I'm trying to make copy the paper come out blank on d.copia283mf
    New Friend:
  • 9 Answers
Turn the original image over. Scan it inverted.
Posted on Jul 29, 2013
3 Suggested Answers
canontech
  • 1219 Answers
SOURCE: full page is not copied
Hi, did you place paper in tray also horizontal? the paper in tray and on glass must be horizontal if you want to copy A4R size.
DO NOT forget to adjust the blue paper size indicator on paper tray to A4R also.
Also under user mode, under copy sett. you can find option for auto rotate, so copier will adjust size automaticaly.
Posted on Jul 17, 2010
  • 684 Answers
SOURCE: I replaced the black cartridge
1. Get a damp paper towel.
2. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
3. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
4. Next dab the cartridge on the towel to make sure that the ink is flowing.
5. Snap the cartridges back into the printer.
Good Luck!!!!!
Posted on Sep 18, 2011
My Dell 3115cn MFP prints 3 blank pages between prints or copies if I print more than 1 copy how do I fix this? What is causing it?
I will do first a full printer cleaning, that mean take off all dust and anything can that can be inside the printer (ex.bugs and dirt accumulation).
Second try to locate the printer rollers and check if they are in good condition.Printer rollers need to be in good condition because those are the parts that move the paper inside the printer.
Also when you feed the papers into the feeder make sure you air the paper so they don,t stick together.
May 07, 2013 | Dell Printers:Dell MFP Color Laser 3115cn
Trying to copy and nothing printing. Ink levels are good, paper is coming out
Perform "clean print heads" in printer properties select printing preferences,service then click clean nozzles, perform twice or thrice then do the nozzle test, if print heads are recovered your will be in safe, other wise***Two print heads are in this printer each print head leads two colors, left print head leads black & yellow and other one leads cyan & magenta. You need to replace the print heads based on the color which missed.
Jan 03, 2012 | HP Officejet 6500 Wireless All-in-One...
Mfc 9880. printing clear 100%. problem with copying only. feint and blur copies, cant see 98% of doccument. i tried cleaning the scanner unit. i think i probably messed up sumthing..
Probably did! I found out the hard way on a HP All in One that all the remedies out there wouldn't make it print until I bought a new print head. This one would go through the motions of printing but I got blank paper in and blank paper out. You probably didn't mess it up it can do that itself. I would just get on the web and spring for a new head and be done with it. dhgill
Aug 24, 2011 | Office Equipment & Supplies
My printer will not print anything on the paper when I press print or copy. However, it is going through the motions as though it is but the paper remains blank. I have replaced the ink cartidges &...
You are doing well, keep trying the ink as it is a new cartridge has to still come through.
Do a few more deep cleans and then print some test pages. You may need to do this a few times.
Thanks michellelwol
Take care!
damnor01
Apr 16, 2011 | Canon PIXMA MP780 All-In-One InkJet...
Full page is not copied
Jul 17, 2010 | Canon iR 2016i Black and White Copier
This morning I thought I would print out some Shamrocks (for T.S. windows) on green paper. I put the green 8 1/2 x 11 in the bottom tray and asked the printer to print 5 copies. It would print 1 copy and a...
Was the green paper the type kids use in school. When my kids were little we called it contruction paper. If this is the case, your printer is smart enough to know that this paper is thicker than normal. It's responding as it should. Next time you want to print on this type of paper - select this in your printer's software control panel.
Feb 26, 2010 | Office Equipment & Supplies
Tried to copy a book and the copier started pages were blank
maybe it would help if you try not to use the automatic paper select button or use the manual paper select try. set it to 11 x 8.5
Jan 31, 2010 | Canon Office Equipment & Supplies
Paper feed jamming
check the back of printer and see if there is door u can open. Most likely there is a paper jam u cant see.
May 24, 2009 | Canon PIXMA MX310 All-In-One Printer
32 people viewed this question
jasbo
jasbo
