Question about Cat5e Computers & Internet
Cable stuck i can't seem to get the lan cable out of the hub
    Problem Solver:
  • 30 Answers
Look at the above left. There should be a plastic lever (with a little nose to hold the plug in) reaching a few millimeters out of the front panel of your hub. Press it to the body of the plug and pull it out. If the lever is broken, use a small screwdriver, a needle or a paper-clip.
hth, Karl
Posted on Nov 27, 2014
I cant connect laptop with ethernet cable
I assume the LAN adapter driver is installed and is working properly.
The LAN cable maybe faulty.
If the LAN cable is colored red then it is a crossover LAN cable and this is a special LAN cable for connecting two computers together without a network hub or router.
Try a another LAN cable..
May 13, 2012 | ASUS Computers & Internet
Belkin F5U307 Hub suddenly doesnot work on my Macbook
The lights (link light) on the hub indicate the LAN cable from the computer to the hub is connected and working.Disconnect the cable fron the hub and the computer then connect the Lan cable to the computer first and the other end of the LAN cable to the hub anf the link light for that LAN port on the hub should light up. If not the LAN cable could be faulty then try a different LAN cable.
NEXT
Try turning off the power to the hub for 30 secs, reconnect the power and check the LED lights. If this does not fix the problem then it appears the hub is faulty.
Apr 20, 2012 | Apple Computers & Internet
Wanna connect mulitple computers to my Printer
Yes, you can definitely share one printer to multiple computers. All you need to have is a ethernet hub or some call it network hub and Cat5 cable. Ethernet Hub is a simple, small and inexpensive gadget to connect multiple computers together.For the Cat5 cable is popularly known as LAN cable. For you to share your printer, connect it on a ethernet hub as well as your computers using a Cat5 cable. Once everything is connected to the Ethernet hub fix the network and that's it. Everyone that is on the network can use the printer.
I hope I answered your question.
Thanks a lot!
Jul 25, 2011 | Ricoh Aficio GX3050N All-In-One Printer
I am connected from the service provider to a linksys hub and then I connected a cable to the wireless router Dlink -601. I do have internet wireless in the house but I CANNOT connect myself to the hub by...
Improve the Fixya.com experience for everyone by voting!
The solution I'm suggesting works in my business (LAN installations) about 95% of the time. I trust that it will work for you.
Let's see if I can help you.
Begin by turning on your computer and your router
? Open Internet Explorer;
? Click on 'Tools';
? Click on 'Internet Options';
? Click on 'Connections';
? Click on 'Setup'
? Click on 'I want to set up my Internet connections manually . . .';
? Click on 'Next';
? Click on 'I connect through a local area network (LAN);
? Clock on 'Next'
? Click on 'Next' [This is not an error];
? Click on 'No';
? Click on 'Next';
? Click on 'To connect to the Internet immediately . . .; and,
? Click on 'Finish'.
That should have you online
All the best
Ben
May 29, 2011 | D-Link DIR-600 Router
Reconecting the cables to the hub does not make a network
Not necessarily! As long as a lan cable is connected on the wan port of your hub and the other end goes directly to the modem, the connection is correct. The remaining port will be left for the lan cables of the computers. No orders needed. Just make sure that lan cables was properly seated on the port. The LED blinking in the hub will tell you if its working or communicating with your computer. Find it, when the LED is not lit or blinking, the lan cable is not connected properly on the hub (or the other end of the lan cable is disconnected from the lan card of the computers).
If all cables are connected properly and still cannot connect to the network, you may need to refresh the name of the workgroup on the computers that cannot connect on the network,
How? Right click on My Computer.
Select Computer Name
Click Change to change the name of the workgroup that is being use by other computer. Delete the old name if the same and retype.
Restart the computer and try to connect using network neighborhood.
Jul 07, 2010 | D-Link DSH 16 (DSH-16) Networking Hub
Cannot view my client in handycafe
Check if the LAN cables are connected properly, make sure that client PC's have handycafe client installed and connected to the hub/switch with the server PC.
In some cases wherein the server has two LAN Cards installed, make sure to choose the LAN Card which is connected to the hub/switch where the client PC's are also connected during the initial start-up of the Handycafe software.
Note: Check if the hub/switch or router (whichever you're using) does not have a problem.
Nov 05, 2009 | Computers & Internet
Hello need help in config a wsg-404 ap and then connecting another ap via ethernet cable from the wsg-404 to the other ap cant seem to get it working right
If you are trying to network two computers together without a hub, then you must use a crossover LAN cable, not the standard LAN cable.
Aug 09, 2009 | Computers & Internet
Genius LAN 16 Port Hub Dropping connections intermittently
Col probably means Collisions. There are probably collisions going on on your LAN. Collisions can happen when there are two adapters with the same IP address or when there's a bad cable. My suggestion is that you make sure that you have unique IP addresses and that you don't have any bad cables - cable tester comes in handy.
Mar 27, 2009 | Computers & Internet
Lan cable Setting for Switch & PC to PC LAN Connection.
If you are asking about connecting two computers together with a hub or switch, plug them into the switch/hub with standard patch cables (cat 5e or cat 6).
If you are asking about connecting two computers together directly using a LAN cable, then you will need a "Crossover" cable (cat 5e) wired specially (oranges transposed at one end for the common -B pattern) for direct LAN connection.
Jan 01, 2009 | Computers & Internet
Computers & Internet Logo
164 people viewed this question
Top Cat5e Computers & Internet Experts
KG John Justin
KG John Justin
Vuk B
Rishi Solutions
Rishi Solutions
Are you a Cat5e Computer and Internet Expert? Answer questions, earn points and help others
