Question about Acer X1160pz Digital Projector - Ey.j8801.021
My acer x116OPZ projector remote will not work at all
The remote (despite changing the battery) will not work at all
Remote stopped working for Sony, ceiling mounted, projector. Batteries changed.
Try calling 1-800-294-3889 or visit their website at: www.ElectronicAdventure.com to buy a new Sony projector remote.
Perhaps they'll even offer a suggestion or two that may help troubleshoot and fix your particular remote problem...I have no personal or financial interest in the aforementioned business- just trying to help and pass on good info.
I also attached a youtube video that offers a coupon code should you need to buy a new one.
Feb 20, 2015 | Office Equipment & Supplies
The beam light does not come up and the remote does not control the machine
try to change the battery in the remote control.... i think its CR2032.
Dec 11, 2013 | Acer X110P
I cannot get my remote to work with my Sanyo PLC-XE30 projector
I would first try changing the batteries in the remote and verifying that batteries are in the right direction (+ and - terminals line up).
Once that is done, try pointing the remote right at the infrared sensor at the front of the projector...the black plastic circle on the front of the projector.
Mar 04, 2011 | Sanyo PLC XU30 Multimedia Projector
Menu from Projector keeps popping up. it will clear away when we click MENU button but then within 5 seconds, it will pop up again. we are using ACER XD1150 DLP PROJECTOR. would appreciate any...
hi,
Check is the remote transmits signals for menu at any time.
to check this after clearing the menu remove the battery of the remote. if the menu didn't po pup again , the remote need cleaning .
If the menu pop up again then, you have to check the menu button (push button) on your projector.
ok
Feb 21, 2011 | Acer XD1150 DLP Projector
My remote control never worked
If your Remote desn't work then first check your battery and then try it again. After trying again if same thing happen then changes it and place new battery.
Nov 26, 2009 | Acer X1160Z Projector
Remote control that no longer works, ie. no response from the TV despite changing the batteries
You can get an IR remote tester at radio chack or frys. It's just a card that you point and shoot at with the remote. If you do not see red flashing on the card replace the remote . If you do then call serv shop. remote reciever is bad.
Apr 24, 2009 | Televison & Video
Optoma ep721 remote problem
return the projector (still under warranty, if bought new). if it's used, reset the settings on the projector to factory default. if still nothing, replace the remore.
Sep 24, 2008 | Christie 38-VIV211-01 LCD Projector
Remote control for HP mp2220 projector
possibly it the remote controls battery that needs to be changed
Mar 11, 2008 | HP mp2220 Multimedia Projector
Acer X1160pz Digital Projector - Ey.j8801.021 Logo
16 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
