Question about Contax Telephoto 85mm f/1.4 Carl Zeiss Planar T* (MM Type) Manual Focus Lens
Nikon d300s Does not work autofocus,why?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Contax Master
  • 102,366 Answers
As the name states, this is a manual focus lens. As such, it does not have autofocus capabilities.
Posted on Jul 29, 2013
My nikon d300s will not come on
Hard to tell with this one, Would have to be takin apart to determined whats wrong
Nov 09, 2013 | Nikon D300s Digital Camera with 18-105mm...
Tip
My new 2month old..d300s..my if Switch Off it shows On..LCD goes Blank..no live...
DSLR Camera or All kinds of Expensive camera needed a good care.Otherwise it will effect by Fungus or Moisture cause the damage to your Camera.I Have a Tip to give you to Protect your Camera in inexpensive way.
Tip:Take a Cardboard Box ,cover your camera and lens with dry cotton cloth and put it inside the Box.Make a Coin size hole in any side of the box and connect a zero watts Bulb or Frigde lamp fix to the hole.(You should need only a Zero watts Bulb or Fridge Lamp)You can switch on the Lamp now.Another way is to buy silica and put it in your bag even if you travelling.Silica will obserb moisture and kep your camera dry.
on Oct 02, 2010 | Nikon D300s Body only Digital Camera
My sigma 24-70mm f2.8 doesnot work on my d7000
Could you be a little more specific about "does not work"? Does the lens not fit? Can you not view through the lens when it's attached? Does it not autofocus? Does it not meter the exposure properly?
Feb 15, 2013 | Sigma 24-70mm f/2.8 EX DG IF HSM Lens for...
What digital nikon cam works autofocus in a nikkor micro AF 105mm f/2.8D?
This lens lacks the autofocus motor, so it will only autofocus on cameras with the motor. This lens will autofocus on every Nikon digital SLR except for the D40, D40x, D60, D3000, D3100, D5000, and D5100. It will autofocus with the D1 family, D2 family, D3 family, D50, D70, D70s, D80, D90, D100, D200, D300, D300s, and D700 (I hope I haven't left any out).
Jul 03, 2011 | Nikon Cameras
DOES IT WORK WITH NIKON D300S
Yes, though it's an older flash unit and cannot be used in the iTTL mode. The "Other Flash Units" section of the D300s manual (page 350 in my copy) lists the modes in which the flash may be used. Another concern is that the flash may not work well with certain lenses. The "Usable lenses and cameras" section of the SB-29 manual (page 5) discusses this.
If you need manual, you can download the D300s manual from
http://support.nikontech.com/app/answers/detail/a_id/16525/kw/D300S/r_id/116678
and the SB-29 manual from
http://butkus.org/chinon/nikon/nikon_sb_flashes/nikon_sb_flashes.htm
Jun 25, 2011 | Nikon Macro Speedlight SB-29 TTL Ring...
I want to go digital will my lens fit on a digital camera if yes what model camera should i get
Any of your lenses will fit on any Nikon digital SLR camera. However, there are several things to consider.
Most Nikon digital SLRs have a sensor smaller than a frame of 35mm film. This means that your lenses will give the same angle of view as a lens with a focal length 1.5 times longer. For example, your 50mm lens will give the same angle of view as a 75mm lens would. This applies to all Nikon dSLRs except the D700 and D3 series.
If the lens does not have the electronics to communicate with the camera, some dSLRs will not be able to meter with them. Of the current models, the D7000, D300s, D700, and D3 series will work.
Most old autofocus lenses will not autofocus on some dSLRs. Unless the lens is designated "AF-S" they will not autofocus on the D3000, D3100, and the older D40, D40x, and D60.
Feb 09, 2011 | Nikon N55 35mm SLR Camera
How is Nikon D300S
It's a very good camera, i'm plannig of buying one myself. The filming capability is now with autofocus, unlike the D90 wich does not have this capability. Also the sensor is upgraded from D300.
Apr 03, 2010 | Nikon D3 Digital Camera
Price for nikon d300
D300 can be found scarcely new. It has been replaced with a newer model D300S. The D300S incorporates video and both SD and CF capability for extended uses of writing the photos. One card can be used as backup, or one can be used to write RAW files and the other JPEGs. Some slight changes were added to the menu {active D-lighting}, and the D300S also was give a slight boost to 7FPS. Used D300 on the market go for $900 - $1300 depending on its history.
Apr 02, 2010 | Nikon D3000 Digital Camera
Auto focus tracking
All autofocus points, and Focus mode set to Servo.
Check out digitalphotographyschool.com's forums, they are excellent sources for this type of info. And you can join a community of other DSLR users like yourself.
Nov 28, 2009 | Cameras
I just bought a D300s digital camera in Seoul yesterday and I'm unable to use it because the manual is in Korean. I'm Canadian and speak English. After spending over 2000usd, I am very disappointed in your...
1706b32.jpgNeed a spare battery for your Nikon D300s digital camera? Capture beautiful memories perfectly with a high capacity battery for your Nikon D300s digital camera. Rechargeable Li-ion 7.4V(Compatible with 7.2V) 1500mAh Nikon D300s battery for sale,20% off! 1 year warranty!
http://www.nikon-coolpix-replacement-battery.com/d300s.htm
Oct 02, 2009 | Nikon Cameras
Contax Telephoto 85mm f/1.4 Carl Zeiss Planar T* (MM Type) Manual Focus Lens Logo
65 people viewed this question
Top Contax Cameras Experts
Steve
Are you a Contax Camera Expert? Answer questions, earn points and help others
