Question about Craftsman Garden
Starts dies blower starts then stops each time
  • Craftsman Master
  • 1,807 Answers
Limited information in your description, would look towards a fueling problem/starvation.
Posted on Jul 29, 2013
I have craftmam leaf blower that will start and run for a few second before it dies. Once this happen it will not start again until it set over night and it then will start right up and stop again
Hey Ron,
Has this blower been sitting for a long time?? Sounds like the carb is stopped up.. there are many TINY passages that can easily stop up, take it to a qualified pro for a carb cleaning, setting, and a new spark plug.
Jul 10, 2017 | Garden
Intermittent heater blower and motor slugging and missing at certain speeds
it does it every so often not all the time it just dies while driving. then starts after a few minutes .but one time I sprayed starting fluid in throttle body and I got fire . but after fluid ran out it would die again . but would start a few minutes later.
Feb 27, 2014 | 1987 Isuzu Trooper
Blower motor not working
Reground your motor a lot of times the ground get rusty and do not make a good contact
Oct 09, 2013 | Honda Cars & Trucks
My echo pb265l doesn't start
first check for spark when it first dies then see if its getting fuel start there
Apr 18, 2012 | Garden
Briggs & stratton engine stops working - died and won't start
It sounds like it is time for a new ignition module. Get the model, type and code off the blower housing and go to www.precisionope.com. There you can look up the ignition module under OEM parts.
Jan 03, 2010 | Garden
Climate Control stopped working , no fan function or anything. Started to work then stopped, now nothing at all.
From the information that you've provided, it sounds as though the blower assembly went bad. You can access the blower by removing the glove box door and the panel behind it, which will reveal the heater core. The blower should be located on the side of it.
Jan 02, 2010 | 1998 Cadillac DeVille
The best way to start cold husqv leaf blower 145
Most of the small outdoor power equipment that I have used takes the following to start:
1. Prime 6-8 times, or whatever the manual calls for.
2. Choke the carb to full choke.
3. Pull starter rope. It may sputter and die.
4. After it sputters and dies, put the choke on 1/2. Pull a time or 2 more and should start. Run like that 10 seconds or so, then take choke all the way off.
Oct 30, 2009 | Husqvarna Backpack Blower 155 145 Starter...
Hi. My craftsmal leaf blower runs OK for 3-5 then dies????
Could be a blocked vent on your fuel tank - is there a vacuum in the fuel tank immediately after it stalls?
Oct 25, 2009 | Craftsman Garden
Blower motor runs but dies out..
When it does this carefully feel the end of the blower motor. If it is too hot to touch,Replace the blower motor.
Your 5 minute off sequence allows the motor to cool enough for a restart.
Apr 08, 2009 | Amana PTH153B50AJ Heat Pump Air...
did you check the volts? and the amps.
Apr 08, 2009 | Amana PTH123B25AJ Heat Pump Air...
Garden Logo
37 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
