My Panasonic inverter cs-12hkr heat pump has stop working I went to check and it come up with code h 11 the timer light is flashing red and it not working at all
Plz e9 solution onida
Posted on Jul 29, 2013
  • jess Jul 29, 2013
    What dose that mean ??
5 Suggested Answers
bobotfel
  • 236 Answers
SOURCE: flashing lights on system
Maybe the unit is on test run, try to push the test run button of remote control pointing the remote to the unit receiver.6d9792c.jpg
Posted on Jan 07, 2008
  • 86 Answers
SOURCE: Panasonic split system air con cs/cu-e24gkr
check the indoor unit sirkit board,there is problem.
Posted on Mar 15, 2008
SOURCE: Fujitsu inverter ASTA24LCC aircon wont
Check that the gas is not leaking, that would be the most likely cause.
Posted on Jun 17, 2008
SOURCE: i have a Fujitsu ASTA24LCC
Check your filters. Manual says they need to be cleaned every two weeks under normal operation (and in my case more often during renovations). It seems it may not take much to limit air flow enough for the indoor unit to trip out. Hope this helps.
Posted on Aug 24, 2008
Panasonic microwave convection oven model NN-CD997S works normal but stop heating
Judging from the model and without looking it up I expect that unit has an inverter. If it is not the Switches and you have replaced the mag, the inverter is the power supply for the mag to work so either mag not getting power from inverter or inverter not getting signals from main PCB Timer board.
Jul 03, 2017 | Panasonic Microwave Ovens
Model CS-E12NKR. What does error code F99 indicate?
Outdoor Direct Current (DC) peak detection
7 times occurrence continuously
Check: • Outdoor PCB
• IPM (Power transistor)
• Compressor
Chances are that the outdoor board has gone. You need a megger to check the compressor first before buying a new board.
Nov 13, 2015 | Panasonic Heating & Cooling
Timer blinking.outdoor unit does not functioning. what was the error?
Looks like you said it, the outdoor unit is not working. Check for power to the outdoor unit or try cutting power to it, then after a minute restore power in attempt to reset it.
Apr 28, 2015 | Panasonic CU-E18JKK-1/CS-E18JKKW-1 Wall...
Panasonic fault codes
h14 is indoor intake air temperature sensor
try turning power off for over 1 min, and restarting
Jul 12, 2014 | Panasonic Heating & Cooling
Panasonic heat pump timer light flashes
check if it is poor contact .or current is too small.
wall light
May 20, 2012 | Panasonic CU-E18JKK-1/CS-E18JKKW-1 Wall...
Fujitsu inverter air cond. Just stopped working properly. Model outdoor AOT30PMAL indoor unit AST30PBA-W. Code oper. Red led flashes fast continously green led (timer) repeats 13 slow flashes. After power...
It sounds like your inverter is at fault. You will need an inverter tester ( most good service techs will have one ) to prove that the output to the compressor is correct. If the inverter is okay then it will be the compressor at fault with a location error or it is simply seized. A common fault that caused this was the eev remained closed (coil failure ) and caused the compressor to over heat.
May 11, 2010 | Heating & Cooling
Panasonic air conditioner CS-E24GKR...The unit stops and the timer indicator blinks. Also displays error code H 11...Help...Please...its hot in here
H-11Indoor / outdoor abnormal communication. Check • Internal / external cable connections
• Indoor / Outdoor PCB
Jan 04, 2010 | Panasonic CS-A12C Air Conditioner
Panasonic Inverter CS-E12EKU timer indicator blink. The unit not work at all, I follow the manual instructions using the remote control but the instructions are not clear. Using other similar Panasonic...
Today I install a new unit Panasonic CS-S13KKP also have a same problem timer blink and the outdoor unit wont start. Error code is 11. after checking the problem, can not using a 3 cable cord, solve the problem using 4 Cable cord and its run !
Victor
Aug 21, 2009 | Panasonic Heating & Cooling
I've got a pana inverter CS-E24FKR, and the timer icon is blinking. I have not set a timer and i can not get the unit to respond. I tried holding the "check" button down for 5 seconds, then...
I had the same problem with a Panasonic Inverter mini split model cs-e12eku and i had to turn it off using the main power breaker switch. ( I could never get the darn error code.) I left it off for a couple of minutes and it seems to reset. My uncle is in the ac business and he has heard from other ac techs that the Panasonic ac's are problematic, sounds like it might be true...I suspect that the time, my unit worked perfectly for from 11/06 to June 08 and living in the tropics I used it every day I havent called Panasonic but it sounds like a faulty circuit board.
Jun 03, 2008 | Heating & Cooling
Heating & Cooling Logo
159 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
