Question about Microwave Ovens
Brown spots on window of microwave - Microwave Ovens
    Top Expert:
  • Microwave Ovens Master
  • 12,223 Answers
See this steps and fix it.God bless you
  • Waveguide coverSparking and arcing in a microwave can be caused by a damaged waveguide cover. Try removing the waveguide cover to see if the problem persists. Once removed, the waveguide cover can be inspected for burns, which will indicate if this is the issue. If the waveguide cover is burnt or will not stay in the proper spot it will need to be replaced.
  • Cavity/Rack supportIf sparking or arcing in your microwave is near a rack support, any exposed metallic area can be covered with a microwave cavity support. It is also recommended to replace the rack supports in this situation to ensure the issue is resolved.
  • Cavity paintIf sparking or arcing in the microwave is visible on the side walls, the paint covering the metallic areas could have worn off or chipped. This can possibly cause pitting in the side walls or ceiling. If this is the case, it can be repaired with microwave cavity paint
  • Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#10#ixzz2aSjW5F9U
    Posted on Jul 29, 2013
    Rust or brown spots on window of microwave
    follow this steps and fix it. God bless you
    Jul 29, 2013 | Microwave Ovens
    No instuctions on how to brown or sautee food----------how do you brown food???? very disapointed in manuel
    Browning and sauteing food really depends upon the type of oven you have. If it is a microwave oven only then there are speciic food containers that are designed to get hot. If a convection type oven then the grill browns the food.
    Mar 27, 2011 | Microwave Ovens
    Inside ceiling of white microwave is brown What to use.
    Try Lysol non abrasive kitchen cleaner. Also try vinegar.
    Apr 30, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    Please Help my GE Microwave produces no heat!!
    Most of the time it seems to be the magnetron. The Magnetron is what heats the food, when you remove the magnetron sometimes you will see signs of wear like a black or brown spot on the tube sometimes there is even a hole burned through. A cheap place to find these part is Global Micro Parts in Dallas TX. Usually Magnetrons are about $30 - $45 and shipping is only 7.95 there web site is www.allapplianceparts.com
    Oct 26, 2008 | GE JVM1850 1000 Watts Microwave Oven
    Microwave door has burn spots on the glass of the door...
    i have the same problem, there is a brown spot about 3 inch
    by 2 inch at the bottom of the glass, I cannot clean it, it looks
    like its in between the glass.
    May 01, 2008 | Whirlpool MH6150XMS Microwave Oven
    Kenmore Over the Range Microwave
    If you think the window is stained, you ought to see the rest of the inside! Wife is probably right. (wink, wink, nod, nod)
    Actually, you can take the cover off, remove the front panel without much effort and clean everything and get a lot more life out of it. Microwaves usually die because of heat related problems caused by buildup of yuck on the guts.
    Hope Ya Make your Wife Happy!
    Jan 24, 2008 | Microwave Ovens
    Emerson Model MW8627W does not heat after changing fuse!
    check the magnitron and capacitors one of this is bad
    Sep 18, 2007 | Emerson MW8627W Microwave Oven
    The brown spots are usually grease / smoke deposits. Usually there are indeed two sheets of glass in the door. If the grease is not arcing or smoking, and the metal screen / mesh (that blocks microwave leakage) is not damaged, then it's likely better left alone. It might be useful to boil a few cups of water with a little vinegar inside the microwave to help dissolve the deposits. In case you want to take it apart, I have attached a photo from a similar model that illustrates disassembly of the door. It is not necessary or advisable to remove the door or hinges when disassembling the door.
    Jun 25, 2007 | Goldstar MV-1501 Microwave Oven
    Microwave Ovens Logo
    187 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
