Question about HEWLETT-PACKARD T790 InkJet Plotter Printer
Yellow & Magenta not printing
Yellow & Magenta colors are not printed in papers in my hp t790 plotter. Can any one help please
  • HEWLETT-PACKARD Master
  • 1,121 Answers
Both print heads are clogged, try to clean it manually if not succeeded replace both of them.. U can find how to clean print heads in you tube..
https://www.youtube.com/watch?v=Ztl_SiUdPLw
Posted on Sep 17, 2013
HP Color Laserjet CM6040 only prints in black and Cyan no yellow or magenta ?
Have they printed 21,000 pages yet, or 10 reams of paper?
Check in the Printer Settings under Maintenance for clues and run the Tests and Maintenance steps.
HP Color Laserjet CM6040 Google Search
Mar 14, 2017 | HP Office Equipment & Supplies
When printing, if I select any other form of paper than "Plain Paper", e.g. "Photo Glossy Paper", the print (of a photo) comes out with a distinct Magenta overhue. The true colours are...
Hello Landscapeman ,
You need to specify the paper type when the print dialog box appears. Heavy glossy paper needs to spend more time in the fuser so that the toner is fixed.
Mar 25, 2008 | Computers & Internet
My HP Designjet T790 report "Error 21.2.:13, restart, if problem persists call support" i restarted but still can't print. Can you help me? Thanks
This is a service station error. One of the more common causes I have come across is a piece of paper or foreign object jammed in the service station. It is located on the right hand side of the carriage. Unplug the plotter. Plug it in and the minute that you hear the print head move, unplug the power. Then open the window, move the head out of the way and look for a foreign object stuck in the service station.
May 15, 2015 | HP Designjet T790 44-In Postscript...
Why won't a new tri-color cartridge print red?
Tri color cartridge contains Cyan,Magenta & Yellow color inks, mono cartridge contain black ink, combination/mixing with these inks desired color out put will prints on paper.. If any one or more inks are missing/dried, result mis matched print outs on paper.
In your case I feel it's Magenta ink is not firing..,nozzles may clogged, try to clean the nozzles with solvents & try it...If no result ,. replace the color cartridge..
Mar 28, 2015 | HP PSC 1315 All-In-One InkJet Printer
Trying to copy and nothing printing. Ink levels are good, paper is coming out
Perform "clean print heads" in printer properties select printing preferences,service then click clean nozzles, perform twice or thrice then do the nozzle test, if print heads are recovered your will be in safe, other wise***Two print heads are in this printer each print head leads two colors, left print head leads black & yellow and other one leads cyan & magenta. You need to replace the print heads based on the color which missed.
Jan 03, 2012 | HP Officejet 6500 Wireless All-in-One...
My HP 6500 only prints yellow and black. I refilled all three color cartridges and only the yellow is working. Any ideas?
This printer having four cartridges and two print heads.Each print head having two pens, black, yellow & magenta,cyan. As you said yellow & black are OK.. So replace Magenta & Cyan print head..
Oct 28, 2011 | HP Officejet 6500 Wireless All-in-One...
Im using hp deskjet 2660 cartridge says INTRODUCTORY HP TRICOLOR PRINT CARTRIDGE (colors) cyan magenta yellow 60 it's not producing yellow images that i printed are in pink or purple i...
This model printer has only two slots for ink cartridges. One is for a black ink cartrigde and the other is for a tri-color cartridge which contains cyan, magenta and yellow inks.
This tri-color cartridge has run out of yellow ink, you need to replace this tri-color cartridge.
Aug 12, 2011 | Office Equipment & Supplies
Cyan and Magenta does not print on the right side of the paper. Toner indicator shows three quarter of the cartridge to be full. Yellow and black prints are perfect.
I have worked/ serviced similar Laserjet Color Printer with same issue.
Actually, prints with faded colors or different colors are due the the dust/ toner dust accumulated on the optics (mirrors and lenses) inside the printer, which refect the laser beams to form prints. For instance, red color is formed by a mix of yellow and magenta toners. The color is replaced by yellow due the the partial or complete blocking of the image laser beam for
magenta as the mirrors which reflect laser beam get covered with dust and toner (which partially blocks the laser beams). Hence the image is not produced properly. This needs professional hands for servicing and cleaning of the optics inside the printer. Note that first magenta goes off, followed by yellow, then cyan and lastly black. This is due to the mirrors placement inside the printer. Magenta is the last one facing upwards at 45 degrees angle and gets most of the dust and goes off first.
Rest assure that the printer requires ONLY CLEANING OF THE MIRRORS, which are inside the printer. So, it is advised that you get the printer serviced by any printer repair/ service professional. (Please note that the mirrors, lenses and scanner assembly inside such printers is extremely complex and can get damaged very easily especially the mirrors).
Hope it would help. If you need any clarification, let me know
Good Luck!
CreativeTECH
Mar 31, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
We use HP Color Laserjet CM1017; Magenta color is not printing
Dirty laser unit - needs (careful) cleaning internally.
See ' Printing Weak Magenta', 'Printing Light Magenta' for HP CM1015, HP Color Laserjet 1600, 2600, 2605.
All the same laser unit
Apr 14, 2010 | HP LaserJet CM1017 MFP All-In-One Color...
HP Photosmart 3210xi - some colors (magentas) will not print
Remove the magenta cartridge, and try cleaning the head with alcohol, maybe with a small paint brush or an acid brush. It sounds like ink has dried and plugged up that head.
Jun 04, 2017 | HP Photosmart 3210 All-In-One InkJet...
HEWLETT-PACKARD T790 InkJet Plotter Printer Logo
97 people viewed this question
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Victorman
Victorman
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
