Question about Garden
Connect governor spring
Kohler Courage21 motor. Where does the governor spring connect at?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,917 Answers
Go to google type in ask kohler technions that will bring up a sight to ask about govnor linkages were they attach and talk to techniction
Posted on Jun 07, 2014
2 Suggested Answers
  • 110 Answers
SOURCE: Governor and Carb spring linkage
the solid wire link goes from the top hole in the governor rod to the carb and the spring goes from the lower hole on the rod to the throttle plate where the cable attaches
Posted on Nov 01, 2009
Honda Gv 100 works well if grass is short to medium loosing power with high grass any idea
Patrick, Ensure mower has good gas, good spark plug,Is the blade good and sharp. Clean any dirt, grass etc, form around the carburetor and governor linkages. It is possible the governor on engine may need adjusted, or spring off or a dirty carburetor needing cleaned internally. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Governor Adjustment and How They Work Honda Briggs Tecumseh Kohler etc
How Small Engine Governors Work any governor setup
honda governor adjustment Google Search
Apr 07, 2016 | Honda Garden
How to set up the governor on a Kohler K141 petrol engine on Howard rotovator
if it is a petrol engine then the governor arm will hold the carby open when stopped
as the engine starts the governor moves the arm to close the carby off to idle. the speed setting is by a spring attached to the throttle level and a point on the governor lever
Feb 13, 2015 | Cars & Trucks
Kohler engine troubleshooting
I would be looking into the governor system... starting with the spring and then internal... but I would also looks at the connection at the carb... any play, damage ???
Sep 01, 2014 | Garden
Kohler V-Twin (624 cc) RPM on the engine does not stay stable , It will raise and lower the RPM in any Throttle Range. Could the Governor be going bad???
Try a static governor adjustment first as it simply be out adjustment.
Static Adjustment Procedure
Make this adjustment whenever governor arm is
loosened or removed from cross shaft. Adjust as follows:
1. Make sure throttle linkage is connected to governor
arm and throttle lever on carburetor.
2. Loosen nut holding governor lever to cross shaft.
3. Move governor lever toward carburetor as far as it
will go (wide open throttle) and hold in this position.
4. Insert a long thin rod or tool into hole on cross shaft
and rotate shaft clockwise (viewed from end) as far
as it will turn, then torque nut to 6.8 N·m (60 in. lb.).
Aug 23, 2014 | Garden
Lawn mower governor spring connection points. I know one end goes on the governor lever ,just having a hard time figuring out where to connect the other half of the spring. Model #917.387160 Engine model...
go to a lawn mower shop and ask to look at a diagham of the motor it should show were it connects or if the mechanics are friedly they may do it for you
Aug 05, 2013 | Garden
Can I change a 10hp generator motor with an automatic throttle to a manual throttle?
Yes, you will be able to control the throttle. Look for a lever that pulls on the governor spring. On some generators, the governor spring attaches to an arm with adjustment screw and locknut or metal tab that bends into position. All that you need do is to pull on the governor spring to increase rpm. The governor spring pulls on the governor arm that is attached to the fly weight governor inside the engine. The fly weight is turned by the cam gear in most cases and the force that it produces is constantly trying to close the throttle. The governor spring provides the counter force to open the throttle. Without the governor, the engine can over rev. Good luck with your project.
Nov 18, 2011 | Briggs & Stratton Electrical Supplies
1982 kohler in rv put in new brushs only putting out 96 volt
Try raising the engine rpm slightly. there should be a adjustment on the piece that hooks to a spring which is connected to the governor arm.
Mar 26, 2011 | Kohler Electrical Supplies
I HAVE A CRAFTSMAN KOHLER THAT WILL RUN WHEN
the foat could be plugged or not alowing enough fuel to get into carb.
Jul 08, 2010 | Craftsman Garden
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
