Question about Acer Aspire 5315-2153 Notebook
All numeric keys not working - Acer Aspire 5315-2153 Notebook
  • Acer Master
  • 15,557 Answers
Check the settings in the BIOS to see if they are disabled. If the are not, use a portable keyboard to see if the number keys work. If they do, check the device manager to see what the keyboard is listed as. You can delete it from the list and have it redetected. IF that does not work, OEM says that you restore the computer to factory settings. If that fails then you replace the keyboard.
Posted on Jul 29, 2013
My numeric keypad has stopped working, including all of the keys around the numeric keys, the number lock is on. What do you suggest?
Have you tried booting up in safe mode to see if it does the same thing? Also check your keyboard to see if there is some type of key combination that locks or unlocks the numeric keypad. If so, usually you will have to hit the FN key or the ALT key or the CTRL key plus some other key to get it to toggle.
Mar 31, 2012 | Computers & Internet
My numeric keyboard is not working, the num lock is on.
Mar 31, 2012 | Toshiba Computers & Internet
I need the reset code for a kenwood kdc-mp342u
Your code number is XXXX (KCAR)
* Press numeric key "5" ( 2 times ) and press the Track UP/Next Track key
* Press numeric key "2" ( 3 times ) and press the Track UP/Next Track key
* Press numeric key "2" ( 1 time ) and press the Track UP/Next Track key
* Press numeric key "7" ( 2 times ) and press the Track UP/Next Track key
i am also pretty certain that you will need to use the remote control to input your code.
If this master reset does not work, the unit will need to be sent to kenwood with proof of purchase for them to reset it. ................... in saying that I am yet to hear of this procedure not working.
hope i helped, and please dont forget to rate my solution. :-)
cheers
Jan 15, 2011 | Kenwood KDC-MP342U Car CD Player
I NEED A MANUAL TO SHOW HOW TO GET MULTIFUNCTION KEYS TO WORK. FOR EXAMPLE HOW DO I GET THE ALTERNATE USE OF THE "NUMERIC 6 "KEY ie THE" QUESTION MARK" FUNCTION
You must have a different keyboard selected other than the standard US keyboard My numeral 6 has ^ on it and the numeric keypad 6 has a right arrow. One generally uses the SHIFT key to access symbols that are written above the main alpha or numeric key. The numeric keypad on side of PC has a button labeled key marked NUMLOCK that is engaged to allow use of the numerals as a calculator or to also be inserted into text.
Please rate my help++++Thanks for using FIXYA
May 09, 2010 | Acer NSK8458AN Keyboard
Numeric keys not workin g
The key in the top-left of the numeric-pad enables/disables the numeric keypad. Press it once, to make the keypad function as a numeric-pad.
Dec 11, 2009 | Logitech MX5500 Keyboard/Mouse
Cant get the at button to work even by pressing shift or not,every other key function works.
You may have a bad key, or a key with something under it.
Try this:
Turn the netbook upside down so that the keysj face the floor.
Bang on the back side that way you would to burp a baby.
Then, take a vacuum cleaner and **** out the spaces between the keys.
If this doesn't work, you may have to make an @ symbol manually by using the ALT key. (ALT plus 64). This should work in most Word Processing programs.
  1. Make certain that the Num Lock key has been pressed to activate the numeric key section of the keyboard.
  2. Depress the Alt key.
  3. While the Alt key is depressed, type the proper sequence of numbers (on the numeric keypad) of the ALT code from the table above.
  4. Release the Alt key, and the character will appear.
  5. On a laptop computer, there usually is no numeric keypad. So, instead, depress the Fn (function) key, then the Alt key, then the numerical code sequence. The numbers are on the fronts of certain keyboard keys: M=0, J=1, K=2, L=3, U=4, I=5, O=6, 7=7, 8=8, and 9=9.
http://www.tedmontgomery.com/tutorial/altchrc.html
Nov 13, 2009 | Acer Aspire One AOA110-1113 Netbook
Keyboard letters 'm,j,k,l,u,i,o' permanantly locked for numerals. i have no idea how i switched this function on.
NumLock is on. Look for the Fn key in the lower left corner, and lookint in the top right, the NumLock key.
Mar 22, 2009 | HP 2133 Notebook PC
Cd code on radio kenwood
You need the remote control to clear the code, if you don't have one, then you may need to go to a KENWOOD agent, or purchase one for your use.
KENWOOD SECURITY CODE CLEAR procedure Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
The security is canceled and the set enters the TUNER mode!
Please rate ne FixYa for this solution. Good Luck :)
Jan 30, 2008 | Kenwood KDC-MP4028 CD Player
Acer Aspire 5315-2153 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
