Rotel rcc 945 technical manual - Audio Players & Recorders
Rotel rcc-1055 won't stop spinning carousel. It will sometimes play a disc but mostly spinning looking for a disc
Your changer has lost its mind and is doing crazy things.just like mine. Software issue not repairable.. Go shopping.
Sep 12, 2017 | Rotel Audio Players & Recorders
Idealistic graphic equaliser model 31-9081
Connect your Denon outputs to the Realistic main inputs.
Connect your Realistic main out to the Rotel tuner in.
Connect your Technics out puts to the Realistic Tape 1 inputs.
Connect your tape 1 out puts to your Rotel cd inputs.
And you should be good to go.
May 02, 2016 | Audio Players & Recorders
Need Rotel RT-1080 Tuner User Manual
Hello
Get into this site from you can download the user manual for your Rotel tuner.
www.rotel.com/content/manuals/rt1080.pdf
OK
Aug 12, 2011 | Audio Players & Recorders
Hi, I have a Rotel 1050 receiver that I am trying to hook up to a NAD 2400 THX amp. I do not know how to "bridge" the connections so that the Rotel amps are not disabled. Any help is appreciated.
I think the best solution is to remove the jumpers from the Pre Out - Mon In connectors, insert a pair of RCA Y-adapters and plug one end back to the Mon In while the other ends feed the NAD (Page 15 of the manual available at Retrevo.com) . The Rotel's volume and other controls will still be in charge of the NAD.
The manual fails to mention looping the Pre Out back to the Mon In to enable the Rotel's amp to still participate in the program material.
Apr 10, 2010 | Rotel RMB-1095 Power Amplifier
Rotel processor bypass for Audio Research SP10
If I understand you, the 'sound' of the AR preamp is what you're trying to preserve. Presumably you're just running a phono through it as nothing else needs a preamp these days.
The multichannel inputs bypass all of the Rotel's processing except the volume. Use the Front L and R.
Mar 12, 2010 | Audio Players & Recorders
Roland FC-100 MKII
Hi - not sure if you found a solution to your question. One thing I found hunting around for a new rcc ( since my cable was stolen a few years ago and now I need it...of course) was another blog where the cable had "crimped" ; the user had cut out the bad section and spliced it.
You may want to test it, along each bit of length to see if your patch and bank switching enables to see if that's the problem.
Jan 20, 2010 | Music
Manual circuit diagram
I don't believe that Rotel service manuals are available outside of authorized service centers. Can you provide us with the problem that you have? Perhaps we can guide you through the repair.
Thanks,
Dan
Sep 20, 2009 | Rotel Audio Players & Recorders
Rotel RMB-1095 Power Amplifier Problem
Sounds like wiring problems. Unhook everything, then get owners manual for proper instruction
Apr 13, 2008 | Rotel RMB-1095 Power Amplifier
13 people viewed this question
 Grubhead
Grubhead
