Kyocera km-2050,showing error code 0210,solution.
  • 43 Answers
SOURCE: error code C-6 for kyocera km 1500
Fuser error,
may have either a blown lamp, blown thermo fuse or faulty thermistors, but more then likely a combination of at least two.
Posted on Mar 02, 2008
sir fixalot
  • 146 Answers
SOURCE: Kyocera KM 3050 - error C3300
Error C3300 is a CCD Automatic Gain Control issue.
It could be poor contact in the connector terminals from the SHD PWB to the CCD PWB.
It is more likely a defective exposure lamp or inverter board that powers the lamp.
Try lifting up the Document feeder so you can see the optics frame through the platen glass and turning off and then on, the main power switch to see if the green exposure lamp illuminates.
A better, but more complicated way to check the lamp is to enter the service mode and run the exposure lamp test simulation. I will outline this procedure below. BE SURE NOT TO MESS WITH OTHER THINGS IN SERVICE MODE OR YOU COULD RENDER YOUR UNIT COMPLETELY UNUSABLE.
To Enter Service Mode:
Hit the "Status" button
Hit the following sequence on the numerical keypad:
1 0 8 7 1 0 8 7
You should be in service mode.
Use U601 by typing 6 0 1 and then "Start"
U601: Turning the exposure lamps on
Description: Turns the exposure lamp on.
Purpose: To check the exposure lamp.
Display:
CCD: Main Exposure Lamp
CID: Document Processor Exposure Lamp (inside the feeder)
Method
1. Press the start key.
2. Select the item.
3. Press the start key. The selected lamp lights.
4. To turn the exposure lamp off, press the stop key.
Completion
Press the stop key. The screen for selecting a maintenance item No. is displayed.
After checking the lamp(s) operation hit "reset" a few times to back out where you can type 0 0 1 "Start" to Exit Service Mode.
Posted on Jun 03, 2008
SOURCE: kyocera km-2050 scanning function
The km 2050 was on network, but moved to home and directly into tower system via usb interface connector. Printer works, but can not get scanner to work? read instructions without a clue. can someone help with correct proceedure?
Posted on Mar 12, 2009
mysticus_tam
  • 40 Answers
SOURCE: Error Code C6050
First you must get into the service mode by keying in 10871087
The screen will start blinking - then key 163 and the screen should read cancel or execute -select execute
when it is complete turn unit off then back on and see if that worked, if not buy a new fuser unit. They cost around $150,00 to $200.00 depending on who you buy it from.
Posted on Dec 21, 2009
SOURCE: I have Kyocera km-2050 it
press 1087, 1087 until the machine shows U000 self status, press 163, press start and then scroll to execute and then press enter. the machine will iunitialize and come ready for copying
Posted on Dec 06, 2010
Kyocera km-1500,showing error code A-0210,solution
A communication problem between main board & engine board.
Chk the connector YC3 on main board & connector YC3 on engine board. chk terminal continuity, if not replace the terminal. Very rarely main board or engine board may go bad.
If you are facing any difficulty, download the manual go through it..
Sep 04, 2015 | Kyocera Office Equipment & Supplies
Lost the pin code for kyocera 2050
The default code for the Kyocera KM-2050 is 6482.
Jun 30, 2015 | Kyocera Mita KM-2050 Printer
Error code in 3045 km kyocera
Zero-cross signal error
While fuser heater ON/OFF control is
performed, the zero-cross signal is not
input within 3 s.
fuser related problem
Jan 08, 2014 | Kyocera Mita KM-2050 Printer
I have Kyocera km-2050 it coming error for call for services error code -C6400
Dec 05, 2010 | Kyocera CS-2550 Black and White Copier
KM-2050 Printer: i need to find the pin number to my kyocera km-205...
I need to create a new pin on kyocera 5050 machine as the old one is lost
May 05, 2010 | Kyocera Mita KM-2050 Printer
Printing problems Kyocera KM 2050
when this error comes up..hit the print button on the left hand side..this will than tell you on the screen wha the actual problem is..i.e ( out of paper...lost connection etc
Jan 29, 2010 | Kyocera Mita KM-2050 Printer
Error Code C6050
May 25, 2009 | Kyocera Mita KM-2050 Printer
Kyocera km-2050 scanning function
Mar 04, 2009 | Kyocera Mita KM-2050 Printer
117 people viewed this question
k24674
jasbo
jasbo
