Oce tds 450 scanner error 10508-54664
Hello! When connecting the scanner to the controller, on the display scanner is appear the code: 10508-54664. Thank you!
    New Friend:
  • 43 Answers
Or you can ask the 24 hrs live technical support, they will like to help you, good luck http://www.diyobd2.fr/service/
Posted on Sep 05, 2013
SOURCE: Oce TDS 400 Printer. Erore Prob.
erore
Posted on Aug 25, 2008
SOURCE: OCE TDS600 Error Codes
It might need a new fuse which is located where the hot wires are when the paper feeds through or it might need a circuit an Ormon G3NE-220 TL-US load 20A 240VAC 50/60hz input 24 VDC.
Posted on Aug 31, 2009
  • 990 Answers
SOURCE: Error code E020 0181 on oce cs115 how do we remove the code
Hello sir; Try to replace yellow color developer and then running"stir" or "install". should removed the error code.
Posted on Oct 10, 2009
  • 212 Answers
SOURCE: MY OCE TDS 400 PRINTER
damage of toflon of printer
Posted on Mar 11, 2011
lukebeeee
SOURCE: oce tds 600 Error code 15504 machine stopped in
There seems to be a feed problem. I googled the error 15504 for the Oce printer and got this page. We did this (see photo) and that seemed to sort the problem out for the meantime (until service guy gets here). I dare say it's a sensor somewhere. So jam a roll of cardboard from a used roll in behind the roller (as in the photo) and that does the trick. Hopefully this works for anyone else with the problem.
Posted on Sep 06, 2012
What does error code 0820 on Oce TDS 100 stand for?
NTC Middle right of the fuser assembly. The NTC must be replaced. These are ceramic encased thermistors. Very expensive and easy to break. I recommend calling an authorized Oce technician.
Mar 22, 2018 | OCE Office Equipment & Supplies
Oce TDS 300 Printer. Erore Prob. Hi I have a printer Oce TDS 300, I Get A new Erore code 8507,i want A Solution
Turn off the printer, and let it cool for an hour. The problem will return, but you may have the ability to get some emergency plots out in the mean time. The error code has to do with a thermistor in the fuser section. These thermistors are made out of a delicate ceramic and are easily broken or cracked if installed incorrectly. I would recommend that you call an authorized Oce/Canon service representative unless you want to spend several hundred dollars on incorrect, or broken thermistors you may get via other official channels. Each Oce model may have a different rating of thermistor, so just putting any thermistor in most likely will not solve your problem and may cause others.
Mar 10, 2017 | OCE Office Equipment & Supplies
Oce TDS 300 Printer. Erore Prob. Hi I have a printer Oce TDS 300, I Get A new Erore code 8505,i want A Solution
The NTC 2 is probably shot. These are ceramic coated thermistors and extremely fragile. I would recommend calling an authorized Oce technician to get this replaced.
Oce tds error code 12502
Error 12501, Error 12502, Error 12503, Error 12504, Error 12505, Error 12506, Error 12507, Error 12508, Error, 12509, Error 12510, Error 12511, Error 12512, Error 12513, Error 12514, Error 12515
Error codes related to External Paper Input Module
Oce VarioPrint 110
Oce VarioPrint 120
Oce VarioPrint 135
Apr 28, 2014 | Office Equipment & Supplies
Oce tds 750 error code 08008
Hello, i got TDS 750 from Oc? and the error code is 08010.
Thinks for your help.
Oct 23, 2013 | Office Equipment & Supplies
Oce tds 600 error code 08005
you can see you'r answer here:
http://www.copytechnet.com/forums/other-copier-brands/90112-oce-tds-600-08005-error-code.html
Sep 01, 2013 | Office Equipment & Supplies
Oce TDS 600 scanner error code 10501
Clean mirror and scanner glass. Be extremely careful cleaning the mirror. Its a First Surface Mirror and extremely expensive.
May 22, 2012 | OCE Office Equipment & Supplies
the heater stays cold during run,heater bad or false contac or ssr defect
error 10501
May 22, 2012 | Office Equipment & Supplies
227 people viewed this question
k24674
jasbo
jasbo
