Unox EE1 error code EE1 - Office Equipment & Supplies
2 Suggested Answers
Daniel S
  • 4323 Answers
SOURCE: CADCO UNOX CONVECTION BAKE XAF130 I
Hi
This indicates a loose/broken wire on the oven temp sensor or the sensor is bad and should be replaced. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then that then check the control board and replace the part that is bad. Hope this helps...please post back for further assistance.
Daniel
Posted on Jun 21, 2011
Unox oven
i have an unox commerical oven the lights everything works but when i press start the oven the rcd trips and all electricty goes off ???
Jul 03, 2014 | Ovens
Cadco oven wont start ...give error code pre and por
It looks like the controller board is shot. Get on the web with Cadco and request a complete parts list for the controller circuits. Meanwhile, pull the cover off the stove controls and blow in clean, dry compressed air over the circuit boards. Chances are you have a short or two in the circuitry!
Dec 15, 2012 | Cadco Ovens
I have a sharp microwave sometimes it works for 10 or 20 seconds and then stops with error ee2, other times it works fine. Today it did the same but stopped with error ee1!
This sounds like a keypad problem, sometimes a short developes in the keypad controller causing all kinds of intermittent problems, on the back is the microprocessor circuit board which controls vital areas of the microwave oven. The cost to repair will be high and consideration should given to looking at a replacement.
Feb 17, 2011 | Microwave Ovens
I would like to know the type and max ram amount that can be installed on my laptop part # av3270-ee1 it says it has 512 now so I would like to go to 1 gig. I also have some keys in operative, shift...
Welcome to Fixya. Memory Upgrade for Averatec AV3270-EE1 Laptop, the Averatec AV3270-EE1 Laptop takes the PC2700 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your Averatec AV3270-EE1 Laptop to up to a maximum of 1.0 GB Memory, the system has 1 socket to install Memory, already with 512 MB (removable) standard Memory installed.
Thanks for using Fixya.
Feb 07, 2011 | Averatec 3200 Notebook
Samsung DMR77LHS Tall Tub Dishwasher displays HE code (flashing) and does not finish the cycle. I am very handy and would like to repair this myself. so as much detail as possible is appreciated.
EE1/HE/HE1
  • The EE and HE codes refer to temperature errors. The EE1 designation refers to a thermistor issue, and the HE codes refer to heater problems. These are all functional errors that require a certified service technician, but disconnecting the circuit breaker in the meantime can prevent the problem from growing worse.
  • 4E/4E1
  • The 4E codes indicate a problem with the water supply. If you see the 4E code, make sure the water supply line is correctly attached and open and not frozen or clogged. If you get a 4E1 code, check the temperature of the incoming water supply and ensure that it is below 176 degrees. If either of these issues persist despite your best efforts, contact a repair center.
  • 5E
  • The 5E code means there is a problem with the drain. Make sure the drain hose and openings are not clogged or obstructed. If they are not, and the code remains, disconnect the circuit breaker to reduce the risk of electric shock and contact a service center.
  • oE/9E
  • The oE and 9E codes refer to issues with the water level. The oE code means that the dishwasher is filling too much, and the 9E code means it is not filling enough. Disconnect the circuit breaker for safety and contact a repair center.
  • LE
  • The LE code indicates a leak. To keep from voiding your warranty, do not attempt to diagnose and repair the leak yourself. Close the water supply valve and disconnect the circuit breaker to avoid electric shock and contact a repair technician.
  • 6E2/PE
  • The 6E2 and PE codes both indicate functional errors that must be repaired by a professional. The 6E2 code indicates a pressed key error, and the PE code refers to a problem with the half-load function. Disconnect the circuit breaker in either case and contact a repair service.
  • Jan 14, 2011 | Samsung DMR77LHS Tall Tub Dishwasher
    My dishwasher model number dmr77lhb is showing error code le and there are no apparent external water leaks how can I rest
    I fixed mine by pulling out the unit then flipping over to access the white tray that covers the bottom of the unit. Remove this then dry it out...there's a sensor in there that triggers the LE code. It could be a leak but in most cases it's just built up condensation. EE1/HE/HE1
  • 4E/4E1
  • 5E
  • oE/9E
  • LE
  • 6E2/PE
  • Jan 10, 2011 | Samsung DMR77LHS Tall Tub Dishwasher
    After a few seconds I get error 1 The microwave is a sharp 1500 w/r-2398
    If you mean error "EE1" that means that magnetron 1 is not cooking, and it may be any of a number of components in the #1 cooking circuit.
    We don't have any service manuals for Australian models at our site, but some US models' manuals may help in troubleshooting:
    http://www.microwavedisplay.com/r23gtf_sm.pdf
    http://www.microwavedisplay.com/r21at_sm.pdf
    You can visit Sharp's Australian support site and click on the "Spareparts Outlets" link under "Frequented Resources".
    May 15, 2010 | Sharp R-1500 Microwave Oven
    Error code ee1 on sharp r-22at
    EE1 on a Sharp commercial microwave is magnetron 1-related failure.
    It may be a bad connection or relay on the control board, a bad magnetron, a bad high voltage diode, etc. - anything in the high voltage circuit for the #1 magnetron.
    We have the service / repair manual for a similar model and have uploaded it to our site here to help you.
    It will give you safety info, step by step help in disassembly and troubleshooting tips, but do not rely on the part numbers shown in that manual.
    You can find part numbers and order parts from Encompass here or you can call them toll-free at 866-779-5835.
    Most computers will open the manual automatically, but you may need the free Adobe Reader
    Jun 07, 2009 | KitchenAid KHMS2050SSS Microwave Oven
    42 people viewed this question
    jasbo
    jasbo
