SOURCE: Error Code on photocopier
Please clean or change the charge roller .The your problem in the HV parts.Verify the drum ground plate.
SOURCE: ricoh aficio 2018d error sc302 can someone please
The manual says that this is a chage roller leak.
Means the the high voltage is arching to ground or drum somewhere....usually pinhole in chage roller
SOURCE: i have a problem in copier ricoh 1018 this problem
You have a corrent leak in the charge roller.
In the best scenario you could have dust in the contacts of the PCU (Fotoconductor Unit).
Try to take it off (PCU). You will see a metallic pin in the back. Clean it whit a dry coth.
