Question about Electrolux Washing Machines
Wiring diagram washing machine
The door isn open and the heater is not respond
  • Official Brand Answer
  • 4,342 Answers
Hello Muhammad, I am happy to assist you; however I'm not certain I understand your question. Are you referring to the door isn't closed and the dryer continues to run? Or that the door isn't closing and the unit does not heat? With this information I can better address the issue at hand. Thank you and I look forward to your response.
Posted on Jul 29, 2013
4 Suggested Answers
  • 3600 Answers
SOURCE: Washing machine front loading door won't open.
that is the way it's made you have to turn it off before you can open it or water would go every where.
Posted on Aug 20, 2009
greg_margo
  • 1959 Answers
SOURCE: my washing machine says door opened even i closed the door it' always says opened
Sounds like a sticky or broken lid switch. Over time, detergent and dirt can settle in and around the switch, causing it to stick or disabling it altogether. Try pushing the switch in manually to see if the door open warning goes out.
Posted on Oct 31, 2011
emissionwiz
  • 79847 Answers
SOURCE: front loader washing machine door won't open
try unplugging the machine to reset it.
Posted on Feb 28, 2012
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
Washing machine has detected an overfill situation
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
Sep 30, 2016 | Samsung Washing Machines
I have E64 error code and door remains locked
Heater Open Circuit. Heating element or wiring defective
Check heater coils and connections for open circuits. Replace heater and/or wiring
Jul 13, 2015 | EdgeStar 2.0 Cu. Ft. Ventless Washer Dryer...
Hotpoint fdw60 4th & 6th lights flashing
These two lights indicate a fault in the heating circuit.
You would require to have access to and be able to use a multimeter to test the heater if the machine isn't actually heating the water.
If it is heating the water then obviously we know the fault isn't with the heater.
Check the heater first.
Take the door apart and check the wiring in the door isn't broken.
If everything checks ok, take the pcb out, look for burned or dry joints around the relays.
Nov 05, 2012 | Washing Machines
Door will not open on hotpoint bwd 129 catch may be broken
Your door lock assembly needs to be replaced to open the door try the following procedure.
To open the door, get a piece of string and feed it into the door recess, work it around until both ends come out opposite the door handle.
Pull the string to the side and with your other hand pull the door open.
You will need to get a replacement lock assembly for the machine which isn't too hard to fit if you are a bit handy with tools.
Mar 07, 2012 | Hotpoint Washing Machines
My heater is not getting hot
Hello! There are only a few reasons for this awful event to occur in early December...Either Hot water isn't circulating through the heater core, the thermostat isn't opening or the door that directs heat is faulty...Is the temperature gauge showing normal? Next, is the upper radiator hose hot and hard? If the last two answers are yes then hot water is circulating...The unit that controls the doors ...ie...heat or defrost is called an Actuator...Also the lever that opens the heater may be at fault....LETS ELIMINATE...
Is there defroster heat? If no the heater core isn't opening ..If yes then the actuator is the culprit...You can check the heater by feeling of each of the two hoses that come through the firewall into the inside...If they are both hot then the heater core is open and functioning...If one is cold the heater isn't being opened by the temperature control..Or it is simply blocked with gunk....It's a 99 and getting old...I would suspect that IF the upper radiator hose is hot and hard and the temperature gauge is normal all is well with with most components and the next step is; Are both heater hoses hot...Your going to have to narrow this down for me to pinpoint the cause...See diagram below of the door actuator allowing defrost heat to be sent to the heater floor duct...
Send a comment with results and or observations...Remember"your my eyes and my hands"...Guru ...Saailer
Dec 02, 2011 | 1999 Dodge Durango
Miele novotronic wt 945 door release button not responding wash functions not responding when turned on and off only drier light is on no actual response from drier section cannot open the machine Is this...
Open the door manually.
Open the drain flap on front left bottom
The door release can be seen hanging, pull the cord, the door will open.
Close and open the door 2 or 3 times and your machine will work ok.
S. Datta
Bickley
Mar 06, 2011 | Miele WT945 Front Load Washer / Dryer
Miele premier novo, the main wash light flashing
Hi
Main wash is a fault indicator. The is a problem within the heater circuit, NTC, element, relay or loose wire. You will have to open front and check.
Remove 3 screw around dispenser and 3 10mm bolt around door. disconnect hose by drain pump and front of machine will open like a door.
Apr 01, 2010 | Miele Novotronic Premier 500 Front Load...
The water isn't getting hot
If the water to your kitchen tap is above 120 to around 145 your machine is getting hot water. If not your need to adjust your hot water heater.
It is fine to open the DW door during the wash cycle. The unit will hold the wash cycle. Open the door during the start of the wash cycle (not rinse) and see it the dispenser door is open. If not it could be the timer is not sending the proper signal to the dispenser on when to open. This would be a timer issue and you would want to replace the timer. I doubt that this is it but it is possible.
Hope this helps.
Mar 22, 2010 | GE Dishwashers
Can't open the door timers saver & 1200 spin lights flash
There is a known problem with these washers whereby a small electrical current 'leak' from the heater element causes the machine to think it still has water in it.
Disconnect the wires on the heater (tape them up or otherwise make safe) then run a cycle to verify that part as the problem.
Jan 31, 2018 | Hoover H130E Front Load Washer
Washing Machines Logo
82 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
