Question about Hardware & Accessories
ELETTRO GT KD-2064 alarm clock
How do I set the time and day?
Noggin
  • 944 Answers
SOURCE: Setting Clock for JVC-KD-G420
Here is the link for the manual http://books.jvcservice.com/download/289413083/38360.pdf page 7 Hope this helps :)
Posted on Mar 17, 2007
IB4G2008
  • 3587 Answers
SOURCE: Setting Time
ok..here it is, right from Fixya's manual pages..
click here
Posted on Feb 24, 2008
SOURCE: setting time and alarm clock for timex nature sounds clock
Hold the time set key in until the time flashes. Now let it go and use the tuning forward and back keys to set the time. I had the same problem because I continued to hold the timeSet button down while trying to adjust it. If you do, the forward/back keys have no effect.
Posted on Jan 08, 2009
SOURCE: Setting the clock on JVC KD-G230
Check out this pdf http://resources.jvc.com/Resources/00/00/91/GET0408-001A.pdf
Posted on Jun 10, 2009
SOURCE: Need to set an Ultronic clock
Press the time (current time - numbers) to get to the date mode. Then hold-press "SET" to set it.
Posted on Aug 22, 2010
How do I set the time on a KADIO KD-3806 digital clock
Earlier FIXYA question:
sachin_arane
ALL PARAMETERS CAN BE ADJUSTED BY USING KEYS
GIVEN BACKSIDE...KEYS ARE
MODE (LONG PRESS-4 SEC) TO ENTER INTO SETTINGS;
UP/DOWN TO CHANGE THE PARAMETERS; \
*C/*F KEY TO TOGGLE BETWEEN TO TEMPERATURE FORMAT;
SNOOZE BUTTON TO SET SNOOZE IN ALARM-MULTIPLE SNOOZE CAN BE SET;
RESET KEY CAN BE USED TO RESET CLOCK TO DEFAULT;
DAY COUNTDOWN , AND TIME COUNTDOWN CAN BE ADJUSTED;
DETAILED INFORMATION TO SET THE CLOCK
INSERT CELLS;-SCREEN SHOWS DEFAULT VALUES-INITIAL MUSIC WILL RING;
LONG PRESS MODE BUTTON-KEEP IT PRESSED UNTIL 12 STARTS BLINKING;
USE UP /DOWN BUTTON TO ADJUST HOURS...
THEN SIMPLY PRESS MODE AGAIN, NOW MINUTES 00 IS DEFAULT WILL START BLINKING;
USE UP/DOWN BUTTON TO ADJUST MINUTES;
AGAIN PRESS MODE, SCREEN WILL SHOW YEAR 2002 DEFAULT BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW MONTH BLINKING, USE UP/DOWN KEY TO ADJUST CURRENT MONTH;
AGAIN PRESS MODE, SCREEN WILL SHOW DATE BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW 12:00 BLINKING WITH ALARM SIGN (FOR ALARM SET);USE UP/DOWN KEYS TO SET ALARM, FIRST HOURS AND THEN MINUTES FOR ALARM; THEN ON PRESSING YOU CAN SELECT SNOOZE MINUTES;
AFTER SNOOZE ON PRESSING MODE AGAIN YOU CAN SELECT DAY COUNTDOWN TO SELECT 999 DAYS COUNTDOWN FROM CURRENT DATE;
when watch displays time and everything .....
each and every buttons has some function;(shortcuts)
press down to toggle between 12hr/24hr format;
press up to enter contdown timer;
press snooze to set snooze in alarm;
press c/f to toggle between two temperature formats;
press mode to toggle between alarm time and current time
Mar 18, 2018 | Car Audio & Video
My Mother-in-Law recently purchased a ZTE Majesty Pro [Z799VL] telephone from a Dollar General store. It has an alarm that goes off every 15 minutes. How do I disconnect from this service?
Read the manual. Turn the alarm off and the repeat function. It probably has an alarm set and the 15 minutes reminder is to say it hasn't been cancelled.
Page 89
Clock
Press the
Home Key
Clock
. The Clock app allows you to check local time in places
around the world, set alarms, and use timers.
Setting a New Alarm
1.
Open the Clock app and tap
2.
Tap a default alarm to configure it, or tap
at the bottom of the screen to create a
new alarm.
3.
Set up the alarm options, such as time, alarm days, snooze, and alarm ringtone.
4. Tap
SAVE
to save and exit.
NOTES:
To enable or disable existing alarms directly, tap
On
or
Off
on the right side
of each alarm.
• Tap
to configure alarm settings, including ringtone volume, vibration, alarm
duration, volume crescendo, and alarm in silent mode.
