Question about Haier 45-Pint Dehumidifier
Eledtrical Have power to the unit, lights on top of humidifier do not light up the unit is dead. have had this unit for four years no problems, it will not start.
  • Haier Master
  • 17,164 Answers
What is the exact model number?
Posted on Jul 29, 2013
Testimonial: "HD456E Haier"
I plug it up display shows 8.8. and goes blank. Power light on top and side is green ON. Full bucket light and alarm works, timer button works, nothing else works.
Hello Ethan, thanks for your submission!
Based off what you have described your Frigidaire dehumidifier is displaying 8.78 after being plugged in. This could be an internal issue with a sensor or panel. You may need to contact your manufacturer for additional assistance. Good luck! -Matt
Apr 27, 2016 | Frigidaire Fdl50s1 Air Purifier &...
Power comes on but the humidifier does not capture any water
There are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1 & 2..
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Aug 19, 2011 | LG Dehumidifiers
The light indicating that "bucket
This usually happens when either the Float Valve in the bucket is stuck in the UP position (if yours is so equipped. Jiggle it to get it to return to the DOWN position.
If you humidifier's bucket is not so equipped. It's usually an indication that the bucket was not reinstalled properly, after it was removed. To check and correct this, turn the Master ON/OFF Switch to OFF and unplug the unit. Remove the bucket and reinsert it, making sure that it fits "squarely" in the bucket holder from Top to Bottom. Once installed, make sure the bottom of the bucket is not tilted down in any way. Plug the unit back in and turn the Master ON/OFF Switch to ON. If it was reinstalled correctly, the bucket full light should have gone off and the unit will run as it should, if the humidity extraction level is set low enough.
Hope this helped you to troubleshoot and solve the problem.
Jun 23, 2011 | LG LD40E Dehumidifier
THERE IS NO POWER OR ANYTHING WHEN I PLUG THE UNIT IN
check outlet
remove cover and check fuse on power supply board
Dec 25, 2009 | Maytag M7DH65B2A Dehumidifier
My dehumidifier is making a power surge every few minutes. why?
A dehumidifier is functionally the same as an air conditioner. It has a compressor motor, which is a fairly high current draw item.
First of all, unless you are well versed in electrical repairs, you should unplug this unit and do not use it. This is a dangerous condition and a fire or electrocution could result.
One of four things is happening:
1) You have a wiring fault in the circuit your humidifier is plugged into. There is a loose connection in the circuit, causing a voltage drop, and the humidifier therefore has to pull much more current to start it's compressor. This is a very dangerous condition, as an electrical fire could result. Try plugging the unit into another circuit and see if it does the same thing.
2) the compressor of the humidifier is going bad and is shorting out internally. Time for a new unit.
3) Many compressor motors use a 'start capacitor' to help the motor get going. If this part has failed, the motor will try to start, but it will not be able to.
4) There is a fault in the power cord or controls of the humidifier. Just like #1 above, a loose connection could cause a voltage drop, making the unit draw high current.
most of these units are standard 110V units. If yours uses 220V (like an electric dryer), then it could have 'lost a phase' which is also a similar electrical issue.
Oct 16, 2009 | Dehumidifiers
Dehumidifier
HI, you will need to check the terminal block. this is where the power cord runs to on the back side of the unit. make sure it is not lose or worn. you may have to disassemble the unit to expose the terminal block in this case. the power cord wires will spit into three or four little wires and, they will either be soldered or screwed on the block. make sure these wires are secure and not ripped or worn.
Now, if the terminal block is in good condition, this will confirm power board failuer and, in this case, you will need to replace the board supply board .
May 25, 2009 | LG LHD65EBL Dehumidifier
Will not turn on
Boys and girls, I hate to tell you this -- but those units are DEAD. I had the same problems as being discussed here (not turning on, electronic chirp, bucket full signals), but with one other important feature -- the unit became so hot that I couldn't touch the top. At first it sounded and smelled like the fan was jammed, and later it sounded like the compressor wasn't working.
Anyway, after two weeks of dealing with LG (1-800-243-0000, and be prepared to call back several times as they have a phone problem), they have finally decided to refund me the money on my unit. Give them a call and speak to them. Also, as my unit was intermittently working, I would recommend that you unplug your malfunctioning unit if you are having these problems. A dead dehumidifier is one thing, a house fire is quite another thing.
Aug 24, 2008 | LG LHD45EL Dehumidifier
1 yr old and Stopped working
the beep sound means that there are ac voltage in the unit but you gona need a tech there is no removal parts in that board and sound as a bad ic is there..good luck
Aug 05, 2006 | Kenmore 54701 Dehumidifier
Haier 45-Pint Dehumidifier Logo
37 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Bill Long
Jim Thurston
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
