Question about Orion1934 19" TV
Orion 1934A Last week we had a thunderstorm with some intense lightening, I have 2 of these TV's and both were turned off at the time but after the storm neither would work. I have them both connected to Dish network and the dish is working but the TV's won't turn on. Is there a fuse or something that could have been damaged when the power came back on? If so is it something I can fix myself by getting a new fuse?
    Genius:
  • 1,153 Answers
You can check for fuse and fusible resistor, also horizontal output maybe shorted
Posted on Sep 06, 2007
6ya staff
SOURCE:
Should I replace my lamp for my Panasonic 1080i htd t.v. pt-50LC14
Replacing a lamp won't work. There is not even one lamp in your TV. I'm afraid the lightening has done more damage than can be repaired. Even when some tech manages to repair te error, the TV can have the next error in days or weeks.
Try reading something about ESD. Electro Static Discharge and what it does to electronics. Electrostatic discharge
Apr 25, 2015 | Panasonic Televison & Video
How do I get picture back on TV which was working the night before, which is hooked up to HD cable box, thru HDMI?
OS info is always helpful, if say you are running some type of nix, it's likely not getting recognized by xserver or if your running some version of windows your display manager has shut it down because of a resolution mismatch.
May 26, 2014 | Amstron Fujitsu LifeBook E390 Laptop DC...
My Sharp Aquos LC-26D44E-GY in the spare room has stopped working. It worked ok about 2 weeks ago, went to switch it on last night & its dead. We had a thunder/lightening storm last week? Ive changed...
First check your power outlet, try connecting the TV to a different power outlet. Then see whether the LED light on the TV is on or blinking. Anyhow, this might need attention by a qualified service technician.
Jul 15, 2012 | Televison & Video
How to turn off close caption on Orion TV 1934A
Try unplugging your TV while it is on. This will cause the Factory Defaults to restore. When you turn it back on every thing should work normally again
Jul 22, 2009 | Televison & Video
HP6150 - won't turn on after the last thunderstorm. It's not a circuit breaker or GFCI problem. Power cord has a green light, which is on.
Lightening does hit power lines, and cause voltage spikes; these voltage spikes do burn out electronic equipment. Surge protectors are used to prevent these voltage spikes from burning out electronics
Jun 11, 2009 | HP Photosmart C6100 All-In-One Printer
Power problem with an LG 50PC3D Plasma 50" TV
YOU PROBALY HAVE A BAD Y SUSTAIN BOARD OR POWER SUPPLY. POWER NEEDS TO BE DISCONNECTED FROM THE Y SUSTAIN AND THE VA & VS VOLTAGES CHECKED.
Jul 29, 2008 | LG 50PX4DR 50 in. Plasma TV
32inch orion bad picture
Hii...
I'm absolutly have no idea whit thos tv set ( Orion ) but...your problem looks like mall function at the vertical circuits....can you see the ic or transistor nearst the FBT ? or you can type all the ic number/type and the Chassis of the tv set olso the Transistor around the Fly Back Transformer ?!
I hope it's can help you..
Hear from you soon
Thank's
[Vrya] [email protected]
Feb 23, 2008 | Orion1934 19" TV
Question for troylove11
If the set was off, your horizontal output transistor is most likely good. Some sets do not have fusible resistors and the ones that do usually never have problems with those resistors. With the set unplugged, carefully remove the back and follow the power cord to where it attaches to the main board. At that spot there should be a small glass fuse, usually sitting in 2 small fuse holders so that the fuse will pop right out. If that fuse is good and the set will not turn on, it means that there is a serious problem deeper in the set. If the fuse is bad, you can try replacing it with a fuse of the same rating. If the set works, great, but if the new fuse goes bad, there is a serious short somewhere in the power supply and the set should be serviced by a qualified tech.
Sep 06, 2007 | Orion1934 19" TV
Orion1934 19" TV Logo
133 people viewed this question
Top Orion Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
