Question about Car Audio & Video
Lanzar subwoofer wiring diagrams
Don't know how to wire it on the back of the subwoofer
Your solution must be between 3 and 10,000 characters long
Posted on Jul 30, 2013
trintek
  • 111 Answers
SOURCE: subwoofer wiring diagram
parallel wiring. hook all 4 positives together and run to the positive output from the amp, hook all 4 negatives together and run to the negative output from the amp.
hope this helps,
trin
Posted on Nov 19, 2007
sticky92505
  • 77 Answers
SOURCE: Wiring diagram for Pioneer TS-W3004SPL subwoofers
a good resource for wiring and information on the web can be found at 12volt.com
Posted on Feb 18, 2009
etirbynnor
  • 655 Answers
SOURCE: dont know how to wire a subwoofer
The Jensen XS1010 is a 4-ohm sub and should work properly off of the outputs of most any single channel monoblock sub amp or off a bridged 2-channel. You did not say what brand or type of amp you intend to use, but in any case, there's only 2 wires to connect to the sub, one positive (+) , the other negative (-). Simply match them up with the positive and negative on the amp speaker output and you are ready to bump.
Here's the link to Jensen's website:
http://mobile.jensen.com/jensen/
I'd recommend downloading the XS1010 manual. They recommend an enclosure with at least .75 CuFt internal volume.
If this helps, please rate it as "FixYa". Thanks!
Posted on Mar 28, 2009
  • 3 Answers
SOURCE: I have a set of Audiobahn 15
crutch feild has a great wiring diagram section. www.crutchfield.com
Posted on Oct 14, 2009
smarthome2
  • 1114 Answers
SOURCE: i have a JL audio
Your amp is stable bridged mono at 2ohms, however, having dual 2ohm voice coils will drop the amp to 1ohm if parallel and will kill it. The cleanest possible way to run this amp and keep it cool with lots of headroom is to run the coice coils in series then run the amp in mono @ 4ohms. To do this, run from one voice coil to another, a jumper. connect positive from one voice coil to the neg of the other voice coil. Then connect the remaning positive on one voice coil and the neg from the other voice coil to your amp (positive left and negative right on the amp) If your amp has a switch for momo make sure it is on, some are automatic. Hope this helps
Posted on Jan 02, 2010
How can I connect 2 15 (inch) Lanzar maxp15 subwoofers to a Lanzar 3000 watt 2 ohm mono block amp?
You need to find out the voice coil ohms and if you have 1 or 2 voice coils in each sub and then wire accordingly.
Apr 15, 2016 | Lanzar Car Audio & Video
I have a lanzar stearo DVD and GPS and it does not hold it's memory
It has a power wire and a memory wire on the back of radio. Usually yellow for memory wire. The memory wire has to be connected to a constant hot wire 12v
Jul 08, 2014 | Car Audio & Video
Wire
need a little clearer description of what your trying to do. 1) what ohm load are your subs dual 2 or dual 4
Jan 13, 2013 | Lanzar HBP310 Car Subwoofer
LANZAR SNV65i3D INSTALL INSTRUCTIONS.... LANZAR THEMSELVES DON'T EVEN GIVE OR SHOW INSTALL INSTRUCTIONS FOR THIER PRODUCT.... also what does SW-KEY1, SW-KEY2, and SW-KEY GND mean? Thank you De
I found several schematics and tips just googling that model number. You may try to look it up yourself or check on YouTube. Good luck. A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
May 07, 2012 | Lanzar Snv65I3D Navigation Receiver
I have a lanzar max pro 15'' subwoofer and i need to know how to wire it. It has four wire inputs on each side teo positive and two negative, is this just to change it from 4 to 8 ohm or something?
In part yes it is a flexibility for wiring your speakers to match the impedance of your amp. For example if your subs are 2 ohm dvc by wiring them in parallel you can drop the impedance down to 1 ohm per speaker and if you connect two 1 ohm then you get 1/2 an ohm load. Or you can put them in series and increase the impedance to 8 ohms which I wouldn't suggest you do. Here is a link to wiring speakers:
http://www.crutchfield.com/S-cgSECUmngLm/learn/learningcenter/car/subwoofers_wiring.html
Sep 19, 2010 | Lanzar (Pair) MAXP104D Max Pro Series...
How do wire my 15'' to 1ohm
If each voice coil is rated at 2-ohm, then wire it in "parallel". This will make a 1-ohm total load.
amp pos. out to coil 1 pos. to coil 2 pos.
amp neg. out to coil 1 neg. to coil 2 neg.
If the they are dual 4-ohm, the rating would be 2-ohm in parallel.
Mar 16, 2010 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
How 2 bridge tha opti drive 1222d 12inch subs 2 the opti 600x2hc
You can check Both Crutchfield's learning center on subwoofer wiring diagrams and www.the12volt.com with their wiring diagrams. The crutchfield setup will be more informative for this type of problem. Just go one of the + to one of the - on each sub then wire the other plus's together between the subs as well as the minuses like between the subs and use the open plus and minus that u didn't just bridge. Then there should be just 2 wires a plus and a minus to the amp. Then follow the amp bridge wiring which should be found right above the speaker terminals it will be left plus to right minus or the other way around
May 05, 2009 | Car Audio & Video
Car Audio & Video Logo
63 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
