Question about Irons
GC7320 : my appliance has been well rinsed out, but is unable to produce steam when it starts to 'pump'. What should I do, please?
    Top Expert:
  • Irons Master
  • 12,223 Answers
See the instruction and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Posted on Jul 29, 2013
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: my Phillips gc7320 steam iron
Hi joseph mc410
Go to HomeDepot,Lowes,WalMart,any hardware store,etc.
Purchase some "CLR" mix it according to the directions on the bottle and pour it in your iron and let it work...then pour it out, flush with distilled water and you should have cleaned your iron now.
Please take time to rate me
Posted on Sep 19, 2011
Testimonial: "thank for you help"
Wont produce steam.Sole plate is hot and water is being heated but no steam being produced.18 months old,cleaned after every use.
Pour some vinegar in it and let it set for several hours cold. Then warm it up. This should start to dissolve the leftover minerals blocking the steam holes. May take several attempts, but it will eventually start to steam again.
Aug 08, 2015 | Irons
How can I get my Domena SP400 steam press to produce steam
Blockage " mineral deposits" get a de-scalar and follow the directions. Only use distilled water in steam iron.
Sometimes vinegar will work depending on mineral deposits causing blockage.
Apr 21, 2014 | Irons
GC7320
read the steps and fix it. God bless you
Clean an iron:
Jul 29, 2013 | Irons
Frigidaire stack washer and dryer water pump air bursts
follow this steps and use the common sense. God bless you
f the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below). If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water
Sep 25, 2012 | Frigidaire Stacking Kit for the Affinity...
MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON does not provide steam
My MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON has stop producing steam. I have changed the filter and although it heats up, it does not produce any steam.
Feb 29, 2012 | Irons
My Phillips gc7320 steam iron keeps spitting out brown water what is the best way to clean the chamber
Hi joseph mc410
Sep 19, 2011 | Irons
I have a Euro-Pro E8000. It is about 15 years old. The iron heats up but does not produce steam. I probably have not used it in about 1 year. Any suggestions?
Check that the steam holes in the base are clear. There are patent sale cleaners available commercially. Enquire at any major appliance store etc.
Jan 20, 2011 | Euro-Pro Irons
My new laurastar steamer is not producing steam at
plse call customer service on 1800 999 910
Nov 13, 2009 | Irons
Steam gauge is broken and iron will not produce steam
http://www.fixitclub.com/Parts_Components/Appliance_Controls.shtml click the link  Maintenance and repair tools you'll need to fix an electric iron include these:
  • Screwdrivers
  • Toothpicks or pipe cleaners
  • Sewing needle
  • Commercial electric iron cleaning solution or vinegar and water
  • Commercial soleplate cleaner or baking soda and water
  • Steel wool
  • Emery cloth
  • Metal cooking pot
you will need a speacial tool screw driver  also called as g5 screw driver to open it.available at local repair store. If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Mar 26, 2009 | Rowenta Irons
Russell Hobbs Steamglide 2200 - no steam
Same with mine! What you have to do is keep taking the water cannister off and pushing back on until its lined up correctley. Also have the whole unit at the same height as the ironing board, that should do it! Can you help with filters? I cant find them anywhere.
Mar 23, 2009 | Irons
Irons Logo
95 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
