Question about Uniden TRU9488-R 5.8GHz Corded / Cordless Phone 1 Extra Handset / Ch
Which handsets are compatible with Uniden TRU9488
I want to add a handset to my Uniden TRU9488 phone, but cannot find out which currently available handsets are compatible. The issue is "currently available", none of those listed in the manual: : TCX805, TCX905, TCX400, TCX440, TWX977 and ELX500 seem to be available now.
5 Suggested Answers
SOURCE: ELBT595 & TCX905 compatibility
from uniden regarding your base station:
"This expandable base system is compatible with Uniden handset models ELX500, TCX400, TCX440, and TCX805. However, only the ELX500 is compatible the base system's Bluetooth and CellLink features."
Posted on Jan 05, 2009
SOURCE: Uniden handset TCX905 with base unit TRU8866-if compatible?
I just successfully registered 4 TCX905s with my TRU8865 base - it's documented in the TCX905 manual.
Be sure the handset you want to register is fully charged.
Remove the handset you want to register from its charger.
Now unplug the AC for the main base, hold down the 'find handset' key on the base and plug the AC in again, when it beeps, you can let go of that button.
Hold down the '#' on the handset you want to register, it will show 'Registering Handset...' and when it beeps, it's done - registered, you're good to go :)
Posted on Feb 13, 2009
  • 37 Answers
SOURCE: How do you register a waterproof phone (TWX977) to a TRS9585
Not sure if you still have this problem, but...
Basically go on you base unit, and hit "MENU/SELECT". Scroll down to "REGISTER HANDSET" and click "MENU/SELECT". On your waterproof handset, hold the "#" key until it displays "REGISTERING HANDSET". And voila! After that finishes, your waterproof handset will be good to go!
Posted on May 21, 2009
  • 5 Answers
SOURCE: Uniden TCX905 cCordess phone Handsets # 3 and 4
If the handsets are not currently registered to any base, the SYSTEM RESET menu won't appear.
If the TCX905 handsets in question are actually expansion handsets from another Uniden Phone System, they are not true TCX905 handsets. To verify, remove the battery cover and battery, then look at the inside label. If it lists the model of a TRU9xxx phone system, your handsets are NOT TCX905.
Uniden unfortunately has programmed the expansion handsets from SINGLE LINE TRU9xxx phone systems to NOT REGISTER against the TRU9466. (Those same handsets register fine against predecessor model TRU8866 though).
Posted on Mar 19, 2010
I have a Uniden Cellink D1780-3BT system with 3 working handsets. I want to add Uniden DECT 6.0 D1780-3 handsets.
you will not be able to do this as they are two totally different machines with totally different operations although the 1780- appears the same it is the celllink and dect that makes the difference
you can however add as many hand sets of the same model as you wish to the same model
it has to do with updated circuitry required by the telecommunications department to operate on the system
Dec 17, 2015 | Uniden Lands Phones
Light stays on in the base unit and light flashes on handset. No messages--all have been retrieved.
If your charge light is flashing and you have no messages on your answering system, you may have voicemail. Voicemail is provided by your telephone company and they would be able to assist you with retrieving those messages.
May 15, 2015 | Uniden TRU9488 Corded/Cordless Telephone -...
How do I add another handset to d1384?
Apparently,
d1384 page 7 of http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1384om.pdf
Finding the Handset
With the phone in standby, press
FIND on the base. Each handset will beep for 1
minute. To cancel, press
FIND again or press any handset key
Jul 28, 2014 | Uniden Cordless Phone
Batteries won't charge
There are a few reasons why a battery won't charge. Make sure that the contacts on the phone and the charging cradle are clean. (Unplug the base or charger.) A pencil eraser is good initial cleaner; electronic contact cleaner sprays are a second option. Remove the battery and check the contacts inside the handset and the battery as well. Next replace the battery pack. If you add a comment with your phone's model number, then I can try to find the correct battery. (Stores like Battery Mart may have a compatible battery.)
The final possible problem is that the charging system is bad. If your phone has multiple handsets, try a different charger. If the phone allows you to add handsets, try getting a new handset. The new handset will come with a new charger. (I've never seen the chargers sold without the handset but you could try Uniden customer service. If the base station is the only handset cradle, you'll probably need to replace the phone if a new battery and clean contacts don't work.
