No subwoofer output?!
Not getting any output through the subwoofer connection (single female RCA connector) on the rear of the amp! In anticipation, thanks for your help!
  • Andrew Dunning Jul 30, 2013
    Sorry... My first post & I can't believe I didn't offer info re: Amp / Subwoofer model no's etc!
    Linkman Home Theatre AV Amp LM-5040 Amp & Panasonic Active (Powered) Sub - I'm sure the issue is in the setup of the amplifier, but I don't know how to get into 'setup'. I suspect that it is currently setup with 'no sub present' & as such is simply not sending a signal to the sub-woofer! I don't know how to get into the setup area of the Amp (& I do not have an owners manual).
    Genius:
  • Audio Player... Master
  • 1,054 Answers
What brand/model?
Posted on Jul 29, 2013
    Linkman Home Theatre AV Amp LM-5040 ...Sorry for my obvious lack of sufficient information! Note: Even if you can point me to an Owners Manual (online) for this device, I would be very grateful. I suspect the issue is in the Amplifier's setup (i.e. currently set to no sub-woofer - I suspect)!
5 Suggested Answers
fcollingwood
  • 58 Answers
SOURCE: subwoofer
Most AV receivers do not have a built in amplifier block to drive a subwoofer, and merely provide the subwoofer output channel at line voltage. Thus, a powered subwoofer is required. Does the subwoofer require mains power? From your description, I'm guessing it doesn't. If not, it does not have a buit in amplifier, you will need to purchase a monoblock amplifier, which is just a mono amplifier with a volume control, no tone controls or anything else. Make sure that the amplifier power rating is as close as possible to the subwoofer power rating, as it is quite possible to blow a speaker by using an amplifier whose power output is too low, by overdriving the amplifier , and putting DC through the voice coil when the amplifier clips. If it does require mains power, it will have an amplifier built in, but does not have line level inputs.
Posted on Sep 14, 2007
SirHanz
  • 145 Answers
SOURCE: subwoofer connection
if this is ao powered sub, that plugs into the wall, there should be no problems, if it is powered solely by the reciever it may work fine but be sure you dont exceed amperage on the subwoofer.
Posted on Jan 29, 2008
  • 4 Answers
SOURCE: Bose Acoustimass 15 woofer, Replacement of RCA female connector
On the end opposite of the jacks (top of the sub opposite connectors) in the exact middle, there is a ratchet looking device (flashlight and magnifying glass reveal the little culprit) with a very small flat screw driver rotate the piece CCW until a small tab is protruding from the middle. Pu the palm of your hand on the plastic case and give it a small whack (in the direction of the jacks) it will move about a 1.2 inch. Lift straight up and the case will come off and reveal the connectors. Trust me, get a flashlight and magnifying glass and peer through the small crack between the cover and the box, you will see the little notch (encoder looking) rotating wheel
Posted on Dec 15, 2008
  • 121 Answers
SOURCE: dayton sub-100 connection
You have it upon one of several truly odd "standards" in the AV industry but the answer is simple if not quite logical. You will use an RCA type cable from the Sub out or LFE on the receiver to just one of the two inputs on the subwoofer. I usually use the one on the right but it really doesn't matter. The other connectors would be for a system with out a sub out where the speaker wire would be run first to the subwoofer and then out to the speakers. This will not be used at all in your case.
Enjy!
Posted on Feb 27, 2009
How do i connect subwoofer (canton movie 125 mx) to amplifier(onkyo txnr609)? there is one subwoofer output on the amplifier with either L & R(mono) high level input or L & R(mono) low level input...
Connect front the sub out (single) on the amp to one of the rca inputs on the sub, This will work reasonably well but to make the most from the sub buy a 2 rca to 1 rca cable and use it to connect both rca inputs on the sub to the single output on the amp
Mar 10, 2012 | Canton Movie 125 MX Speaker
HOW TO HOOK UP SDAT 8
You need a long enough subwoofer cable ( Male connectors on each end ) and connect it to the female RCA input on the sub and the rear of your receiver has an output labeled subwoofer out connect the other end of the cable there and you are good to go. Make sure both the receiver and the subwoofer are powered off when making the connections.
Feb 15, 2012 | Yamaha Audio Players & Recorders
Want to connect pc speakers and subwoofer to lg37lc55 tv unfortunaly it doesnt have an earphone 3.5 connection point. My other smaller tv does, the speakers and subwoofer consist of a white and red audio...
