Question about RCA 32V550T 32" TV
Television will not turn on
My RCA 32V524T Televison makes a loud static pop everytime I try to turn on.The green light will come on and the TV will make a clicking sound like it turned on but there is no picture.
Look on the rear of the set and find out what chassis in your set.
Posted on Aug 30, 2007
SOURCE:
Toshiba TP50G90, makes a loud popping sound then shuts off. red light flashes
it sounds like its over heating.clean all the fans ,put new artic paste on the cpu
Jan 25, 2018 | Toshiba TP50G90 50" Rear Projection...
RCA Television Model 32V524t
there is a huge posibility that the electricity wasnt stable and burned your tv... ill try to find a way so you can check if it got burned...
by the way.. how old is the tv?
and when you mean blank.. blank as in black.. right?
does it shows any kind of signs of being on when you turn it on? like lighting up a led?
Jan 18, 2008 | Televison & Video
We own a Sony FWD-50PX2 television. A few weeks ago it would not turn on. The power is going to the television. When you try to turn the tv on you can hear it pop and the red light showing it is off...
this is a common issue i think. below steps solved this issue for an user.
-Press power off or leave with standby light on for 5 minutes (wait the full 5 minutes)
-Unplug TV / Press top buttons 5 times each to remove static from system boards (yes, each button 5 times each)
-Wait one full minute and plug TV in and press power on
Jun 23, 2017 | Sony FWD50PX2/S 50 in. Plasma Television
Loud static noise without warning
The audio may be randomly disconnecting or something. I know that when my TV has no signal coming in, that it makes a bunch of loud static.
Jun 04, 2010 | Tatung V20KQDX 20.1 in. LCD Television
My RCA television quit all of a sudden and now the power button is flashing green and won't turn on.
Your tv has a power supply fault, take it to repair shop and have it repaired
ask the technician to check the following components
semi conductors around the supply section, also ask him to check the (ht) high tension voltage which triggers a line transformer which in turn gives small outputs voltages to power the tv.
okay
Jan 03, 2010 | RCA 32V524T TV
Tv wont turn on, red flashing light
FLYBACK & HORIZONAL OUTPUT SHORTED
Apr 11, 2009 | RCA 32V524T TV
Plasma tv makes loud static noise screen goes blank and shuts off
Take the back off and try to isolate where the sound is coming from.
Nov 24, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
Problem with RCA TV Model 27F634T
You almost certainly have a bad picture tube. The green screen was from one of the elements inside shorting out. The static sound you're hearing is the high voltage arcing out through the end of the picture tube to other parts inside the set. It's more economical to buy a new TV than to repair this one.
Sorry to have such good news, but this is one of the ways a picture tube can go bad, and it happens quite often.
Mar 11, 2009 | RCA 27F634T TV
SAME PROBLEM-ELEC POP SOUND B-4 GOING OUT
check this thread
http://www.fixya.com/ThreadView.aspx?thid=381581&prdid=516316&type=click&mailid=9&rnd=0.512368791975253
May 12, 2008 | RCA 32V524T TV
RCA 32V524T- Blown fuse?
If you blew the fuse, the TV would do absolutely nothing - no lights, no sounds, nothing. It could be that the loud zapping noise you heard was the high voltage transformer arcing or shorting out. This could have caused the horizontal output transistor to short, and the set will not start as a result. You should have the set serviced by a qualified tech.
Sep 01, 2007 | RCA 32V524T TV
RCA 32V550T 32" TV Logo
128 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
