Question about Vacuums
My eureka powerline will not vaccum anything stuff is flying out of it and there is a lot of dirt in the hose how do I get it out??
  • Vacuums Master
  • 18,402 Answers
Straighten a coat hanger and pushit up the hose and hook it out or push it through
Posted on Jul 29, 2013
3 Suggested Answers
Vac Belts
  • 701 Answers
SOURCE: eureka vacuum cleaner
That means that the belt2_bing.gif is starting to wear. When the belt starts to stretch it can't turn the roller brush against the resistance of the carpet and therefore doesn't pick up well. You simply need to change the belt. Here is a link to the belt you need and to the manual:
Eureka 2961AVZ Belts
Eureka 2961AVZ Owner's Guide (3.4 KB download)
Posted on Nov 19, 2009
  • 4 Answers
SOURCE: Need manual for Eureka Powerline Plus Model 9730
I found it at www.vacpartswarehouse.com for $4.79 + sh
Posted on Dec 23, 2012
Eureka Maxima 12 amp vaccum cleaner is not picking what can be done to make it pick up?
remove and clean the filter ( tap and brush filter or use a air compressor to blow out filter ) --- also check the vacume hose near the floor attachment for any dirt and debris that may be clogging the line. this should bring your vacume to full operation.
c...
Jan 22, 2011 | Eureka 4700A Maxima Bagless Upright Vacuum
HOW DO i CHANGE THE BELT ON MY EUREKa powerline
turn the vaccum upside down and unscrew the screws in the bottom, pop that cover off and you should be able to remove the wheel assymblie. take the old belt out,slide knew one over the shaft and replace the cover and screws
Mar 25, 2010 | Eureka Powerline LiteSpeed 5845 Upright...
Eureka lightspeed dirt comes from underneath vacuum cleaner
Usually this is either a broken belt or a clog in the tube that leads up from the brush head.
Feb 28, 2010 | Eureka Powerline LiteSpeed 5845 Upright...
Need manual for Eureka Powerline Plus Model 9730 Type A - missing "door" that covers tool access port on body of upright motor...any ideas? This causes dirt to fly out unless tool hose is placed in...
Maybe you have already solved the problem this late in the game. Manuals for Eureka products can be found on http://www.eureka.com. Your local hardware store will have a bunch of different sizes of plastic caps in the plumbing section normally used for capping pvc tubing. If the outlet is round like an upright I had a few years ago you can pop one of these on and it'll do the trick. The cap shouldn't be more than a dollar or two, plus if you ever do want to use the tools again you didn't do any permanent damage to the port. Hope this helps!
Jan 26, 2010 | Eureka Powerline LiteSpeed 5845 Upright...
I have to check the belt in the ereka powerline plus. how do I do that?
Below I have listed a link that will open the owners manual that has step by step instructions on how to change the belt. Also I have listed links for the replacement belt you need. Eureka recommends replacing your belt at least every 12 months.Hope this helps you.
Eureka Powerline LiteSpeed Owner's manual
Eureka Powerline LiteSpeed Replacement Belts
Oct 29, 2009 | Eureka Powerline LiteSpeed 5845 Upright...
The vaccum doesn't pick up dirt, it sprays out
There is probably a second or third filter (besides the canister) that needs to be cleaned.
I doubt that it's rotating the wrong direction.
Apr 25, 2009 | Dirt Devil M084600 Dynamite Bagless...
Dirt does not go in the dustdup
Take off the front top filter (the clear plastic peice where it says eureka) there should be two filters inside, the bit of foam and the peice it's attached to.
I clean both parts in warm soapy water and let dry, that always fixes the problem for me.
Sep 07, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Vacuum
I just discovered that if you remove the dust cup, lay the vaccum back, reach up inside above the dust cup area, there is a yellow piece that can be removed (twist it and it comes out.) I found that there were GOBS of lint and pet hair stuck inside there. We removed all of that and the vacuum works great again!
Jul 25, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Dust is flying!!
Bad filters could be the problem. They need to be replaced, some every 3 months or so. Also a clog in the hose or the dirt inlet down by the brush roll.
Apr 14, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka powerline gold
If no suction, then you have a clog either in the hose, the dirt inlet by the brush roll, or bad filters.
Mar 23, 2008 | Vacuums
Vacuums Logo
56 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