Your TV should have an AUDIO OUTPUT other than optic..at least " Headphones" output..
You can connect TV audio output with a RCA cable.
white and red audio jack....
since SUB has both RCA and "3,5mm Headphone female Jack"..here are the options;
** you need to buy a cable one end 3,5mm MALE headphone jack and the other end 2xRCA stereo (or 1x RCA for mono or you may need "Y cable " ) to be connected to your TV...
** or 2x RCA
white and red audio jack and connect from your TV..
**" "Headphones" output to SUB with 3,5 male-to-male cable ( the least recommended)
And you need to connect front,centre and rear speakers to your SUB as well...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
May 19, 2011 | LG 42LH40 LCD TV
Im not sure which plugs I should plug my RCA cables that come from my amp to the reciever. I dont know if its the "back RCA output" or the "Front RCA output" or the "subwoofer...
First of all get yourself a Y-LINK cable. (single male RCA on one side/ double female RCA on the other side) Connect the Y-LINK to your head unit sub woofer output with the stereo RCA that leads to the sub woofer amplifier. Now you are connected to the correct output. I do not know what head unit you had connected before to base your comparison, however there is a output voltage difference from one head unit to another, (1.2V, 2V, 2.5V, 4V, 5V) and that is what determines where the gain on the amplifier should be set to. Always match the headunit output voltage with the amplifier gain control to be the same. It is not uncommon for some entry level units to have a single sub woofer output. dreamsystems
Feb 21, 2011 | Pyle PLTS77DU Car DVD Player
Hi i have just bought a alpine dvd headunit the 105r and it only has 1 phono sub output and not the left and right phono output how do i connect my amp to this
it has 3 pairs of rca outputs, one pair for the front, one for the rear, and another for the subwoofer. the other sub preamp output is not needed to run to your amplifier.
For better sound quality, buy an RCA Y splitter cable (single male connection to double female connections), and run your regular pair of rca cables to the amp.
Nov 03, 2010 | Alpine Car Audio & Video
How do i hook up sub from main unit.from main unit only has one plug that says sub in.and my sub has two plugs that say L mono and R in. like R.C.A connects.please help
Get a cable that splits a single rca cable into two. It has a female end and two male ends. That way you can feed both inputs from the single sub output on the receiver.
Jan 10, 2010 | Yamaha YST-SW005 Subwoofer
Connect stereo amplifier to powered sub
You can y out from the main out to the sub.This output is post volume control. set level on sub to desired balance of lows feq to highs
Nov 20, 2009 | Yamaha YST-SW015 Subwoofer
I need the audio cable that hooks the dvd/vcr player to the subwoofer
your player output is RCA connection and your subwoofer since you didn't mention it i think its a mini jack connector or BB plug connector...so you have to costumize for that cable... or u will buy a RCA cable in the market then buy a coonector that will convert your BB plug in your subwoofer to RCA... i
what i mean is this... from your player put a RCA coonecotr it is 2 wires in your subwoofer its output is BB plug so you have to buy a connector that will make your BB plug become a RCA male...in your RCA cable from your player its output is RCA male so again convert it to RCA female connector to so that you can connect it
Oct 15, 2009 | Sanyo Audio Players & Recorders
My philips dvd player 5.1 have female ports at back side for audio but i have the sound system of LG which has simple naked wire to connect .
Philips DVP 3256 has 6 outputs which takes in RCA connectors
Altec lansing VS3251 has 3 STEREO outputs.
Buy 3 nos of STEREO (female) to RCA (male) cables
1. Connect the Altec's green wire to first stereo-to-RCA cable. RCA ends to DVP 3256's Front left and Front right
2. Connect the Altec's black wire to second stereo-to-RCA cable. RCA ends to DVP 3256's Rear left and Rear right
3. Connect the Altec's orange wire to third stereo-to-RCA cable. RCA ends to DVP 3256's Centre/Sub woofer. Interchange RCA ends if the Subwoofer sounds dull.
Good Luck
Jan 29, 2009 | Altec Lansing VS3251 Speaker
Subwoofer
Sep 14, 2007 | Polk Audio CSi40 Center Speaker
54 people viewed this question
 Grubhead
Grubhead