Manual is here
http://zte-iqorsupport.custhelp.com/ci/fattach/get/3730/0/session/L2F2LzEvdGltZS8xNTExMjI1NjY2L3NpZC9mVUl0Ykhoc3lwNW9rVWZ3WU0ycGlPbllqOEdkS1lzTFB3ZkJheHNGdXdFUEtweVpzZWUzZ05BaWhiTmFMJTdFdVBoU09TUVJzcExxYUpXUFBndldkUmVCNl8xNldsTE1RRWlHQ1J1dDhBYkNHa2xFRHNheHVSJTdFZE9nJTIxJTIx/filename/ZTE_Majesty_Pro_LTE_GSM_Z798BL_UM_EN_Approved.pdf
Specs and link to manual at the bottom of the page.
How do get the User Guide for the ZTE Majesty Pro LTE Z798BL GSM
Nov 21, 2017 | ZTE Cell Phones
How to adjust date and time free of charge
You did not specify the phone you using.
To set date and time on your nokia phone
Select Menu > Settings and Phone > Date and
time.
Select from the following:
Time - Enter the current time.
Time zone - Select your location.
Date - Enter the date.
Date format - Select the date format.
Date separator - Select the symbol that separates days, months, and years.
Time format - Select the time format.
Time separator - Select the symbol that separates hours and minutes.
Clock type - Select the clock type.
Clock alarm tone - Select the tone for the alarm clock.
Alarm snooze time - Adjust the snooze time.
Workdays - Select your working days. You can then set an alarm only for working day mornings, for example.
Automatic time update - To update the time,date, and time zone, select On. This network service may not be available on all networks.
Regards
Jun 30, 2011 | Lands Phones
Set time on jvc kd g420
CLICK HERE for the owner's manual.
Setting the time is covered on page 12.
Press SEL button
Scroll through the PSM menu items with |<< and >>| until you come to CLOCK H
Adjust by turning the VOL knob
press |<< or >>| again until you get CLOCK M
Set again with the VOL knob - then press SEL again to exit.
Thanks for using FixYa!! A 4 THUMBS rating is appreciated for answering your FREE question.
Jun 02, 2010 | JVC AM FM CD DET FACE CAR STEREO
I can't find the alarm clock setting anywhere on my nokia surge phone! is this normal? I've searched everywhere for it, and it just doesn't make sense for there to not be such basic thing... I must have...
hiSelect > Tools > Clock To set a new alarm, open the Alarms tab, and select Options > New alarm. Enter the alarm time, select whether and when the alarm is repeated, and select Done. hope this will work. regards aniruddh
May 28, 2010 | Nokia 6790 Surge Cell Phone
How do you set the clock on a jvc kd-g230 car radio
There is a misprint on manual concerning setting the clock. This is the case for similar JVC mobile head units.
The proper way to set the clock for this unit is:
1.)Hold down 'SEL' button count to 3 seconds
2.)Immediately after release of 'SEL' button hit the '>>|' button
This will allow you to enter 'PSM' menu. Every time you press '>>|' it will cycle between, 'CLOCK HOUR','CLOCK MINUTE', and 'Demo' Mode.
3.)Adjust settings by using the 'turn knob' and make sure 'Demo' mode is set to 'Demo Off' for the clock to stay set.
Nov 17, 2009 | JVC KD-G230 CD Player
How do I set the clock on Accurian IPod docking alarm clock
When in standby mode (press and hold power button to enter standby), press MODE. Now press |<< TUNE/SKIP >>| to set 12-hour or 24-hour display mode. Press MODE to confirm display setting. The display flashes. Press |<< TUNE/SKIP >>| again to set the hour, then press MODE. Press |<< TUNE/SKIP >>| to set minutes, then press MODE to confirm the time.
Nov 12, 2009 | Digital Products International ILIVE...
Date keeps changing a week forward after setting time
A possible solution to this issue could be changing the automatic update of time and date. If it's currently switched on on your phone, try switching it off. And if it's already off try switching it off.
Here's where to find the setting: Menu >> Applications >> Clock >> Options >> Settings >> Automatic time update
For more info, check the (English) N79 manual on page 147
Feb 26, 2009 | Nokia N79 Cellular Phone
Car radio - setting the clock
1. click on S (select) and choose clock and hold it (?) 2. click on bar v|<< >>|> to select H or M or Seconds 3. adjust it turning the volume button 4. repeat steps 2 and 3 for minutes 5. repeat steps 2 and 3 for seconds
Dec 12, 2008 | JVC KD-G510 CD Player
Hardware & Accessories Logo
109 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
