Question about Safe International Secure Logic 20710 Keypad Wall Vault Safe
Where can I get a new key?
I've lost the key and the battery is dead and cannot open. where can I get a new key?
Need help battery dead and doors locked
This probably far too late but you can open the driver's door manually with a key regardless of battery condition.
May 05, 2013 | 2002 Land Rover Freelander
Electrical problem
check ignition switch terminals and block connector...
Jan 09, 2013 | 2004 Yamaha V Star 1100 Classic
2007 is250 battery died, then was fully chared, now the car isn't detecting the key and won't start
all new cars are set up that if the battery deads it goes into lockout mode. it is so the dealer ships can make money
Dec 16, 2012 | 2007 Lexus IS 250
2000 Chrysler Sebring w/year old battery.  Advise, what could have occurred when AAA jump me???  Left tiny interior light on under my mirror--battery dead.  After AAA came, I let it run
I doubt the service person did anything wrong. In today's cars with both engine and body computers, jump starting a car can be risky.
You're better off having the battery charged for an hour or so then trying to start it.
You may have to have the body computer scanned and possibly flashed to get everything working again. The body computer controls everything you mentioned. It could have lost some of the factory programming when the system was dead.
Sep 19, 2012 | 2000 Chrysler Sebring
My range rover 2007 key is completely dead
surely my friend your key has lost its program. Need reset the program even I believe the ignition key. Refer to main dealer about it
Sep 14, 2012 | 2008 Land Rover Range Rover
My car won't start and key won't come out.
I hate to be the bearer of bad news, but your vehicle is NOT fixed. Fuses do not just go around blowing to make your day miserable - ESPECIALLY not a 60 Amp MAXI fuse! That is some SERIOUS stuff!
There is apparently an intermittent dead short to ground in one of your main power circuits if one of those are blowing. It WILL do it again if you do not locate the problem and repair it. I just hope you get it fixed before it burns your vehicle to the ground.
May 16, 2012 | 1997 Oldsmobile Achieva
Bttery is dead, can't get in, have keyless entry, no key, can't open the hood or anything, toyota venza
remove grille and move latch to open hood-boost battery and use key fob to enter or have locksmith or service station use a slim jim or other type of device to unlock door
May 13, 2012 | 2009 Toyota Venza
My 2005 Cadillac STS has a completely dead battery. Nothing lights up when I pull on the door handle. I just moved and I have no clue where my key is since I've only used the FOB since I've owned...
Raise the car up,support it in the front
Put a battery charger on the battery cable
at the starter and the ground to the sub frame
Charge the battery for a couple hours,then try to
open the door with key fob
May 21, 2011 | Cadillac STS Cars & Trucks
I have lost my pin and backup keys + battery dead!
i got the same problem i lost my key and cant open now
any idea what to do
May 28, 2009 | Safe International Digital Electronic Safe...
My electronic key has been lost and my valet key which used to work, won't unlock the door.
IS THE BATTERY DEAD? HOW LONG HAS CAR BEEN LOCKED UP? IF THE VALET KEY WILL NO LONGER OPEN THE DOOR YOU HAVE LITTLE CHOICE BUT TO TOW IT TO DEALER TO HAVE KEY CUT & PROGRAMMED
May 11, 2009 | 2003 Volkswagen New Beetle Convertible
Safe International Secure Logic 20710 Keypad Wall Vault Safe Logo
147 people viewed this question
Top Safe International Home Security Experts
Computer Repairing
Computer Repairing
Theo Nikolaidis
Theo Nikolaidis
Are you a Safe International Home Security Expert? Answer questions, earn points and help others
