We have just bought a second hand psp without charger only usb port so tried a separate 5v dc charger now nothing is working may have blow charger or is there a fusible link ?
Hi there, I am assuming that it was working ok until you tried to charge it then?? I have come across this problem before and you are right about the fuse, there is a fuse on the charge/power circuit that is located in the very top right hand corner of the motherboard, next to where the black power lead attaches to the motherboard - if you repair or bridge that fuse then it will work fine assuming that like I said at the begining it was working before you put the wrong charger in. If you cannot repair that fuse then the console will work fine if you can charge the battery without using that PSP (i.e. another psp or third party external charger) as there is no fuse on the battery circuit as there would not be a surge in power unlike the mains circuit. If you need more information or if this reply is not clear then let me know and I'll get an image of the fuse you need to repair.
my psp dc in does not work
