Question about Hardware & Accessories
Green Thumb Timer
My timer is hooked up to garden hose drip system. It is not coming on at the designated time or at all. Just installed new batteries hoping that would help. Not helping. The timer is about 5 years old. Does it need replacing?
  • 5,245 Answers
Just replace it, 5 years is a good run for battery operated outdoor device:
Copy following links to identify common brands and download manual. Green thumb appears to repackage orbit timers.
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Gene
Posted on Jul 29, 2013
protek480
  • 1714 Answers
SOURCE: Intermatic pool pump timer, time clock won't turn
Check your wiring, it sounds like it's not right. The clock needs 120 volts to run.
Posted on Jun 30, 2009
SOURCE: I'm trying to install a GE digital timer (model
the extra white wire from timer goes to the group of white wire ganged together in rear of box. you need to connect a jump wire to tha group and lead to timer. grey wire goes to black. red to red.
Posted on Jan 02, 2010
  • 243 Answers
SOURCE: Bought a Intermatic sprinkler timer. need help.
reading the specs i should say its a timer for only one zone. you can use it for one zone switching or for the pump. sorry.
Posted on Feb 14, 2010
  • 1583 Answers
SOURCE: I am replacing an in-wall timer switch that
The original timer either was a mechanical wind-up clock or it used a "power stealing" circuit to keep itself powered while it was turned on. The new timer doesn't have this feature. While the light bulb is off, it can run on a small amount of power drawn through the light bulb, but when it turns on the bulb, there is not enough voltage left to keep the switch electronics powered, so when its power supply capacitor runs out of charge, it can't keep the bulb turned on. It probably also forgets its settings.
The only (safe) way to use this model is to bring in a neutral wire. The timer should be connected as follows:
Black: connect to house black from panel (always live when breaker is on).
Red: connect to house black from light fixture.
White: connect to house neutral (white).
Green: connect to house ground (bare copper or green).
If the wires in the box come from one of the porch lights through a conduit (this seems likely; I don't think there are any other legal methods that would leave out the white wire), then it should not be too difficult to add the white wire. Tape a pull string to one end of the wires and pull them out of the conduit at the other end. Bundle a 14 gauge white wire with old wires (tape it to the pull string) and mark the black wire that goes to the light bulbs at each end so you know which one to connect to the red timer wire. Put some wire pulling lubricant on the wire bundle (it will probably pull a lot harder with the extra wire) and pull it all back into the conduit using the pull string.
Note 1: It's tempting to just push the white wire in with the others remaining in place, but it will probably jam when it runs into a place where the others twist around each other, most likely at an elbow in the conduit. That might damage the insulation of the other wires.
Note 2: 14 gauge is the typical size for a residential light circuit. Use the same size that's in there now, and be sure it is a type UL listed for residential power wiring. Look for the fine print on the original wire; you should be OK if you match that. If more than half of the conduit cross-section will be filled with wire when you add the neutral, consult a licensed electrician to be sure you won't have a problem with crowded wires overheating.
Note 3: An alternative is to use the original wires to pull in a 14-3 cable (black, red, white and ground), provided the conduit elbows have a large enough radius to let it go through. However, the jacket on this cable has considerably more friction than the insulation on wires typically run through conduits.
What happened to the original timer? Maybe we can figure out how to fix it more easily than rewiring the box. I know there is at least one two-wire electronic timer on the market, but I'll have to go over to my church and look up the brand and model. Check back after 7:30 pm CST Oct. 13, 2010.
Posted on Oct 13, 2010
Testimonial: "The white was tucked in the back of the box and painted over so I didn't see it. By connecting as you suggested it woks just super. Thanks"
SOURCE: I have an Intermatic ET70115C
ET7015C manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et70115c%20-%20english.ashx
This particular timer allows Holiday settings that override regular settings.
Do a word search of the PDF manual for 'holiday' and 'HLDY' and it takes you to the pages that talk about holiday. For example page 8 talks about the Holiday (HLDY) feature
My strategy is to replace the out-of-sync fall-back and spring-forward days with holidays ... and then the holidays can be programmed to meet the correct buzzer time.
Now let me say something. I am not an expert on this particular timer. I wire and test timers, but I do not own this timer. And the manual is a pretty good slog of information. I have not read the whole manual, but you can add a comment and I am here to assist as you go along. I answer questions for free and am glad to help.
geno_3245_40.jpgSee this image at Imgur: http://imgur.com/rAXYx
The image on Fixya is too small to see the buttons clearly, but the timer lets you program up to 99 Holidays.
Fall-back is off by 14 days, and Spring-forward is off by 14 days, for a total of 28 days.
The manual says 'review and revise data' on page 12 thru 17
Posted on Nov 10, 2010
Testimonial: "This was a great idea. Thanks so much for your help!"
Can I use a drip irrigation system for my garden's flower pots?
