Question about Cell Phones
GLbox HD60 software upgrade
How to update or upgrade software for GLbox HD60 box please?
Do you know where I can find the firmware update (1.18) for a Bauhn 1Tb PVR?
http://tempoaustralia.com/sw/as-pvr1000r/AS-PVR1000R_IM.pdf
DG-DABVPR1TB
down load and put on a usb drive,
DGTEC firmware 2011 updates available
New updates available for service issues such as freezing and start up/ recording issues (firmware 2011) are also available from the DGTEC website.
Please update software first before replacing hardware...
From DGTEC Website Software Upgrades page: -
Click on the relevant link below to download the latest software update for your DGTEC product. For further help and assistance, please access the DGTEC Call Centre via the Support page.
Obsolete Products
* DG-FV500PVR Upgrade (zip file 4.3Mb)
* DG-HD6760 Upgrade (rar file 2.3Mb) Upgrade instructions DG-HD6760 (25Kb)
New Products
DG-HDMP1080
DG-HDMP1080P
DG-HDMP1080TT
DG-HDMP500TT
DG-DABVPR1TB
DG-DABPVR500GB
DG-HD2104AND
Models
DG-FV500PVR - 500GB HD PVR WITH TWIN TUNER (FREEVIEW)
DG-HD6760 - HD SET TOP BOX WITH USB RECORDING
DG-HDMP1080 - HD MEDIA PLAYER
DG-HDMP1080P - WIRELESS HD MULTI MEDIA PLAYER / STB
DG-HDMP1080TT - HD MEDIA PLAYER WITH TWIN TUNER
DG-HDMP500TT - (NEW MODEL RELEASE)
DG-DABVPR1TB - 1TB HD PVR WITH TWIN TUNER WITH INTEGRAT
DG-DABPVR500GB / DG-DAB+500PVR- 500GB HD PVR / TWIN TUNER WITH INTEGRATED
TV-6600 BAUHN UNIT- 500GB HD TWIN TUNER PVR
GG-HD1200PVR- BAUHN UNIT WITH TWIN TUNER
Note: - Master Override Password 1973
Instructions:
Read instructions carefully before commencing. Software needs to be carried out while the PVR is cold. Go to "Telefix" website and select "Service Guide" or "Download Service Manuals" and download software to a location on the PC Hard Drive.
Unzip file and copy "usb.upg" software onto a blank USB Memory Stick.
Plug USB Stick to USB port of PVR
Connect Power to PVR and switch on so that that the booting process commences.
Press 'Menu' button and scroll left or right by using the arrow buttons to find 'Installation' then press OK to select.
Note: PVR may freeze and not allow selection. Several attempts will be required to enable selection. If problem persists, switch OFF PVR to allow it to cool down then try again or use the alternative method.
Alternative Method
1a. Disconnect mains power.
2a. Plug USB Memory Stick to USB port.
3a. Press and hold the CH down arrow button on the unit and then connect mains power.
4a. When the display starts counting down release channel button and the upgrade interface will appear on screen.
7. Scroll down to 'USB Menu' by using the arrow down button then press 'OK' to select.
8. Scroll down to 'USB Upgrade' by using the arrow down button then press 'OK' to commence software update.
· Note: - Please do not shutdown PVR or remove USB Stick during the update process. When the update is complete the PVR will power down and reboot again as normal.
Once the update has completed, reset the PVR by restoring back to Factory Default.
Press Menu ? Installation ? Factory Default ? enter password 0 0 0 0 ? Select 'Yes' ? press OK to rescan channels.
Check Software Version, Press Menu ? Installation ? Version Info ? OK
download and put on usb drive
Software Updates
Apr 11, 2015 | Televison & Video
How to install software in LG GW525
  1. 1. Before installing the USB Driver, disconnect phone from PC
  2. 2. Please back up all files (through PC Suite etc) before upgrading the phone. LG Electronics will not be held responsible for loss of any data.
  3. 3. Please connect your USB cable directly to the PC (Do not use a USB Hub).
  4. 4. if the phone software upgrade stops before completion, please do not close the update tool and try to update again. If you close the update tool before completion Recovery Phone
    http://www.repair-dll.com/
Dec 07, 2011 | LG GW525 Cell Phone
50HPX95. Need Firmware\r\nHad a failed video board (PD2222C). I purchased and replaced this board with same revision, but tv thinks it is a 42" versus 50". Does anyone have the firmware to...
Notice (Read Prior to Beginning the Software Upgrade)
The following events may interrupt the upgrade process and result in an inoperative unit.
1) DO NOT unplug the Power Cord during the software update procedure
2) Avoid loss or interruption of power during the software update procedure
3) DO NOT Press the power button on the unit during the software update procedure
In the event of software upgrade failure please contact TOSHIBA Customer Service at 1-800-631-3811
Feb 11, 2011 | Toshiba 50HPX95 50 in. Plasma HDTV
Hi please tell me how to unlock nokia 6500 slide
you can try to check if theres any updated software/firmware for your 6500. you can check that from this website:
http://europe.nokia.com/support/download-software/device-software-update/can-i-update
then enter the code which is located at the back of your phone.
you can check the your current firmware by typing *#0000# from the standby screen
NOTE: PLEASE MAKE SURE TO BACK UP EVERYTHING BEFORE UPGRADING YOUR SOFTWARE/FIRMWARE
if it shows that theres a latest software version than the current version of your phone then upgrade your software using Nokia PC Suite. then it will reset your security code and settings.
