SIMS 3 & Packard Bell Easynote A8
I have just purchased sims 3 and have installed it on my Packard bell easynote a8, although it installed fine it now says the game cannot play due to a video game card - do you think sims 3 will ever play on this laptop or am I wasting my time. Thanks and appreciate your support
    Problem Solver:
  • 10 Answers
Try updating your graphics card driver.
Posted on Jul 30, 2013
priyabrat
  • 123 Answers
SOURCE: Monitor not coming on - Packard Bell Easynote R4650
It's a dreadful way to start a day - you press the power button on your computer and nothing happens. Do not fear because all may not be lost! Follow these simple steps to determine why your computer won't turn on.
Note: It is very important to troubleshoot any issue beginning with the most likely and easily testable problem so be sure to follow these steps in order.
Difficulty: Average
Time Required: Anywhere from 10 minutes to a few hours or more depending on why the computer won't turn on
Here's How:
As silly as it may sound, the number one reason why a computer won't turn on is because it wasn't turned on! Before starting a sometimes time consuming troubleshooting process, make sure you've turned on every power switch and power button associated with your computer:
Power button/switch on the front of the computer's case.
Power button/switch on the front and/or back of the monitor.
Power switch on the power supply on the back of the computer.
Power switch on the power strip or surge protector (if you have one).
Verify that the power supply voltage switch is correctly set. If the input voltage for the power supply does not match the correct setting for your country, your computer may not power on.
Check for loose computer and monitor power cable connections. A loose or unplugged power cable is one of the top reasons why a computer doesn't turn on.
Perform a "lamp test" to verify power is being provided. Your computer isn't going to turn on if it's not getting power so you need to make sure that the power source is working properly.
A damaged power supply could be preventing the computer from being properly powered.
Do a quick test of the power supply by holding your hand behind the power supply fan located at the rear of the case. If the power supply is working, you should feel air from within the case blowing against your hand. If not, you may need to replace the power supply.
Tip: Is the power light on the front of the computer's case on? If you've turned the power switch on but the light is off, this is another good indication that the power supply is the cause of this issue.
Over time, internal components and the cables that connect them can wiggle loose which can often times result in a computer unable to power on. Try reseating the following and then try to power on the computer again:
Reseat the internal cables
Reseat the memory modules
Reseat the video card
Reseat other expansion cards
Reseating the CPU may also be necessary but should only be attempted if the reseating of all other components is not successful. This is due to the fact that this process is a little more involved and can run a small risk of damage to the CPU. This isn't a big concern if you're careful, so don't worry!
Check for causes of electrical shorts in the computer case. This is often the cause of the problem when the computer powers on for a second or two but then powers off completely.
Most monitors have a small light next to the power button that can change between various colors. If the screen is blank, this light is your main source of information about the monitor.
If this light is not on at all, double-check the power switch and connections (Steps 1, 2 and 3) and also make sure the monitor cable is securely plugged in to the video card port on the back of the computer case. If the light is still off, replace the monitor. If it comes back on, try starting your computer again - a loose or unplugged monitor cable may have been the issue all along.
An amber or yellow power light simply means that the monitor is not receiving any information from the computer. In and of itself, this doesn't tell us much.
On the other hand, if the light is amber or yellow, the computer power light is on, and the hard drive is active (making familiar sounds and the hard drive activity light on the computer case is blinking), the computer is probably starting normally but the video card is not sending information to the monitor. Replace the video card.
Beep codes (see Step 11) usually sound when a video card has malfunctioned but this is not always the case.
Is your computer making a beeping sound? Sometimes a computer will turn on just enough to play a series of beeps from the speakers.
These beep codes play in particular sequences and represent a specific problem that your computer is having. Troubleshoot the beep code to figure out what it's saying and then service the computer as necessary.
Tips:
Still can't get your computer to turn on? Let a community of computer support enthusiasts help out! Post the details of your problem in the Focus on PC Support Forums.
Posted on Jan 26, 2008
  • 55 Answers
SOURCE: master reset
If by master reset you mean wipe out everything and make it look like you just took it out of the box.
