Baumuller drive faults
F087 f089 error
What does engine power reduced mean and how can it be fixed
Hi Cathy, I would like to assist you with your car problem; may I have more info please? Include year, make, and model of the car you are having problems with. Specify the driving circumstances when the dash light went on (e.g. check engine, MIL, etc)
Did you lose speed? Is your speed limited to 20 m.p.h.?
Were you able to pull any diagnostic trouble codes using an OBD-II scanner tool?
Depending on the circumstances and the pulled DTCs, it could be as simple as: a problem with the battery dying; or a poor connection due to corrosion or moisture damage; loose battery connections , or some other power system failure with a wiring harness, headlights, or wipers.
More serious problems may be the cause too; such as
  • Defective throttle position (TP) sensor
  • Defective oxygen sensor
  • Defective accelerator pedal position (APP) sensor
  • Loose or damaged wiring
  • Defective throttle body
  • Defective powertrain control module (PCM)
  • Any fault/error that will affect drivability function
  • Any fault/error that will affect vehicle performance
  • A fault/error in the emissions system
  • A fault/error in the throttle control system
  • A fault/error in the transmission system
In these cases, the reduced engine power warning light is considered extremely serious because of the immediate and severe drive-ability problems that will be present until the engine or transmission fault/error is repaired. More damage could be incurred if you continue to drive the affected car without making the proper and necessary repairs...and in the long run, cost you more money.
If you don't have an OBD-II reader, does a neighbor have one you can borrow? If not, you can rent one out from your local auto parts store; I would not recommend driving the car to the auto parts store, however, if you are desperate and need to drive the car to the parts store, a counter- person will be more than happy to assist you and pull the codes free of charge. Let me know if I could be of further assistance.
Feb 12, 2017 | Chevrolet Cobalt Cars & Trucks
Tip
XBOX 360 Error Codes
There are several error codes you can get with an XBOX 360, the first step to resolving any problem is finding the root cause. The fault codes are primarily shows on the "ring" on the front of your console (this is the ring split into 4 segments that shows when controllers are connected and what player position they are).
  • 1 SEGMENT FLASHING RED - Thisindicates a displayable error code, the specific error code will bebeing displayed on the TV you have it connected too.
  • 2 SEGMENTS FLASHING RED - The console has overheated.
  • 3 SEGMENTS FLASHING RED - This is the somewhat infamous RROD (Red Ring Of Death).
  • 4 SEGMENTS FLASHING RED - AV cable not detected.
If you have 1 segment flashing red indicating a displayable specific error code then you can identify the fault from the list below.
  • E45 - Update Error.
  • E64, E65, E66 - DVD Drive Error.
  • E67, E68, E69, E79 -Hard Drive Error.
  • E71 - Update Error.
  • E72 - Unknown.
  • E73 - General Hardware Error.
  • E74 -AV cable error.
  • E76 - Unknown.
This is a basic overview of all the fault codes for the XBOX 360, for more in depth information on the faults and how to repair them please see my other tips!
Thanks!
on Mar 25, 2010 | Video Game Consoles & Games
Can anyone tell me what F06 error code means on the whirlpool 6th sense 10kg washer? and what to do about it as the screen is flashing but the door to the machine is locked. Thanks
F06 Drive motor tachometer error This error occurs when the main control unit fails to detect the motor speed from the tachometeric generator fitted to the motor either through an incorrect resistance or the tacho is not correctly fitted into place. The machine will try to detect the reading several times before aborting the program ans shutting down with this error being displayed.
When checking ensure that the drive belt and belt tension are okay as this can cause this error.
  • Check tacho resistance
  • check tacho placement
  • Check wiring for shorts
  • Check wiring harness connections between motor and main controller
  • Check drive belt for damage and tension
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3708-whirlpool-washing-machine-fault-codes.html
May 26, 2015 | Whirlpool Washing Machines
Bmw e90 fault codes
the error codes are BMW specific and yes an error code would show up as a cam position sensor fault.
May 11, 2014 | 2008 BMW 320D E90
Short dst failed fix
Drive short test failure usually indicates what it says, which is a fault with the drive, but you state that this happened after an update (don't trust windows update!)
do you have have any error codes this could indicate further the exact problem. but usually this type of error would indicate a drive fault which would require replacing the drive
Cheers D
Mar 03, 2014 | HP Pavilion g6-2210us Notebook Laptop PC
Error code E602-0001
Data read fault of the Hard Disk Drive on boot-up. Hard Drive fault.
Replace hard drive and install firmware
Hard Drives become faulty over time resulting in E602 error
Aug 16, 2013 | Canon imageRUNNER 3300 All-In-One Laser...
What does error code 91,721.00:1039 on Xerox ColorQube 8570 mean
The error is a printhead tilt fault. It's unable to tilt on the axis, caused by a fault camshaft and process motor. The part you need to fix it is 8570-Z1.
http://www.iteminconline.com/8570-z1_8570-z1-xerox-colorqube-8570-8580-8700-process-drive-camshaft-kit-includes-process-drive-motor-drum-maintenance-camshaft-transfix-camshaft.htm
Aug 13, 2012 | Xerox Office Equipment & Supplies
E68 error code
try removing the hard drive and see if the xbox plays without it.
error 68 could be internal fault or external but is a harddrive fault.
if it plays without the hard drive, you need a new hard drive.
if it still does not work with the hard drive removed, you may have an overheating problem.
this could be fixed by you by following many of the online guides or if you have a warranty maybe microsoft will fix it? the 3 red light fix will fix most red light errors. i would suggest upgrading the fans too if you plan on fixing it yourself.
May 27, 2010 | Microsoft Xbox 360 Console
"Error loading operating system" message
This error means the operating system on the hard disk couldn't load due to possible faulty hard drive or disk controller. The fault could also mean the hard drive needs reseating to make proper connection. Reseat the hard drive and if you still get this error, then you need to determine if the disk controller is faulty.
To do this, remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer see this hard drive as an external drive and you can also see the contents of the drive, then the hard drive is OK and the fault is a faulty disk controller. If the computer cannot detect the hard drive then the hard drive is faulty.
Then get a new hard drive insert it into youe laptop and install Windows to get your laptop operatioal.
Apr 09, 2009 | Sony VAIO VGN-FE660G Notebook
Dell error code ofoo:o244
first things first the error code was with zeros not o's
the error code relates to hard drive errors and faults you could try running disk diagnostics tools and even try a new hard drive
Jul 13, 2008 | Computers & Internet
Computers & Internet Logo
213 people viewed this question
David Payne
David Payne
