Question about Polaroid 7-in. Internet Tablet - Other
Charging battery on Tablet which is totally dead
I thought I was charging Tablet for 8 Hrs. and Tablet is totally dead. Need assistance, please.
  • Polaroid Master
  • 16,404 Answers
Depends on how long it sat for with no charge. LION batteries dont recharge from totally being dead if they are left discharged for long periods of time.
Posted on Jul 29, 2013
My 11 galileo pro tablet will not power on after charging for 9+hrs.. When plugged in the blue indicator light flashes..What is going on?
The blinking blue indicator may be reassuring you that charging is in progress when, in fact, the battery may be dead or the charger is defective.
Jan 02, 2017 | Tablets & eReaders
After 4 months my Fusion tablet won't turn on??
To help you troubleshoot the issue, please follow the steps given below:
- If your device's battery is almost dead, you'll often see an empty battery indicator on the screen when you try to turn it ON. But if you let the battery completely die, your tablet won't respond at all when you press the Power button.
- To fix this problem, just plug your tablet into a wall charger and let it charge for 15 minutes.
- Now try to power it ON with the Power button, if the problem was caused by a dead battery, it should boot up normally.
- If it doesn't work at all, try plugging the device in with a different cable and charger. The charger or cable could be broken and preventing an otherwise-good device from charging.
- Your device may be powered ON and running but the screen won't turn on because the operating system is frozen and not responding to button presses.
- You'll need to perform a 'Hard Reset', also known as a 'Power Cycle', to fix these types of freezes.
- You'll need to long-press the 'Power button' of the tablet and hold it down for 'Thirty seconds' this will cut the power to your tablet and force it to boot back up, fixing any hard freezes.
Now check if your tablet works fine, if issue persists, please go to your device manufacturer website and see the instructions for performing factory reset or you can contact the manufacturer for further assistance.
GuruAid.com
Jun 02, 2016 | Tablets & eReaders
Guys! Help. My Dopo internet 7 tablet shut off. And it won't come back on. The model is DP717 please help me out! 8(
plug charger into tablet(in and out several times quickly)Try charging 24 hrs., if this dose not work could be faulty charger or battery.
press helpful button
Jan 06, 2016 | Tablets & eReaders
Tablet not charging while plugged in
Turned off the tablet, unplugged the charger and kept the tablet off for about 30 minute to one hour, plugged in back the charger, then turn on the tablet. After that I you might see the tablet started charging. Good Luck.
Jul 10, 2015 | ASUS MeMO Pad HD 7
Will not turn on
Nook tablet won't charge
Jan 16, 2015 | Tablets & eReaders
How do i open the proscan 8 in tablet ?
When you press and hold in the power button it should boot up. If it doesn't the battery might be dead so charge it up and try again. If it doesn't boot up after charging we need more information.
Are you getting any kind of a screen or just nothing?
Oct 23, 2014 | Proscan 8 4GB Android 4.1 Tablet
I have had my kocaso m9100 tablet since this past christmas and not had any problems with it until recently. It went completely dead and i had it on the charger for more than 6 hours with a little red...
You need to check battery to see if the battery has correct voltage. Their should be on the battery the number for voltage of battery if battery is not at suggested voltage then check for tablet with voltage meter to see if the tablet is charging at correct voltage. If battery is at correct voltage then something is wrong with tablet. If battery is not at correct voltage then probably battery is bad. Let me know for further assistance
Aug 24, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
Hisense Pro 7 tablet isn't working
A totally dead battery can prevent the tablet from booting. A technician is the only one that can replace batteries in tablets. Contact the manufacturer for an RMA and repair.
Apr 07, 2014 | Tablets & eReaders
Tablet won't turn on
When you plug in the tablet to a charger, does the LED come on indicating that it is charging? If not, your tablet's battery is probably dead and you may have a dead charger. Try connecting your tablet to a PC's USB port, with the PC turned on, of course.
Leave the tablet connected and the PC on overnight. That should trickle charge your tablet enough that it will power on. If that doesn't work, your tablet may have a bad battery, a bad charging port, or your charging cable is bad. Try it with a different cable as that is the cheapest solution at that point.
Jan 10, 2014 | Samsung Galaxy Tab Tablet PC
My Samsung galaxy 10.1 tablet will not charge. It keep flashing between an empty battery symbol to a flashing yellow battery symbol. going Off and On. I can not get it to turn on at all. Im pretty sure...
Hi my Samsung galaxy tablet is flashing icon on and off signal but not charging? I have tried turning off for 30seconds still dead what should I do?
Jul 30, 2013 | Samsung Galaxy Tab Tablet PC
Polaroid 7-in. Internet Tablet - Other Logo
471 people viewed this question
Top Polaroid Tablets & eReaders Experts
John mullen
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Polaroid Tablet and eReader Expert? Answer questions, earn points and help others
