from the camera. Go to their website for tech support www.polaroid.com
Oct 12, 2009 | Polaroid i830 Digital Camera
Where can I buy a film pack and paper??????????????????????
Polaroid manufactured their last run of film for that camera this summer,so go on the WEB and search Polaroid 600 film (or ask a a local camera store). If you really like this camera, you might buy some extra, nut you already know about the battery, so don't buy more than you will use before the expiration date. When the film is gone, the camera will be useless, unless someone like Fuji,who makes the film for the camera in Japan, decides to keep making it.
Aug 24, 2009 | Polaroid One600 Pro Instant Camera
I have a polaroid i834 and the lens won't go in or out
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 05, 2009 | Polaroid i834 Digital Camera
Lens buzzing Polaroid T737
Your lens is stuck. You should contact the buyer and ask for a warranty or replacement. If they can't, try getting a service manual and it shold tell you how to fix it.
Jun 01, 2008 | Polaroid T737 Digital Camera
Lens stuck on i830 polaroid digital camera
Gently pull on the lens when its trying to extend, you may be able to get it back on track. This is by far the weakest point on any camera that has a retractable lens. So much that Olympus sold a lens guard/adapter for their C5050 that was basically a screw on tube that was the length of the extended lens and people bought it just to protect their extended lens.
Jan 18, 2008 | Polaroid i733LP Digital Camera
Cameras Logo
145 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
