Unable print 4a
How to fix unable print 4a on screen mfc brother j220?
    New Friend:
  • 9 Answers
Turn the printer off. Unplug from the wall and power back on after about 5 minutes. See if the mechanics reset.
Posted on Jul 29, 2013
komguy
  • 2306 Answers
SOURCE: Brother MFC-9440CN error 5A print unable
Error 5A unable to print is a problem with the high voltage power supply PCB, or with the engine PCB. A shop could tell you which one after some testing. Expensive repairs...
Posted on Jun 29, 2009
  • 583 Answers
SOURCE: Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Posted on Jul 13, 2009
cene765
  • 787 Answers
SOURCE: unable to clean print heads
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41,49 or 4F the print head is defective.If the error is 48 - defective print head cable or circuit board.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the annoying cannot clean message.
Posted on Nov 24, 2009
pineworks
  • 4041 Answers
SOURCE: Print Brother Mfc-290c Error Print unable 4F
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 18, 2010
pineworks
  • 4041 Answers
SOURCE: Brother MFC-465CN says 'Unable to Print 5A'
Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Posted on Mar 02, 2010
Unable to clean50 brother mfc-j220
You need to do the following. Enter maintenance mode by pressing Menu * 2864 in less than 2 seconds. Press Stop and retry if you dont see the lights blinking. Then press, 80, 2864, 4460, 99. It should work, otherwise its a fault service station pump
Jan 07, 2015 | Brother MFC J220 Multifunction Printer
Brother MFC J220 unable to print 73
The cap lift cam switch is defective. you will need to replace either maintenance unit or the ASF motor assy
Aug 17, 2014 | Brother MFC J220 Multifunction Printer
Unable to clean 5A for brother printer MFC J220
check for ink levels and also check for rollers and usb connections drivers etc
Apr 05, 2014 | Brother Office Equipment & Supplies
Unable to init. 4F
4F is Main PCB Faulty unfortunately most likely from Power surge. Do you have warranty ?
Feb 25, 2014 | Brother MFC-J615W Compact Inkjet...
IMPRESSION IMPOSSIBLE .4F
change your print head, and the printer will work perfectly.
when changing print head don't use chineese ink, use brother original ink, to save your head,
Hot Sell Printhead For Brother Mfc J825 Print Head Buy New And Original... Printhead Mfc j220 Mfc j615w Mfc j410 Dcp j125 Printer Head Buy Print Head...
Oct 05, 2012 | Brother MFC-J220 All-in-One Color Inkjet...
UNABLE TO init48 BROTHER MFC-J220
I think the printer head need to be replace
Jul 09, 2012 | Brother MFCJ220 All-In-One InkJet Printer
Troubleshooting : unable 4f cant print
Error 4f mean the head drive voltage has dropped from the high to low level in an abnormally short period.This mean your printer need new print head.This will cost you just as a new printer, then think about new printer.
Nov 04, 2009 | Brother Multi-Function Center MFC-240C...
k24674
jasbo
jasbo
