Whirlpool stylemaster 4213632 - Washing Machines
5 Suggested Answers
philbran
  • 242 Answers
SOURCE: washing machine does not spin
If the unit is making noise while set to spin but not spinning replace the motor coupling for the fix.
If the unit is silent when set to spin replace the lid switch for the fix.
Both are very common and not expensive plus easy to find online with the model number under the lid. Let me know if you have any other questions.
Phil
Posted on Apr 11, 2009
  • 56 Answers
SOURCE: we have a Whirlpool washer stylemaster 4213632
Probably a bad timer. $100 + for part alone.
Posted on Jun 13, 2009
  • 215 Answers
SOURCE: whirlpool 4213632 wont drain water on perm press or delicate
check manual as this seems to be correct, Often called rinse hold or crease gaurd on many other machines
Posted on Feb 11, 2010
SOURCE: Whirlpool Stylemaster 4213632 Rev-B wont drain water on perm press and delicate cycles. Works fine on regular cycle
thir is a wrong model number. what's the model number?
Posted on Oct 29, 2012
Whirlpool stylemaster 4213964 washer will not drain because door sensor broke. Can this piece be repaired/replaced easily?
This is probably mid range difficulty. I could not find specifics on your model (most Whirlpool stylemaster washer model numbers .. at least in the USA ..start with "LA")
Regardless....here is a link that will give you an idea of what is involved for a top loading machine. The challenge is getting access to under the top deck of the washer to access the switch. There is usually a combination of unbolting/unscrewing/prying to get access
How to Replace the Lid Switch Lock Assembly on Top Load Washer Repair...
Helpful?
Good luck on your troubleshooting
Feb 17, 2018 | Whirlpool Washing Machines
Why won't my Whirlpool Washer Stylemaster #907675 fully drain?
The pump may be failing. That's where the leak is coming from.
Jul 28, 2014 | Whirlpool Washing Machines
Grinding noise in spin cycle
It sounds like the drain pump needs replacing, its bearings have failed or there is something from the wash jammed in it. But before you buy a new one, get the machine checked by an expert in case lots of parts are damaged.
Dec 20, 2013 | Whirlpool Washing Machines
Whirlpool 4213632 wont drain water on perm press or delicate
Feb 11, 2010 | Washing Machines
My Whirlpool stylemaster 907675 Washer wont spin.. The lid switch is fine.. Washes fine and all other cycles work.. just wont spin.
Hi, stylemaster washing machine won't spin on the top half. The bottom part spins perfect. the top doesn't seem connected. What
should I do ?
TIA
RJ
Jan 08, 2010 | Washing Machines
Will not drain or go into spin cycle
Definetly the lid switch has been knocked out of place or has gone bad.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Aug 26, 2009 | Whirlpool Washing Machines
Washing machine does not spin
Phil
Apr 11, 2009 | Whirlpool Washing Machines
Washing Machines Logo
102 people viewed this question
Top Washing Machines Experts
