Question about Husqvarna Garden
Replacing trigger on a e-series 137
Trigger broke and i cant take it off
  • Husqvarna Master
  • 1,807 Answers
replacing trigger on a e-series 137  - 1c5ff43e-1552-4f62-886f-2dc93ee15eb1.jpg
You need to tap the pin out through the side of the handle. Here is the picture out of the manual. I'll send you a link to the full manual.
Posted on Jul 29, 2013
My NERF gun broke.
Take it back to where you bought it. It shouldnt do that, it sounds faulty to me. I am sure they will replace a faulty item.
Feb 26, 2014 | Hasbro Nerf N-strike Longstrike Cs-6 2010...
I think you call it the throttle trigger i dropped and it broke i cant give it the gas
You need to rplace the trigger, if this is a 350, start by removing the throttle lock on the top of the back handle, gently open up the slot where the latch fits, at the same time pry the rear end of the latch up, it will pop up at the back, once up pull the latch toward the back of the saw and away, now knock out the roll pin that the trigger pivots on, once out pull the trigger slightly back and down, it will just pull away, replace with a new trigger and re fit the the roll pin, push the throttle lock latch back into the tank and push the back end down to lock it into the tank, make sure the spring locates into the latch. adw1_11.jpg
Sep 18, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
When i unlock the car from the drivers side the passenger door stays locked. if i unlock the car from the pasenger side the drivers door stays locked cant figure it out?
You have a slave door electrical sysyem ... ie the drivers door is the Master door with a mechanical lock ,,, which sends an electrical trigger to All the other doors.... the passinger door does not have the trigger signal for the rest of the doors, but can operate via a Key .(or elec trigger from drivers door) So to recap Driver door (master (no motor) all others triggered by Drivers door . So dud passanger door motor. Good luck
Apr 08, 2010 | 1999 BMW 323 Series
Safety trigger will not push down to pull trigger
Up inside the trigger is where the safety hits, it moves in the way of the trigger to get it to fire, but it has to hit something in between, i have the same gun, only older, and I deactivated the safety so I could get in tight spots. You should be able to see what is stopping it from moving, then see if the part is bent, broke, missing, whatever. I don't recommend disabling it. But you want to get it going. Hope this helps.
Apr 02, 2010 | Senco 2D0001N FinishPro2N1, 18 Gauge Brad...
Cleaning solution tank dumping
in some cases the reservoir that the tank sits on would have to be replaced. best way to tell is, if you take the tank off and pour a little water in the valve where the rubber gramet is. if it holds the water its good, but if it goes down without you pressing the trigger then it will be the reservoir.
Jul 27, 2009 | Hoover F5906-900 Upright Steam Vacuum
How to get code for 93 bmw radio after battery replace
The code you are needing can be accessed online. just jump bmw.com
Jan 28, 2009 | 1994 BMW 3 Series
Rain bow E series power head
Maybe these pictures will help, I think your wire broke off by the hose.
Feb 02, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Shampooer
aqua mates have an o-ringed valve assembly that go bad regularly reccoment having it replaced by local vac shop
Oct 07, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Garden Logo
43 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
