Question about Juicers
Nutrifaster 350 repair manual - Juicers
Base motor
The Start capacitor in the motor is faulty or the centrifugal switch is worn out info@nutrifaster.com.au
Jul 13, 2013 | Nutrifaster Ruby 2000 Juicer
What is the difference between the Ruby 2000 and Nutrifaster N350? Were they once produced by the same manufacturer?
If both juicers were purchased in Australia the same the brand name changed in 2001 from Nutrifaster the company to The Ruby Juicer
Feb 25, 2013 | Nutrifaster Ruby 2000 Juicer
I need a Ruby 2000 manual. How can I get it?
Go to the Nutrifaster Australia website and you will find it
Click on this link: http://nutrifaster.com.au/juicing-bar-equipment/multifruit-juice-extractors/4:1155/
Dec 28, 2010 | Nutrifaster Ruby 2000 Juicer
Broken side clip on cover of juicer
The main problem is that the CLIP needs to be adjusted in order to have the correct pressure adjustment the lever clip should be at a 45 degrees level once is clipped at the bottom anchorage it will be OK to much pressure will brake the securing pins of the unit info@nutrifaster.com.au
Oct 08, 2010 | Nutrifaster Ruby 2000 Juicer
HOW TO SOLVE PROBLEM WITH PUMPACK WITH LOW PRESSURE in model oj 106 juice tree/nutrifaster
check oil level if low, add mobil one oil. check for oil leaks.low hydraulic pressure is sign of low pressure in the valve housing, unit should be rebuilt by replacing o-rings in the housing . email me for help.
Jun 04, 2010 | Nutrifaster Juice Tree 106-OJ Commercial...
Bearing noise
Why don't you contact Nutrifaster as see if they can assist?
Nov 01, 2009 | Nutrifaster Ruby 2000 Juicer
How do i sharpen the plate on my commercial nutrifaster N450
The Nutrifaster blades do have to be sharpened every so often. You can send the blade into Nutrifaster and they will sharpen the blade for you. Go to Nutrifaster.com and look under spare parts.
Sep 22, 2009 | Nutrifaster N450 1056 Watts Juicer
Nutrifaster N450 hex nut stuck
Your unit is a Nutrifaster not a Ruby juicer tray again their website of Nutrifaster in Seattle USA...good luck
Aug 30, 2008 | Nutrifaster Ruby 2000 Juicer
Juicers Logo
153 people viewed this question
Top Juicers Experts
eyecam
Tom Chichester
David Payne
David Payne
Are you a Juicer Expert? Answer questions, earn points and help others
