Question about Coffee Makers & Espresso Machines
La marzocco linea 2av
Our hot water sprayer that we use to clean utensils is not working at all. The heads and everything else about the espresso machine is aok. Any thoughts? Thanks! zingcafe@yahoo.com
SOURCE: Unable to programme La Marzocco
FYI - the flowmeters can get fried after lots of usage. Back in the day Starbucks used to put pieces of cardboard between the flowmeter and group head to prevent them from heating up. Aside from checking for scale you use test with an ohm reader. I think a functional one will reach 2.4ohm (or maybe 2.8). A broken one will post junk ohm information and bounce around. Replacing them is expensive so I'd just recommend usitng the semi-auto on/off switches. This info comes out of the big oragne Linea maintenance book.
Posted on Feb 21, 2009
z34aga
  • 137 Answers
SOURCE: Buzzing Espresso Machine
that noice is from your solenoid valve during brewing coffe.
  1. as first you should clean the group with blind filter and special detergent for washing coffe from group. if you didnt do this long time you should repeat the cleaning 3 - 5 times same day.
  2. if you follow the 1st instruction but you have the problem again you should change your solenoid valve.
Posted on Apr 01, 2009
EsWorld
  • 1618 Answers
SOURCE: La Marzocco espresso machine troubleshooting
Where is the steam coming from the small valve on the top or the big tall one? If it is the tall one then the problem is in the block electrical box(pressure stat) on the left above the element, that may be stuck and not telling the machine that it has enough pressure turn off the elements.
Posted on Jun 20, 2009
EsWorld
  • 1618 Answers
SOURCE: Problems programming La Marzocco Linea espresso
Check to see if the program switch is turned off. There might be a switch in the inside of the machine, or on the front panel and you need the key for you have to go through the cpu board.
Posted on Aug 06, 2009
EsWorld
  • 1618 Answers
SOURCE: i need an operators manual
You can dowload one from LaMarzoccousa.com.
Posted on Jan 25, 2010
La Marzocco Linea 3AV...water is coming out of group heads but is not hot. The boiler for the steam is hot. Help?
Your front brew boiler likely has a dead heating element or there is a problem with the electrical system for the front boiler.
Aug 03, 2011 | La Marzocco FB-80 Series 3 Groups Coffee...
How do I increase grouphead pressure on la marzocco linea 2 group?
To increase dispense pressure you turn the adjustment screw at the pump. When pulling a shot (use espresso) on one group the bottom needle of the gauge should read 9bars while pulling the shot.
Dec 16, 2010 | La Marzocco Linea Series Group 3 Espresso...
Leaking pump head at adjustment for pressure - worn rubber seal or snapped pin. Where to get a new pin?!
Unless you have an old pump you can take the pin from you will have to get a new pump, as for the o-ring since there is no hot water there a small o-ring can be found at the hardware shop or a home espresso machine dealer/repair agent.
Sep 19, 2010 | La Marzocco Linea Group 1 Espresso Machine
La Marzocco GB 5, 2 group head boiler not starting. It says coffee boiler 1 30.8 C. Please help
New machine? check the thermal reset on top of the left group head. Press the red button and see what happens.....
Aug 17, 2010 | La Marzocco Linea Series Group 3 Espresso...
Trouble shooting guide
You can dowload one from LaMarzoccoUsa.com
Apr 24, 2009 | La Marzocco Linea Series Group 3 Espresso...
I need an operators manual
Dec 26, 2008 | La Marzocco Linea Series Group 3 Espresso...
Mar 18, 2008 | La Marzocco Linea Series Group 3 Espresso...
hello
you need to check your flor meters. they could be scaled or dirty. you need to dismantle flowmeter that is on the side that is not working and clean it. make sure the water main is off and power is shut off. hope this helps.
Feb 29, 2008 | La Marzocco Linea Series Group 3 Espresso...
Coffee Makers & Espresso Machines Logo
35 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
