Question about Refrigerators
How to replace thermostat in diplomat apm 6724 fridge
Have a diplomat apm 6842 how do you defrost freezer
the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS .
Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
Mar 23, 2015 | Refrigerators
How to change a light bulb in a diplomat fridge
I Googled Diplomat Fridge light bulb and came up with this: Copy www.youtube.com/watch?v=U-yyPGlRoZ0. Go down the page until you come to a video called "How to replace a fridge light bulb". It is there, you have to look.
Jan 02, 2015 | Refrigerators
Diplomat washing machine
Try Sliding the Soap Dispenser Drawer Lock to the RIGHT and then pull straight back... It is located under the handle
Mar 03, 2014 | Washing Machines
DIPLOMAT APP6302 FRIDGE
The no frost fridge has a compartment that collects the water while it keeps defrosting on a time cycle. I presume that the tray is clogged and full. you will need to access the rear to see to this. Also try to reduce the cooling on the thermostat, reduce the times you are keeping the door open. all of his will only create more frost into the coils to be defrosted. Please also see that the cooling/blowing fans in the freezer are not blocked, allow space for the air flow. Helpful I guess. Good day
Jun 30, 2010 | Refrigerators
I have a 1985 Dodge Diplomat and I replaced the thermostat and still no heat the A/C works fine
Check your heater control valve. It is vacuum operated. your heater hoses conect to it.
Jan 14, 2010 | 1985 Dodge Diplomat
Diplomat washer drier
all you have to do is:
select half load
set drier timer to required time. set main timer to dry program
i suspect you are not pressing half load button - this is essential
Jul 20, 2008 | Washing Machines
I have a Diplomat APM 8702 integrated washer / dryer, it has decided to stop working! its been great but does get used alot, the electrics come on, ive checked all the connections inside the machine made...
I have one of these machines. I don't know whether this will be of any help but I had issues of the machine not activating a final spin and the clothes being left sodden once the cycle had finished. The engineer replaced the PCB module at the rear of the unit which fixed the problem. If your APM 8702 is not even starting I'd guess its a motor problem and time for an expensive repair or new washing machine.
Apr 26, 2008 | Washing Machines
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
