Question about Technics SA-DA8 Receiver
Overload sound clicks off
When the compressor tries to come on, why does it click and hum, then clicks off?
Two causes for that situation. The compressor has a start relay and a overload mounted on the 3 prongs. When the relay/overload is bad, compressor will kick on, hum, then a click sound. The click is the overload. Or, the compressor is drawing too much power and the compressor is bad. 90% of time it's the relay/overload but you need to check and make sure fan is running by compressor and coils underneath are not clogged up. Poor air flow around compressor can cause overload to go bad.
Aug 19, 2015 | Refrigerators
Not cooling clicking sound refrig compresso and
IT'S MOST LIKELY THE START RELAY/OVERLOAD PROTECTOR ON THE SIDE OF THE COMPRESSOR. UNPLUG UNIT AND PULL START RELAY OFF AND SHAKE. IF SOUNDS LIKE IT'S FULL OF GRAVEL IT'S BAD, OR GET VOLT /OHM METER AND CHECK CONTINUITY BETWEEN THE START AND RUN TERMINALS ON BACK SIDE OF RELAY, WHILE YOUR THERE CHECK CONTINUITY BETWEEN THE BACK SIDE OF OVERLOAD AND WHERE L1 WIRE COMES IN FROM THE HARNESS. IF ALL THAT CHECKS OUT THE COMPRESSOR MIGHT BE BAD OR DRAWING TOO MUCH CURRNET FOR THE FACTORY START DEVICE. YOU DIDN'T NOTE A SERIAL #, SOME OF THOSE MODELS WERE UNDER RECALL FOR THE RELAY/OVERLOAD PROBLEM.
Oct 06, 2010 | Maytag MSD2756G Side by Side Refrigerator
Freezer get start but shut off after couple of seconds
This sounds like the compressor tripping on overload.It will make a "click" sound.This is the sound of the clixon (overload protection) on the compressor.Only way to solve this problem is to replace the compressor.
Regards
Andre Nagel
Mar 22, 2010 | Danby 3.6 cu. ft. / 102 liter Chest...
Plug it in, a click is heard but no compressor coming on, doesn't freeze
The click sound that you hear is from the clixon (overload protection) on the compressor.This means that the compressor is tripping on overload.
Regards
Andre Nagel
Mar 22, 2010 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Clicking
your RTX overload on the compressor body is going out and needs replacement
Dec 10, 2009 | GE GSH22SGRSS Side by Side Refrigerator
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
Unit is 5 years old. came home and could smell a faint oder. there was a loud click sound then 30 seconds a softer click sound...3 minutes later it did it over until i unplugged it. the freezer area has...
could be overload and relay,if clicking is coming from compressor area could be start device {overload and relay} if not that ge has been having problems with main board,i'd check the start device first because the main board is expensive
Nov 06, 2009 | GE GTS18HCM Top Freezer Refrigerator
Clicking from underneath
you need a new relay and overload on the com pressor
goto www3.sears.com type in your model number
look for compressor or controls
on the compressor itself you will see the overload box
you might need both the relay and overload id replace both anyway
Oct 08, 2009 | KitchenAid KSRG25FKSS Side by Side...
Our office refrigerator is clicking... and now its beeping on the inside as though the door has been left open.
The clicking sound is the compressor overload. When cycling on overload the compressor is under stress from several different reasons not all at the same time but for several different. Solving the problem may take simple repairs to start relay, start capacitor, overload, cleaning of the condenser coils, checking the condenser and evaporator fans. The beeping sound is possibly coming from the temperature board inside. When the clicking begins with a compressor overload is the time that it needs to be looked at to prevent further damage. Sometimes the compressor is worn out and nothing you really can do when worn out. If you would like my assistance I will be here or the links below to help or answer your questions. Please provide your model number and I will be glad to help out, Thanks, Sea Breeze
Sep 21, 2009 | GE Refrigerators
I hear buzzing sound and a click like a switch when the compressure turns on.
Then you will need to get that fixed. Sounds to me that your start relay and start capacitor are not making good start connection and the overload is clicking out. If you don't fix this problem soon the compressor may be damaged. I need to know if your model is the MSD2756G or a different model. Let me know..Sea Breeze
Jun 21, 2009 | Maytag MSD2756G Side by Side Refrigerator
Technics SA-DA8 Receiver Logo
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
