Question about Sewing Machines
Singer 1842U How to thread this machine. The manual has been lost. Thank you
  • 185 Answers
SOURCE: Problems with Singer CE-150... the LED light #19 keeps coming on, but I KNOW it isn't threaded incorrectly..
This machine uses a rotary thread break sensor. If you look at the top left of your machine when it is running the sensor (white dial) should be spinning. Threading around this part is critical. Make sure it spins when you pull thread through the needle. if it does not you have missed something in threading. If this is spinning and machine still stops it is likely the sensor is malfunctioning.
Posted on Apr 01, 2008
  • 4 Answers
SOURCE: TS 380 Tiny Singer Serger Manual - Threading
If you go to this page: http://www.singerco.com/accessories/manuals.html
at the search box, type in just the model number, ts380, and click search.
at the results screen you'll the "Free Download" for this manual (PDF format). (there are also options on that page to have them mail you one; but luckily this is one which also has a free downloadable version!)
Enjoy serging!
Posted on Sep 11, 2008
  • 3 Answers
SOURCE: Singer Concerto 9217 - problem threading bobbin
thread the same way as for sewing. put empty bobbin case in bottom. close slide plate only to red button, not all the way. wrap thread from needle around bolt that holds on the presser foot (or just hold it tight). press pedal to sew. bobbin should wind. when done, shut slide plate all the way and sew.
if this doesn't work, try using a pin to push down the center of the bobbin when the slide plate is in winding position - the little catch on the bottom of the plate breaks easily and then the bobbin won't wind without a little help.
Posted on Mar 03, 2009
SOURCE: free download of singer overlocker manual
Jag har en industri overlock singer 81k73 Jag kan inte trä den
Har du några förslag
Posted on Oct 20, 2009
  • 139 Answers
SOURCE: how to thread & what needles for singer 660 A2 sewing machine
You can download a manual here:
http://parts.singerco.com/IPsvcManuals/
Posted on Apr 07, 2010
How do you thread a singer merritt 1872?
Wow, one of the few Singer machines that doesn't have a free download manual. Hmmm..... Ok looked up a photo of your machine. It's pretty easy.
1. raise your presser foot.
2. Put thread on spool pin.
3. draw thread over to and under from behind of the pre-tension disc at top
4. Draw thread down from the right and under the tension dial to seat the thread into the tension discs and flex that spring a little.
5. Through the take up lever.
6. Down through the thread guide.
7. Down through the needle bar thread guide.
8. Through the needle.
Hope that helps.
Aug 20, 2012 | Singer Sewing Machines
Unable to thread machine correctly. I have misplaced my manual. Thank you
sewusa.com has threading diagrams
or singer has a free instruction manual
Go to the singer website
Go to the home page
At the bottom of the page look for instruction manual--click on it
It will take you to another page
In the box put the model number (example 3116) & click search
They have a free download
Aug 15, 2011 | Singer 3116 Simple
Instructions on threading top thread lost manual
on the website diplodocs.com they have free pdf manuals to download
go to diplodocs on page1
look on the right hand side for the alphetbet letters look for S
then look for the singer name,,click on the singer name
that will take you to page 2
look for a large box that says MOST COMMON SEARCHES
look for your sewing machine number & click on it & it will take you to the page 3
on the left look for the box that says FIND USER GUIDE FOR SINGER
click on the manual for your machine it will take you to the last page
page 4-go to box on left hand side that says user manual & it will show a icon it free shows pdf file click on download tab & it will take you to
the final page to the download either answer the questions or put in the code & download the free manual
the manuals are clear & easy to read
please rate this with the thumbs in the upper right hand corner ,thank you
Aug 06, 2010 | Singer 1120 Mechanical Sewing Machine
How do I thread my Singer 7422?
I suggest you do a search on youtube on how to thread a sewing machine and choose a video showing a similar machine as there are really only about 3 basic types of machine as regards the threading.
Some of these instruction videos are very good and you will find it much easier than explanations. However-the important thing is that the thread must go between the tension discs by your tension regulator and do make sure you have a good need le in the machine, inserted correctly.
Jun 22, 2009 | Singer 7422
I lost my manual and don't know how to thread the White Superlock 834DW electronic serger
Here is another singer threading manual
Should be the same.
www.singerco.com/pdf/14SH654_threading.pdf
Singer (white company) has a really good website.
You really want to reinvest in a manual for your machine, they really are a necessity.
Good Luck
Mar 30, 2009 | Sewing Machines
How to thread the machine
Does anyone can send me a copy of manual for singer 2502 C ?
Thank You Ann
Mar 01, 2008 | Singer 2517 Mechanical Sewing Machine
Sewing Machines Logo
59 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
