Question about Casio EXILIM EXZ800 Digital Camera
Stuck button when I've taken a shot and want to view it, It won't pan left and more. The button feels as if it's stuck. It pans up and down and to the right OK.Can it be repaired?J.M.
    New Friend:
You have to go to the place where you bought the camera and arrange to fix it have fun
Posted on Jul 29, 2013
Testimonial: "It's put of guarantee. I've had it a few years. But thanks"
1992 Ford Thunderbird Sport 5.0 HO V8 Stock AOD transmission slipping when cold, gets better when hot.
check for a clogged cooler in your radiator. back flush it. if you had a weak pump the problem would be exactly opposite of what you are describing; as a matter of fact, the majority of transmission complaints are related to a warm trans, not a cold one. I am interested in what you find out; keep in touch. btw, your throttle to trans cable is adjusted to zero lash at idle.
Mar 07, 2013 | Cars & Trucks
Tip
My panel won't come off, I've taken out all the screws but it's...
This advice is for Kenmore Elite, Whirlpool Duet and Maytag Epic model FRONT LOADING washing machines. If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
  1. Unplug the washer while servicing inside the unit.
  2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
  3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
  4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
  5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
  6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
  7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
  8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
  9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
  10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
  11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
  12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
on Jul 26, 2011 | Washing Machines
POT AND PAN DRAWER WON'T CLOSE PROPERLY
Take out the drawer. Lift it out. Make sure nothing is in the tracks. Take everything out of the drawer. Put it back and watch the tracks. If it closes properly you've over loaded it, otherwise you have bad tracks.
Jan 23, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
I'm trying to change oil pan. I've removed all visible bolts but it is stuck. Anything I might have overlooked?
If all the bolts are really removed, then try whacking it with a rubber mallet.....not too hard.
Hope this helps
Good Luck
Aug 07, 2011 | Daewoo Nubira Cars & Trucks
MLG LS307HV. Condensation is dripping off the bottom of the indoor unit. We've mounted the unit level but the left side continues to pull up. The wall mount is level but he unit is slightly out of...
the inside unit should be mounted with a slight tilt to the outside - so the water can drain outside.
also - be sure your drain hole (in the unit) is not plugged - either with dirt/debris.
Aug 04, 2011 | LG LS307HV Air Conditioner
Remove oil pan
Find your oil pan's drain plug -- it just looks like a bolt from the outside. Use this to drain the oil from your vehicle first (keeps you from getting covered in oil later). Once the oil has drained out (usually it will still be dripping, but that's OK) put the plug back in so you won't get dripped on. Then find all of the bolts around the pan that you just drained -- there should be several around the top of the oil pan connecting it to the engine. Once you have removed all of these bolts, the oil pan should come off relatively easily -- most times it gets a little stuck to the oil pan seal, so you might have to pull on it a little, or if it's really stuck, you might have to pry it off (be careful not to damage the oil pan when doing this). If you notice that the oil pan is REALLY stuck on there, make sure you got ALL of the bolts (if you miss one the pan will not move).
Once the oil pan is off the car, and you have done what you need to do, clean the surfaces where the oil pan will connect back to the car -- making certain that the old gasket has been totally removed (leaving debris from the old oil pan seal will keep the new seal from functioning correctly. When you go to put the pan back on the car, make sure you have the oil pan seal set perfectly where it is supposed to go, then hand tighten the bolts back where they should be. Don't tighten all of the bolts down quite yet.
Check to make sure that the oil pan seal has not moved out of place, then tighten one bolt, but not ALL the way tight yet. Once you have one bold mostly tightened with your wrench, start tightening the bolt on the opposite side of the pan from the first one you just tightened -- and make this one about as tight as the first one. Next, double check that the seal has not moved, and then tighten a bolt on a 90 degree angle from your first two. Next, do the bolt opposite the third. Work on one bolt at a time, making sure that you don't tighten two bolts next to each other in a row. This will help you make sure you do not move or distort your oil pan seal as you are replacing the oil pan. I don't know the exact number of bolts, but if you follow the pattern from the diagram below as much as you can, you should not have too many problems. Once all of the bolts have been wrench tightened in this order (or similar depending on how many bolts there are, and their placement) go around the pan one more time, making sure that all of the bolts are nice and snug and you should be just about done -- don't forget to put more oil in the car before you turn it on :-)
Bolt Tightening to keep pan seal from slipping out of place:
1 ----- 9 ----- 6 -----4 ' ' 7 8 ' ' 3 ----- 5 ---- 10 --- 2
May 28, 2011 | 2003 Chevrolet Impala
Model TR810 - pan jumps around during kneading cycle (1.5lb setting). Won't stay engaged in lugs. All the parts look normal; nothing bent, corroded or twisted, etc.
Bread pan pops out
reach in with your fingers and bend the two little clips out a little until they grip your pan snugly. Start with 1/4 " and try that. If it doesn't feel snug go another 1/4 inch.... and so on....
May 10, 2011 | Kitchen Appliances - Others
Once u zoom into the picture that is very far away how do u keep the picture zoomed in after u snap the shot ...
Once you've framed your shot (zoomed in) and taken the picture. That's it, the picture you've taken is the one in your view finder, and that's the way its kept.
However, if you want to zoom in further, you can using the software you were provided with your camera, you can, you can also zoom in using your camera menu. Once happy you can then save the edited picture. But this time its a digital zoom and it will reduce the resolution. The picture won't look quite as fine. It will be a balance between picture quality and the extent you want to zoom in.
Apr 19, 2011 | Olympus PEN EPL1 Body only Digital Camera
I have a panasonic lumix DMC FZ 45 and I cannot figure out how to take panoramic pictures. When I take pictures of the room or view it just keeps saying next, retake and exit. Can you help please?
Hi. In Scene>panorama assist, a grid is shown on screen and things get confusing!
1. The initial choice needs to be made between
left >right (for a sequence of shots made while 'panning' towards the right)
right >left.
down >up.
up >down.
e.g. if 'left >right' is selected:-
2. After the first shot has been taken, a preview is displayed without the grid.
- the 1st shot can be cancelled with 'retake', or saved for the sequence with 'next'.
3. If 'next' was selected a 'ghost', of what was in the right hand panel of the 1st image, will be shown on the left as an overlay in the LCD display, together with the grid.
The camera can now be panned to the right to try to align the ghost of the right part of the 1st shot with the left side of the new view. The 2nd shot can now be taken,
The combined image is shown, without the grid, which may or may not show good alignment of the 1st and 2nd images - so you can choose to 'retake' the 2nd image, or choose 'next' again.
If you choose 'next', it's back to no.3, above
....and so on until you choose exit, when the sequence can be transfered to PC for stitching with an image editing program.
Hope that helps!
Dec 28, 2010 | Panasonic Cameras
Casio EXILIM EXZ800 Digital Camera Logo
21 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
