Question about LG LRTBC1825T Top Freezer Refrigerator
GL83220M Water collection on floor frequently
    New Friend:
  • 41 Answers
Check if drain pipe is not blocked and check if it is aligned with the with the drip tray which can be found on top of the refrigerator motor.
Posted on Jul 29, 2013
2002 Tribute water collecting on floor of cabin passenger side
SOUNDS LIKE YOUR A/C EVAPORATOR DRAIN IS PLUGGED. WHEN YOUR DRIVING THE EVAPORATOR WILL COLLECT CONDENSATION AND THEN DRIP OUT OF THE DRAIN. THE DRAIN IS LOCATED NEAR THE FIREWALL ON THE PASSENGER SIDE OF THE VEHICLE. SOMETIMES LEAVES OR MOLD/MILDEW WILL COLLECT THERE SIMPLY SHOVING A COAT HANGER END OR SCREWDRIVER WILL UN CLOG IT AND ALLOW THE WATER TO DRAIN.
Jun 26, 2012 | 2002 Mazda Tribute
The dehumidifier doesn't collect any water.
There are several things that can cause the problem:
1. The humidity extraction level is set to high. Lower it to 35%
2.The air intake filter is dirty and/or clogged. Remove the filter and clean it.
3. The cooling coils on the dehumidifier need cleaning.
4. Not enough clear air space all around the unit. Maintain at least a minimum of 12" air space all around the unit, while in operation.
5. The ambient air temperature at floor level is between 40 & 60 degrees F. This is particularly true, in basement applications. Raise the unit up off the floor onto something sturdy, that can maintain the weight (including a full bucket of water) and the vibration.
The above 5 things are the most frequent causes of your problem. Start your troubleshooting with these.
Hope this helps you solve the problem. Please let me know. Thanks.
Jun 06, 2011 | Kenmore Dehumidifiers
Passanger side floor is wet with water not antifreeze3 what can i do to stop this
Windshields can leak as the glue/sealant gets old and hard and cracks. The small area behind the hood and in front of the windshield collects run off and diverts it to a drain. The drain often gets plugged and the rainwater finds its way into the passenger compartment. If you have a sunroof, that is another place for leaks growing more frequent a the years pass. You just have to pull the flooring up and track the wet spot back to its source. Water generally leaves a trail of corrosion to follow.
Nov 18, 2010 | 1998 Jeep Cherokee 4WD
Collected water in evaporator pan does not
you obviously live in a high humidity area.(or you are putting warm/uncovered food inside) but the answer is yes,or you could collect the water to use on you indoor plants.........better than tap water...
Jul 08, 2010 | Frigidaire FRT18KB2CW Top Freezer...
Water on back seat floor
It could be caused by blocked sunroof drains. Thats where I'd look first.
Feb 18, 2010 | 2003 Volkswagen Passat
SubZero 550 Water keeps collecting at the bottom of the refrigerator, behind the vegetable bins. I see it leaking from the drain pipe and the handyman has tried to clamp the pipe, but not sure why so much...
your drain may be plugged... it will need to be clean and clear... it may freeze too it you have ice in it you will need to add a drain heater to keep it clear
Sep 11, 2009 | Sub-Zero 650 / O Bottom Freezer...
Overflow of condensation water
If you have a water filter the water will leak past the filter to the pan if it's clogged up and needs changing.
The defrost water drains to the pan, so if you are having a lot of frost it could fill it up. Excess frost can be caused by leaky door gaskets and frequent door openings.
The condenser fan near the pan should be running when the compressor runs to help evaporate the water in the pan.
Sep 09, 2009 | Haier HTE21WAAWW Top Freezer Refrigerator
Collecting water at bottom of frig inside under drawers.
begin by removing the grill on the front at floor level. look under there and you will see the evaporation pan. next pull the fridge out from the wall so you can get behind it. there you will see the tube. to unclog it you will have to disconnect it at the top and force hot water into it using a turkey baster.
Aug 22, 2009 | Refrigerators
Water collects under dryer. Clothes dry. floor wet. Vent open.
You said, Water collects under Clothes dry on floor.This sounds like a condenser dryer that needs the water retention bottle empdied or the hose to the bottle is leaking.
Check these two things
Huuum
Please leave a rating before you leave the site!
Feb 01, 2009 | Dryers
Water dripping outside the collector
I think that there is a 90 degree bend in the outlet on the bottom right front side of the collection tray that gets pluged with dirt, line etc. You can see this when you remove the collection container from the unit. I used a small piece of wire to clean out the hole and now the water goes into the tank and not onto the floor.
Aug 24, 2008 | LG LHD45EL Dehumidifier
LG LRTBC1825T Top Freezer Refrigerator Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