Yes. You can buy drip kits that consist of a timer, hose and emitter. The hoses for flower pots are the 4 mm diameter ones.
Sep 10, 2013 | Garden
How do I install a sprinkler system?
1) Copy following link for general sprinkler-system design, and for identifying brands of sprinkler timers.
http://waterheatertimer.org/pdf/Garden-watering.pdf
2) Feb 2012. Add comment and say what you are doing, and what equipment you are installing, and which timer you are going to use.
Feb 23, 2013 | Rain Bird Hardware & Accessories
I have a T10404R dual intermatic timer clock and I can only turn my pool pump on manually. The clock is working and it will turn off, but I can't get the ON pin to work despite replacing it with a new...
1) Troubleshoot walk-thru indicates that tripper is wrong, or timer mechanism is worn out:
Check that tripper is labeled ON, and compares similarly with old tripper, and is not worn down. Trippers are made of softer metal and designed to wear out before the timer mechanism wears out.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
http://waterheatertimer.org/images/WH-lever-005-500.jpg
2) Buy new timer mechanism: If the new ON tripper does not push the on-off lever, then timer mechanism is probably worn out.
Buy new T104M mechanism, and change out with existing mechanism using thumb spring located top inside box.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
3) How it works: The trippers rotate around on clock dial. Trippers come into contact with on-off lever, and trippers push lever.
On tripper pushes lever one direction. Off tripper pushes same lever other direction.
Each time the lever moves back and forth, the manual override also clicks with audible sound.
The lever moves a slide bar located on back of timer mechanism, and that action opens and closes electrical circuit.
http://waterheatertimer.org/images/Back-of-WH40-2b-500.jpg
4) Since any timer mechanism can fit into the T10404R control panel, you can also buy and install T104M210 timer mechanism with fireman's switch that turns off heater 20 minutes before turning off pool pump.
For 2-speed pool pump, the digital P1353 can also be installed, and this timer would replace both timing mechanisms in the T10404R. Non-electronic timers are more reliable.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#P1353
5) Add a comment for more help
6) Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 18, 2011 | Intermatic T10404R - Two 220 time clocks...
The right side is for the pool sweep. The timer wheel doesn't move around and keep in time with the left side which is for the pool.
If timer wheel doesn't rotate on time, then clock motor is probably bad.
Probably the wheel is getting stalled a bit when tripper comes into contact with on-off lever, because motor has lost power.
Add a bit of grease where tripper come into contact with on-off lever.
Intermatic T104 is 240Volt clock motor
Buy T100 series 240V clock motor from grainger:
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
Notice also that link above also shows extra trippers.
Trippers are designed to wear down before on-off lever, so timer mechanism lasts longer.
To install clock motor, snap mechanism out of box using thumb spring at top.
Motor is attached with 2 small star screws.
Notice that motor has plastic gears so motor is designed to stop working before rest of timer.
Motor wires attach to terminals 1 and 3, tighten screws very tight against copper wire.
Make sure no part of the wire insulation is under screw plate when tightening.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 26, 2011 | Intermatic T10404R - two 220 time clocks...
Schematic for installing garden drip watering syustem, includes timer and filter anf backflow
Good Afternoon, Frankborg9
I hope this message finds you well.
Here are the links to the manual for the hose runs and connectors
http://www.orbitonline.com/lib/media/DripMasterInstallationGuide.pdf
I do not know what timer you have, but you can get the manual by selecting that timer here:
http://www.orbitonline.com/support/guides/Manualsearch3.cfm?Brand=02&Type=Timers
Happy landscaping!
Chr
Dec 05, 2010 | Orbit Irrigation 61100 Dripmaster Layout...
Maytag pav2300 wont stop filling up. New timer
After the water fill, Switch off the mains, allow little water bleed through the hose that goes to the level switch. As the water flows try fixing into the level switch block.
Clean the water drips to dry and switch on the m/c. It should be alright since you say that the switch is OK when air is blowed!
Apr 01, 2010 | Maytag PAV2300 Top Load Washer
T101 R Clock will not turn
The "Line" is the power source. The "load" is the device that is being powered.
typically the green wire is the ground wire. I strongly urge you to verify your assumption that is is the common wire. If the green is indeed the ground, and it gets hooked up to common, you will be energizing the cabinet of the unit and posing a serious shock hazzard.
Your curcuit will be as follows.
The power source "Line" will have wires going to the timer. (hooked to the "line" terminals on the timer.)the timer then is supplying the power to the pool pump, and we will reffer to it as the "line".
The two black wires from the pump would be hooked up to the "load" side of the timer.
Typically they would be labled line 1 and line 2 or "L1" and "L2"
If yours are not labled so, describe exactly what terminals you have in detail in both the pump and the timer.
Oct 03, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Hardware & Accessories Logo
96 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
