Digidoor remote Hi, I have a digidoor 2 garage door, the garage door does not open and close with remote while standing outside the garage, but while standing inside it works fine.3 remotes and changed the remote batteries also, no change. Any help will be appreciated. Thnx Pieter
Hi not sure if you have fixed this but I had the exact same problem and I managed to fix it. What i Did was Switch off the motor, remove light cover, Remove the Pc board. on the pc board there is a black wire this is the antenna wire. I removed this wire from the PC board and soldered a New longer lenght of copper wire to the board. put the PC board back and the light cover switch motor back on. My remotes now open and close the doors while I am Still sitting inside my Car :)
Posted on Sep 20, 2013
  • 59 Answers
"Another reason is problems with the radio frequency of the remote control system used, some older systems use frequencies that are liable to interference from various sources such as police and fire department radios and military communications. The effects of this interference are many for example, the garage door may open and close on its own or the operating range of your remote control may become so poor you cannot open or close the door with your remote control even whilst standing next to it."
source
Posted on Aug 14, 2013
2 Suggested Answers
  • 9 Answers
SOURCE: how do i programme a
How to program a digi-key remote control :
- on the wall console press the light toggle button to switch the light off.
- press and hold the light toggle button, the light will come on and after 5 seconds go off.
- release the button and the light will go on again.
- within 30 seconds press the required key on the digi-e key transmitter (your remote control). The light on the digidoor ac/dc will go off.
- to confirm press again the same button the transmitter (remote), the light on the digidoor ac/dc will flash foor times. Done
Posted on May 08, 2012
The klik3 works inside the garage but not outside the garage
make sure antenna wire is hanging loose and that the remote batteries are new
Aug 18, 2015 | Building Materials
How do I get a free service manual for digidoor 24 garage door opener
Your first problem is you bought a digidoor garage door opener. But check their website, or call the manufacture. You will either be able to download the manual or have to buy a one directly.
Mar 28, 2015 | Building Materials
How to re programme my Digidoor III garage door motor?
Did you check it engages the end switches?
Oct 07, 2014 | Building Materials
I bought a second hand Digidoor 1 with garage door. The door opens and closes perfectly when the digidoor is off. When I power up the digidoor the motor will not open the garage door when the door is...
You are receiving interference from the digi door. You will have to return this unit and go with a different one on a different frequency. Chamberlain makes a clicker that would work well with that unit. Thanks BB
Sep 21, 2010 | liftmaster Chamberlain Garage Door Opener...
I have a digidoor 2 automatic garage door and it closes in stages not in one motion. The problem started when I stopped the closing motion half way down by remote control to let someone in. Up until then...
It sounds like your obstacle setting might be set too low and the friction of the door is causing the motor to stop. There are two white alan key adjustments on the side of the motor that can be adjusted to change these settings for the up and down sensitivity. If this does not solve your problem contact the Digidoor technical helpline on 2711 4749060, they will be able to assist you.
Aug 24, 2010 | Kitchen Ranges
My Craftsman remote won't close my garage door
If the remote opens and closes while inside the garage but not outside , there are a few things it could be. Assuming it was working fine before..
1. weak battery in remote.
2. remote itself could be bad. (unless you have more than 1 remote acting the same)
3. Logic board in opener is going bad causing limited range.Is the wire that hangs down from the opener straightened out? That is your remote antenna.Some people have coiled or even cut it off..reducing range.
4. Less likely but this can happen- interference from another electronic device, wireless routers, cell phone, new appliances etc.. can reduce remote range. Any new electronics recently purchased?
Jan 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door won't open.
The most common cause of this problem is the door sensors have been bumped and misaligned. They each have a small light that should be lit and not flickering. Tweak them until they are pointed at one another and the lights are lit.
Jun 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door trouble
This is a link on how to program your remote. Have to have make and model number ready.http://www.garagedooropeners.us/helpgifs/maincode.html
Hope this is a Fix Ya.........
Nov 17, 2008 | Sears Craftsman LiftMaster Chamberlain...
520 people viewed this question
 Grubhead
Grubhead
