Question about Microwave Ovens
Rust or brown spots on window of microwave - Microwave Ovens
    Top Expert:
  • Microwave Ovens Master
  • 12,223 Answers
Follow this steps and fix it. God bless you
  • Waveguide coverSparking and arcing in a microwave can be caused by a damaged waveguide cover. Try removing the waveguide cover to see if the problem persists. Once removed, the waveguide cover can be inspected for burns, which will indicate if this is the issue. If the waveguide cover is burnt or will not stay in the proper spot it will need to be replaced.
  • Cavity/Rack supportIf sparking or arcing in your microwave is near a rack support, any exposed metallic area can be covered with a microwave cavity support. It is also recommended to replace the rack supports in this situation to ensure the issue is resolved.
  • Cavity paintIf sparking or arcing in the microwave is visible on the side walls, the paint covering the metallic areas could have worn off or chipped. This can possibly cause pitting in the side walls or ceiling. If this is the case, it can be repaired with microwave cavity paint
  • Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#10#ixzz2aSjW5F9U
    Posted on Jul 29, 2013
    2 Suggested Answers
    SOURCE: my microwave oven has are rust spots;can I paint over them?
    Yes, you can paint over the spots and no, it's not dangerous. I'd let the paint thoroughly dry before using the oven -- it could otherwise cause paint to buckle/ripple/etc.
    Posted on May 03, 2009
    I wrote about it an hour or so ago, with no answer. My Emerson microwave is developing some rust spots along the very sharp edge of the " floor " where the door shuts on it.
    Could be grime. If that is rust then maybe there is too much humidity at the location of the microwave. Could also be old age.
    Sep 21, 2013 | Microwave Ovens
    Brown spots on window of microwave
    see this steps and fix it.God bless you
    Jul 29, 2013 | Microwave Ovens
    The microwave oven coating is peeling and exposing rust spots. what can I do to fix this? Do I need a professional repair person?
    No this is something you can repair yourself. Take sandpaper and gently rub rust spots until smooth. Then you need to get ceramic touch-up paint and repaint rust spots.
    Feb 09, 2011 | GE JX2030DMBB Optional 30" BuiltIn Kit ...
    I have a Spacesaver Microwave (manufactured 1988) that still seems to work ok, but I noticed on teh back wall under the glass tray the coating has rusted away. Should I continue to use this microwave?
    As long as the oven's metal bottom is sound underneath the rust, there isn't a problem. The cooking chamber walls are so thick and highly conducting that they reflect the microwaves extremely well even when they have a little rust on them. However, if the metal is so rusted that it loses most of its conductivity in the rust sites, you'll get local heating across the rusty patches and eventually leakage of microwaves. If you're really concerned that there may be trouble, run the microwave oven empty for about 20 seconds and then (carefully!) touch the rusty spots. If they aren't hot, then the metal underneath is doing its job just fine.
    Thanks.
    Jun 17, 2009 | Microwave Ovens
    Can I paint rust spots w/enamel paint? Dangerous to use?
    You will need to buy a appliance high heat paint. the spray can works the best.
    May 03, 2009 | Microwave Ovens
    My microwave oven has are rust spots;can I paint over them?
    My microwave is rusting inside. mainly the area where the turning wheels meet the base. I have sand and painted with microwave paint but after a few weeks the paint area around the wheels is rusting again.
    try the microwave touch-up paint again but this time clean the spots you sanded with rubbing alcohol. also make sure the rollers turn freely
    Jan 31, 2009 | Microwave Ovens
    Microwave door has burn spots on the glass of the door...
    i have the same problem, there is a brown spot about 3 inch
    by 2 inch at the bottom of the glass, I cannot clean it, it looks
    like its in between the glass.
    May 01, 2008 | Whirlpool MH6150XMS Microwave Oven
    The brown spots are usually grease / smoke deposits. Usually there are indeed two sheets of glass in the door. If the grease is not arcing or smoking, and the metal screen / mesh (that blocks microwave leakage) is not damaged, then it's likely better left alone. It might be useful to boil a few cups of water with a little vinegar inside the microwave to help dissolve the deposits. In case you want to take it apart, I have attached a photo from a similar model that illustrates disassembly of the door. It is not necessary or advisable to remove the door or hinges when disassembling the door.
    Jun 25, 2007 | Goldstar MV-1501 Microwave Oven
    Microwave Ovens Logo
    95 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