Aug 22, 2010 | Nokia 6500 Slide Cellular Phone
I have tried downloading from the samsung website lastest firmware update, which is an iso file when extracted it saves it to disc as a xuf file and the blu ray wont read this what am i doing wrong??
Read the Upgrade Guide (PDF) for instructions on how to do this. It says to burn a CD. The ZIP file extracts to ISO type. The guide tells you what format it needs.
http://www.samsung.com/us/support/search/supportSearchModelResult.do?menu=SP00&searchWord=bdp1400&searchInputBox=bd-p1400&find_button=
READ the PDF file under Upgrade Guide. Make sure you designate the proper file type when burning CD. Check your burning software.
How to make a firmware update CD
Please follow the below procedures.
1 Download the new firmware file from www.samsung.com
2 If the firmware file is compressed (*.zip), the file should be uncompressed to CD image file
(*.iso).
3 Please burn the CD image file on a blank CD-R/RW disc
1) Recommended CD Burning Program is Nero Burning ROM.
2) Burning Options (in case of using Nero Burning ROM)
A. ‘Recorder’ menu ?? ‘Burn Image…’ ?? Select an uncompressed image file(*.iso)
B. Please check ‘Finalize CD (No further writhing possible!)’
C. Please refer to your own CD burning Program Manual if you want to use any other
CD burning program for burning ISO image file.
D. Make sure if the downloaded software is eligible for your BD-P1400.
E. The System Upgrade will not be executed if using the update CD made with NOT
following the upper procedures.
Warning
The following events may interrupt the upgrade process and MAY RESULT IN PERMANENT
DAMAGE TO THE UNIT WHILE UPGRADING.
1. Unplugging the power plug
2. Power outage
3. Dirt or scratches on the burned CD-R/RW disc
4. Closing or opening a disc tray during update processing
How to upgrade the BD-P1400
1. Press OPEN/CLOSE button to open the disc tray.
2. Insert the upgrade CD.
3. Press OPEN/CLOSE button to close the disc tray.
4. Please wait about 6 minutes while verifying.
Verifying Firmware Version.
5. When below message box comes up, please check the date of the Firmware version.
Do you want to update Firmware?
>Current Version : 070730.02_XAA
>New Version : 070903.01_XAA
Yes No
6. Press ‘Enter’ button to choose ‘Yes’ for upgrade and please remove the disc on the tray.
If you select ‘No’, BD-P1400 will be automatically powered off.
If you don’t see above message box, try another disc. Generally, this is caused by disc
quality or a disc creation problem.
7. Please wait for about 7 minutes.
Firmware Update.
Now, Processing…
Please, do not turn off the power.
8. When finished, the screen and the power will turn off automatically.
9. Turn on the unit again. The tray will close automatically. Below screen will show up. Please
select the language you want with a corresponding number button.
MENU LANGUAGE SELECTION
Press 1 for English
Pulsar 2 para Español
Touche 3 pour Français
Macrovision : BSS01
10. If you want to do System Upgrade through the network, please refer to ‘System Upgrade’
Article on the User’s Manual.
Aug 18, 2010 | Samsung BD-P1400 Blu-Ray Player
How to upgrade the firmware of MT6225 Nokia N97?
Hi. To upgrade your phone to the latest firmware, please follow instruction from Nokia's website.
How to update:
http://europe.nokia.com/support/download-software/device-software-update/how-to
Download device driver updater:
Good luck. Thanks for using FixYa.
Aug 17, 2010 | Cell Phones
Subscription renewal and upgrade
reboot and restart a few times and then check for updates
Oct 04, 2007 | Symantec Norton AntiVirus 2004 - (Open...
Installation and Usage Tips for the DiMAGE 7 Optional Enhancement Upgrade:
Taken from the DiMAGE 7 Upgrade Software Installation Pamphlet… Power Supply during Update: When performing the software update, please use a set of fully charged NI-MH (nickel hydrogen) batteries or the AC Adapter AC-1L or AC-2L (sold separately). When using the AC Adapter, be sure not to inadvertently disconnect the camera during the software updating procedure, otherwise the camera may be permanently damaged. Amendment to the DiMAGE 7 Upgrade Software manual… (Located on an insertion card within Upgrade Kit and Upgrade Firmware boxes) For Windows XP users: Do not copy the dsc.app and ram.bin files directly from the CD-ROM to the CF card or the upgrade will not be executed correctly. First copy these two files onto the computer’s hard drive or desktop, and then copy them into the CF card. After upgrading: When the camera is turned to the playback mode, the no-image message appears and the images taken before the upgrade are not displayed. These images were placed in a folder with names ending in MLT03, the upgraded camera places images in folders ending in MLT14, see CompactFlash card folder organization in the DiMAGE 7 manual. To view images taken before the upgrade, select the appropriate folder in the custom 1 section of the setup menu. Refer to DiMAGE 7 manual for a description of this function. When using autofocus with the wide focus frame, the live image may freeze for an instant as the AF system determines the focus. This is because autofocus speed is increased
Sep 15, 2005 | Konica Minolta DiMAGE 7 Digital Camera
Cell Phones Logo
185 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
