hii.first of all check door is closed properly .see inside of door there is a small plastic lever which press door switch.may be this lever is broken .otherwise switch is not working properly .check it and replace this.
do not forget torate the solution
MIAN AKHLAQ
Was this helpful?
Yes
No
Popular Solutions for Sharp AR-235 Grayscale Copier
Hi, every one My proplem in my Riso 3750 it is not work in speeds 3,4,5 he work only in speeds 1,2...
(More)
Hi, every one My proplem in my Riso 3750 it is not work in speeds 3,4,5 he work only in speeds 1,2 when I' use paper size A4R, A4 . But when I' use paper size A3 he work normal in all speeds
I have a Sharp ARM550N.This one has a paper tray error F3-12. Tray 1(paper tray desk trouble). I...
(More)
I have a Sharp ARM550N.This one has a paper tray error F3-12. Tray 1(paper tray desk trouble). I took the cover off of the front of tray 1 so I could watch the elevator. The one on the right side works fine, but the left one does not move up. I switched out the drive motor and gears from the right side to the left. It did not help. I then switched the small board that has the two sensors on it and that did not help. I took the gearbox apart and watched the worm gear and it would not even try to turn when I blocked the sensors. The right side did turn.Someone please help. I have spent 3 hours on this one.
got envelope jammed in my 926 photo copier. lost manuel and don't know how ,to get it out!!! What do...
(More)
got envelope jammed in my 926 photo copier. lost manuel and don't know how ,to get it out!!! What do I do??
I have a canon mp190 printer.It starts to say printer is offline and check power even though the...
(More)
I have a canon mp190 printer.It starts to say printer is offline and check power even though the power is gone