Simply put in the "Restoration CD" that came with the computer.
(If you still have the instruction booklet then instructions are in there I believe)
Posted on Mar 14, 2008
pagebor
  • 2785 Answers
SOURCE: Packard Bell EasyNote H5 Laptop,
please check your power supply unit.
Posted on Apr 04, 2008
SOURCE: wireless button on packard bell easynote MV35-202?
Fn / F1 or some models are Fn / F2
Posted on Oct 06, 2009
  • 38 Answers
SOURCE: Require Packard Bell Easynote R1938 disassembly
Her's something you may or may not have. Hope it helps.
http://safemanuals.com/user-guide-instructions-owner-manual/PACKARD%20BELL/EASYNOTE%20R1938-_E
Posted on Nov 12, 2009
Easynote a8
Go to the below link for the factory restore settings,
http://www.makeuseof.com/tag/restore-windows-computer-factory-settings/.
You can also avail our technical support by visiting our website: http://www.vtechsquad.com.
Jun 02, 2013 | Packard Bell Computers & Internet
I need an wireless installation disc
you can get the drivers for you wifi on Packard bell support site
look up you laptop model on site and it will give you all the drivers for you laptop just download the wireless install it or put it on usb to move it to another laptop /computer
Dec 27, 2012 | Packard Bell EASYNOTE A8 COMPATIBLE LAPTOP...
Need a disassembly manual for packard bell easynote A8
First - apols for the many repeated questions - hey-ho. Secondly - found manual for A7 (essentially same machine) here: http://www.fixya.com/support/t11335548-need_disassembly_manual_packard_bell#
Jan 17, 2012 | HP Pavilion Computers & Internet
No audio driver in my laptop packard bell easynote A8
Hello. By accessing this LINK you will be able to download the Audio Driver for your Packard Bell EasyNote A8 series which is available for Windows XP
Enter the code shown and save the file to your computer. Run and install it properly.
I hope I helped!
If you have any other questions, please leave a reply.
Thank you for using FixYa!
May 31, 2011 | Computers & Internet
How much is packard bell easynote nj65 laptop?
you can pick up a replacement screen for between £70 and £80 by searching 'nj65 screen' on ebay
Feb 25, 2011 | Packard Bell EASYNOTE A8 COMPATIBLE LAPTOP...
Please i want a (multimadia audio controller) ,(pci modem), and (vidio controller (VGA compatible) drivers for packard bell easynote QUA-K1 please help me.
Is these the specification for your laptop? or similar?
PACKARD BELL EASYNOTE C3300 QUA-K1
Basic Specifications:
Processor: AMD Athlon 2.2GHz
Memory: 512MB RAM
Hard Drive: 20GB partitioned
Video Memory: 64MB
Networking: Lynksis PCMCIA WIFI, LAN, etc
Display: 15" XGA TFT Screen
Power: Working Battery & A/C Adaptor
Operating System: Windows XP Professional
Office: Microsoft Office 2003
Pre-Installed: Programs, Games, & MP3
Try this Archived FTP site from Parkardbell @ ftp://ftp.download.packardbell.com/NOTEBOOK/EasyNote%20C3%20series/Driver/Xp/
Your laptop is "Easynote C3 Series"
Hope it helps.
Aug 13, 2010 | Microsoft Windows XP Professional
HI, Packard Bell Easynote L4, switches off after 5 seconds
no..this is a motherboard issue. if the power won't stay on, even without a battery, then it's the m/b..replacement is a bit dicey, but not impossible. The hard drive with data should be fine.
Nov 28, 2009 | Office Equipment & Supplies
Pls help fit my packard bell easynote A8 audio sounds.myintel R PRO/ wireless 2200BG network is not working
type our service tag on dell drivers downloads page n u will get the drivers list..
if not contact me vveeru19@gmail.com
Oct 24, 2009 | Dell Inspiron B130 Notebook
Packard bell easynote m5262
This is hard you have to take the laptop apart to get to the ram. but you have to remove the screen to get to the case screws.
Dec 08, 2007 | Computers & Internet
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
