Question about Craftsman Drills
The chuck on my Craftsman C3 drill won't stay tight
Chuck goes loose in mid drilling causing the bit to slip. Do I need to get a new chuck, drill?
    Top Expert:
  • Craftsman Master
  • 42,159 Answers
If you have a keyed chuck then yes as the jaws are not parallel any more from wear. If keyless then the thread inside the chuck cover is damaged and not tightening properly. So again yes a new chuck will be the answer.
Posted on Aug 04, 2013
  • 1019 Answers
SOURCE: chuck will not release bit
the Chuck should be 2 Part.
Use 2 pair of stillsons Or pipe wrenches, Tight On the 2 Chuck Parts, Crack in opposite Directions.
Alternative, Use Wrench On Chuck Jaw, Short sharp Blow With Hammer.
Mike @ compurepair.
Posted on Feb 28, 2008
danny_murray
  • 55 Answers
SOURCE: keyless chuck will not tighten down enough to hold bit
What size bit are you using if it is real small it may be below the min sixe require for that chuck .If it is say 1/8 or larger it may be time for a new chuck .They are easy to replace open the chuck as far as you can there is a screw inside them most of them are left hand threads just back it out and tap the chuck loose with a hammer .Make sure you know the threads of your chuck when you buy the new one most are 1/2-20 but some can be 3/8-24 tpi
Posted on Dec 05, 2008
danny_murray
  • 55 Answers
SOURCE: porter cable 884 cordless drill
Most chucks have a tolerance the cordless drills where designed for drill bits 1/8 and larger the 3/8 chucks are a little better with the smaller bits .Check your owners manual and see if they have a min requirement listed for the bit size
meleemore
  • 19 Answers
SOURCE: Makita Percussion Drill HP2051F keyless chuck release problem
jacobs come out with this all metal keyless chuck(i think thats what you have) and if thats the case, there is no solution for this youll have to replace the hole chuck, being its new, it may be under warrenty
Posted on May 05, 2009
  • 12 Answers
SOURCE: Dewalt Drill DC728. Chuck came out of drill body
If you find that the end of the screw inside the chuck is actually broke then you have a gear problem inside your drill. This is actually a very common problem. Sometimes people push too hard on their drills and the gears inside wear out and break. This prevent the motor from wearing out, but, the gears have to be replaced.
If it is the gears and not the chuck. you broke the minimium of the front gear or gears inside your drill. YOU CANNNOT repair gears. they need to be replaced. you may be able to find some off brand gears to work but, you run the risk that they are not as strong as your original ones, or may not be exactly grooved correctly.
so, if replacing your chuck does not work. find replacement gears. IF you cannot find the gears from the manufacturer see about replacing your drill.
If the chuck is still good, keep it. If you buy the same model, keep your old drill for replacement parts, ie, switch, armature, cord, etc.
hope this helps somewhat.
Posted on Jun 11, 2009
Why does my chuck keep loosening
First check whether you have the correct transmission setting for the bit you are using. This may affect the range over which the chuck operates and how it locks onto the bit. A conventional small-diameter drill bit may not work with a hammer drill setting. If the setting is correct, then either your hands aren't as strong as they used to be and you're not getting the chuck tight, or the chuck is worn and no longer has enough friction to hold.
Try this diagnostic: when you put a bit in, use a fine-tip felt marker to draw a line from the chuck collar (the part you turn to tighten or loosen) to the chuck baseplate. If the bit comes loose, check to see if the collar is still lined up at the same place relative to the baseplate. If it is, the chuck pieces are slipping inside; perhaps the transmission setting is incorrect for the bit chosen. If the collar has worked loose (the marks didn't stay lined up), the threading on the collar or the parts it engages could be worn.
May 23, 2014 | Dewalt 18v Battery Hammer Drill Dcd950...
I have just purchased a Makita 8391DWPETK 18V Cordless Combi Drill - how do i actually put a drill bit in? Do I need to take off the plastic ring?
The large black part of the chuck should turn left and right to extend (close) and retract (open) the three chuck teeth that hold the bit in place. Turn the chuck to open it far enough to get your bit fully in the chuck then turn it closed to hold the bit in. When the teeth make contact turn the chuck a bit further to get it tight enough that the bit won't slip. When you get used to it, sometimes it's easier to hold the chuck lightly and turn it by lightly squeezing the trigger to turn the chuck with the drill motor.
Feb 25, 2012 | Makita Drills
I have a Makita HP1621f Drill,and I cannot get the drill bit out,seems like the chuck itself is bad,any ideas on how to remove the drill bit?
Sometimes if you happen to have the right size bit, it will stick into the bolt that holds the chuck on if the chuck wasn't tight enought to keep it from slipping further into the chuck. Clamp drill bit in vice and tap chuck with soft hammer to pull it free.
Oct 04, 2010 | Makita & 1/2 Inch Drill
How do you remove the chuck of 18 volt cordless drill?
lock an allen key in chuck,,chuck has l/h thread so turn chuck anticlockwise to remove
Jul 07, 2010 | Craftsman 19.2V C3 DRILL/DRIVER
Keyless drill has locked in a closed position with the drill bit
I just put mine in reverse and grasp the chuck with a pair of channel locks. Pull the trigger and hold the channel locks tightly. The chuck will release the bit.
Jun 04, 2010 | Craftsman 3/8" Corded Drill
My Craftsman 19.2 drill's adjustable torque clutch want allow drilling in forward gear.
Try with the drill chuck torque setting set to max. If no joy on that one, work tha low/high speed switch several times. If no luck there, you may need to open the drill and check for a loose linkage, or that something has slipped out of place. It's not difficult.
Regards, --W/D--
Jul 17, 2009 | Craftsman 19.2V C3 DRILL/DRIVER
Locked drill chuck
i have the same tool and have had the same problem
i use 2 large prs of channel locks(water pump pliers) to break the bond
Jul 05, 2009 | Craftsman C3 19.2 volt Combo Kit,...
Keyless chuck will not tighten down enough to hold bit
Nov 18, 2008 | Black & Decker HPD18K - 2 High Performance...
Chuck loosens
Chucks ARE meant to stay tight.
You also use drill to UNSCREW THINGS.
Nov 27, 2007 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Drills Logo
270 people viewed this question
Top Craftsman Drills Experts
Gareth Cockram
Gareth Cockram
John Trevino
Are you a Craftsman Drill Expert? Answer questions, earn points and help others
