Question about Dometic RGE400 Top Freezer Refrigerator
Power problems Where is the fuse for this model because the display is off and won't run the motor.
    Top Expert:
  • Dometic Master
  • 8,688 Answers
Display is 12 volts 120 volts heater element
Posted on Oct 03, 2017
2004 Buick LaSaber w/Automatic Temp control, blower motor just quit, won't run at any speed, all fuses are OK. I'm thinking bad motor?
With Auto Temp---you first need to use professional
scanner, to look at Body Module Data & continue from
there,it helps to have factory trouble charts to use &
not guess, as I'm afraid some shops still do
Mar 13, 2013 | Cars & Trucks
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
I have a Bosch SHU9955US/14 (Integra) dishwasher. There is currently a 0 with and asterisk showing on the display and the unit will not run.
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 29, 2012 | Bosch Dishwashers
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
Sep 28, 2012 | Dishwashers
When you push start button nothing happens
Sep 28, 2012 | Washing Machines
1994 evinrude boat motor keeps blowing fuse. motor keeps running but once shut off won't restart. also while motor is running the tilt won't work work
I'm sorry but you have this posted in the wrong product category. Please re-post the question in the proper category This is the car and truck problem category
Jun 27, 2012 | Cars & Trucks
Where are the blower motor fuses
I looked in a book on this, as I didn't actually go out and look into the fuse box, but it is a numbered fuse box, so it should be rather easy t locate. Look for fuse 23, it is a 30 AMP fuse that runs off the Blower motor resistot block. Als it shows Fuse 17, a 10 AMP fuse that must control the Manual temperature control head. Either way, look at them both. If nothing is amiss there, look to the Blower Motor Resistor. It is below the glove box inside the car. Remove the right lower ari duct to get at it. If the fuses are okay, check the connector for power. If you have power, then perhaps the resistor that pokes into the housing is faulty. If you take it out, you may see that it is burned out on one or more of the little coils inside. They're not too expensive to replace.
I haven't done this on this model, but if this is a temperature controlled module, there might not be a resistor in there- I'm not certain on the 300M, but it is worth a look. Advance says so- about 32 to 164 bucks for it. I'd imagine the 164 dollar version is for the automatic climate controller- It sure looks fancy... but you won't know exactly until it is out- and if it's not working right now, it is definitely worth the look. The old-fashioned version should look like it is burnt out, but I imagine the electronic fancy-shmancy one won't. It may have to be electronically tested for resistance.The book I have does not outline that.
Anyway, it should not be a huge job to investigate. but if you have power to the resistor, the issue could well be in there. Another note, however: Unplug the blower motor from its' harness as long as you are down there, and carefully run a 12 volt source to it. Make sure you ground the other end of your connection to the motor. so you have two wires, a + and a -. If the motor runs, then it is the resistor. if it does not run, then it is likely the motor. Double check everything before you go buying parts, and never "Just" replace parts without proper testing. You could spend alot of money and get nowhere fast. Let us know how this works for you, but be methodical. Fuses first. Then the power to the blower and the resistor, then the motor. Good luck!!
Dec 16, 2011 | Chrysler Town & Country Cars & Trucks
Blower stays on when car is turned off won't stop running until I disconnect the battery cable, tried the blower fuse that didn't work. 1995 olds auroa
If you pulled the 10 amp fuse in the I/P fuse block and the blower still worked than the the blower motor module is most likely the problem. It is fed by a 30 amp fus4e in the fuse block under the rear seat. That fuse is always hot and always supply power to the blower motor module. If you pull that fuse and the blower stops than it's pretty likely the blower module is the problem.
The blower module is located near the blower motor. It is usually held in place with 2 screws and will have four or five wires at the connector.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
May 10, 2011 | Oldsmobile Aurora Cars & Trucks
Refrigerators Logo
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
