Brady wraptor my wraptor isn't receiving the print files im printing from computer via usb
oldnovii
  • 667 Answers
SOURCE: Lexmark x4580 connected via USB
1) Disable both firewalls and see if it prints.
2) If it prints, then it's a firewall roblem. Enable your Windows firewall first. If your printer works just leave the McAfee firewall disabled. You don't need both anyway but leave the ant-virus enabled.
3) If it doesn't print with your Windows firewall enabled, try it the other way. Windows firewall disabled, McAfee enabled.
4) If it doesn't print in any of these cases try re-installing the software for your printer.You will want to make sure that McAfee is totally disabled (anti-virus and firewall) and turn off off your Windows firewall. Here are the steps for re-installing software. If you don't have the cd let me know and I'll provide you with a link for it.
Removing and reinstalling the software
If the printer is not functioning properly, or if a communications error message appears when you try to use the
printer, you may need to remove and reinstall the printer software.
1 Click Start �� Programs or All Programs �� Lexmark 3500-4500 Series.
2 Select Uninstall.
3 Follow the instructions on the computer screen to remove the printer software.
4 Restart the computer before reinstalling the printer software.
5 Click Cancel on all New Hardware Found screens.
6 Insert the CD, and then follow the instructions on the computer screen to reinstall the software.
Note: If the install screen does not appear automatically after you restart your computer, click Start �� Run, and
then type D:\setup, where D is the letter of your CD-ROM drive.
If this fixes your problem please rate this as fixed. If it doesn't and you need more help just add a comment and I'll be glad to help you out' I'll be waiting to see how it turns out. Thanks.
Posted on Apr 10, 2008
Kurth
  • 86 Answers
SOURCE: using kyocera to computer
Check if you have documents qued for printing
If so delete all, then retry. unplug printer and turn it off also remove usb cable, restart PC then plug all back in. Re isntall printer then try again. Should workl
Posted on Aug 16, 2008
  • 239 Answers
SOURCE: canon mp460 wireless printing
you need to in stall the drivers on your computer for the printer. and make sure you phone is not connected to the printer at the time you are trying to use it with your computer as this can cause problems to.
Posted on Mar 01, 2009
  • 18 Answers
SOURCE: canon bjc 50 printer
Purchase a PCMCIA parallel port adapter. the USB to parallel adapters are a pain to set up and are flakey at best. The PC card adapter provides a native parallel port to laptops without one, and works perfectly in ALL cases, even with the scanner cartridge. In Vista, the printer may then be manually installed from its list of printers, and set to use the new LPT port.
Posted on Aug 20, 2009
SOURCE: Printing from MS Excel 2003 to MX860, ''print to file'' box pops up
Anybody find an answer to this problem? Windows 7 same problem Excel 2003??
Posted on Feb 21, 2010
Print preview looks fine but just get a blank label from label mark. prints ok when not done from pc
You likely need to use Brady's software to create the label on the PC, and your PC will need the correct printer drivers to communicate with the Brady. The software and drivers should be available from Brady.
Apr 02, 2015 | Brady TLS 2200 Label Printer
Memory overflow
try printing a different file format. is teh printer connmected via network or USB? connect either way and see
Apr 09, 2013 | Oki Brand Oki 62435103 C330dn Laser...
HP LaserJet 2430 Printer Will Not Print since USB Power Surge Error
INSUFFICIENT POWER - USB PORT
If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Feb 19, 2013 | HP LaserJet Office Equipment & Supplies
Unable to print labels
Turn off the printer and open the printer back door. Use a spot light and give look inside properly. Make sure there no paper. Some time small part of the paper creates the problem. So you can do one thing after open the back door, top side etc make the printer upside down etc. So if anything inside that's will come out. After cleaning again connect it with PC and turn on. Now give a look. If you face same problem then Un-install the printer driver and software from the PC. Then restart the PC and Printer both. Now connect the Printer with PC via USB and install again the driver & software. Then try to print and let me know the result.
Aug 09, 2012 | Brady TLS2200 Thermal Label Printer
Hi. I have a wildfire s and want to print photos using a USB connected straight to my printer put the option just doesn't seem to be there when they are connected. Can anyone please help?
There is no way you can do that. It does not have usb host mode. What you can do is connect via usb to your computer, select disk mode and browse for the files (usually in DCIM folder) and print them using the default image managing sw on your computer.
Feb 23, 2012 | HTC Cell Phones
Hi - My Brady IDPAL says it is printing, but nothing actually prints... silence. I was reading about the "insert labels" contact issue. It not that.
Hello, this is a response from Brady's technical support team. Please try this:
The three contact pins in the printer are not making contact with the smart cell computer chip (the shiny silver pad at the bottom of each cartridge). The occurs after the printer is dropped or after shoving
cartridges in at an angle.
To remedy, remove the cartridge and look at the bottom of the cartridge opening (just above the Power button). Take tweezers or needle nose pliers and pull slightly on the pins (outward, and towards you). Please double-click and View the file below for a picture of the pins. Once these metal contacts are out far enough to make contact with the smart cell (computer chip) on the label/ribbon cartridge, the printer will know that labels are loaded.
In addition to the Insert Labels error, contacts that get pushed in can result in two other issues:
One, the printer will only print if the cartridge is pushed down
(which makes the smart cell touch the contacts).
Two, if one or two, but not all three, contacts are not all the way out, the printer may only print on half of the labels (because it is only reading some of the silver bars on the cartridge's computer chip, and narrow media activates only one or two bars, where as wide
media activates all three).
We'd be happy to help you directly if needed. Brady Technical Support at 1-800-643-8766 ortech_support@bradycorp.com. Please leave your name, and phone number or email address, if you are unable to speak to someone. Our Technical Support business hours are Monday through Friday, 6:30am to 6:30pm US Central Time.
Jun 15, 2011 | Brady ID PAL Thermal Label Printer
My Brady LabPal label printer seems to be printing labels that are not very bold and, in fact, the numbers are often only half printed. Do I need to change the ink cartridge within it, or what is the...
I have label cartridge in but it doesn't print, just says "insert labels". I have tried many times to take cartridge out, and reinsert, but it won't do anything.
Jul 01, 2010 | Brady LAB PAL Thermal Label Printer
I have a Brady ID PAL label maker, I was printing labels and the printer stopped working< I thought it was because the cartridge was low so I replaced the cartridge and it still does nothing, I can hear...
I had the same problem. I opened up the unit and found that the small drive gear had lifted up on the shaft and was no longer engaging the other gear. I could have probably noticed this from the battery compartment. I pushed it back down and now the unit works fine.
Mar 10, 2010 | Brady ID PAL Thermal Label Printer
My Design Jet 1050c does not like to print PDF's. It says receiving low memory right now and is taking an extremely long time
Two questions:
1. How large is the PDF file and is saved on your local hard drive?
2. How is the plotter connected to your computer? Network or directly connected via parallel or USB?
Try changing how the printer processes the print job.
On the driver properties / preferences, select the Advanced tab and change the Process Document to "in computer" and then try printing again.
Aug 06, 2009 | HP DesignJet 1050c plus InkJet Printer
WILL NOT PRINT LABLES
Maybe you have the type of file blocked on your printer/computer. If not im not sure what the problem is..
Mar 08, 2008 | Brother HL 5140 Laser Printer
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