If your Uniden phone is under warranty, contact the company.
I hope this helps.
Jun 18, 2014 | Uniden DECT 6.0 Cordless Telephone...
How do i add another handset "uniden 6.0" phone to an existing phone and base unit of the same brand.I need the step-by-step instructions please. thank you!
First make to get a compatible handset.
For the Uniden D1660-2, the compatible handsets are DCX160 and DWX337. Make sure that you have not exceeded the number of handsets that the phone can support. The D1660-2 can support 12 handsets unless you use any DWX337 handsets. Then the limit is 6. (If you have more handsets, you will need to deregister some of them first.) Then allow the handset to charge. If the handset is reading "not registered", then place it into the base unit. You should see "Handset Registering" for about 30 seconds; then it will read Registration Complete. The manual for the Uniden D1660-2 is available here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1660-2om.pdf . This is the most common Registration for Uniden phones; there are a few exceptions (depending on the base or the replacement handset). Check the appropriate manual (see below to find the manuals).
For the DECT4096, press Menu on the base and then navigate to Handset Register. When you see Handset Registering on the base display, press and hold # on the handset to be registered until you see Handset Registering. (It takes about 2 seconds.) After the display changes to Handset Registered, check for dial tone.
On a few Uniden phones, there is a Page/Handst Register button on the base. On those you navigate through the Handset menu to Handset Register (Menu > Handset menu > Handset Registration). Then press and hold the Page button until you hear a beep. Then wait for the registration to be completed.
Most Uniden manuals are available here: http://www.uniden.com/scat/cordlessphones_mnl . Select your type of Uniden phone and scroll through the list to your model or use the search box to directly search for your phone and the manual.
I hope this helps.
Jul 26, 2011 | Uniden D16602 Twin Cordless Phone
Add more handsets to uniden phone
Add more handsets to what model Uniden phone?
Jan 15, 2010 | Uniden 5.8GHz Expandable Cordless Phone...
Uniden 6.0 with 2 handsets
Unplugged all telephones but one and still had trouble so I called Verizon. They discovered it was an incoming line that was malfunctioning. However, the Uniden telephone system still does not work and since it is still under warranty I will contact them.
To continue the solution of my telephone problem - It was discovered that the incoming line was indis repair. After it was repaired, I again set up my Uniden telephone system. It works with no problem. The word "searching"still appears on the face of the units, but it can be overcome with normal activity on the units.
Aug 02, 2008 | Uniden TRU9488 Phone
OU might need to deregister the hand set first by holding down the red end (hang up key) and keep it down while holding the # key. If deregister wont work use base unavailable and yes, you are sure twice.
List the handset numbers of those working handsets
Using a WORKING handset follow these directions
Resetting Handsets
If you want to register the handset to a different base or
replace a handset with another one, you must first clear the
registration information from the base and the handset.
1. Press and hold [ ] and [#] for
at least 5 seconds, until the
SYSTEM RESET menu
appears.
2. Select the DEREGISTER HS
submenu. WHICH HANDSET?
appears in the display.
3. Move the cursor to select the handset ID to be de-registered
from the list, and then press the OK soft key. DEREGISTER HS
appears. CHOSE A NUMBER THAT IS NOT ONE OF YOUR WORKING HANDSETS
4. Move the cursor to select YES, and then press the OK soft key.
When ARE YOU SURE? appears, select YES. You will hear a
confirmation tone.
PUT THE HANDSET IN THE BASE CHARGER AND IT SHOULD REGISTER
Hope This Helps - It worked for me
Jan 28, 2008 | Uniden TRU9488 Phone
Uniden hand set
What is the model # of your handset. It must be tcx 900 or tcx 905 to be compatible with the tru 9488. Good luck! :)
Jan 12, 2008 | Uniden TRU9488 Phone
Resetting the Handset
YOU might need to deregister the hand set first by holding down the red end (hang up key) and keep it down while holding the # key. If deregister wont work use base unavailable and yes, you are sure twice.
Resetting Handsets
SYSTEM RESET menu
appears.
confirmation tone.
Dec 29, 2007 | Uniden TRU9488 Phone
Uniden TRU9488-R 5.8GHz Corded / Cordless Phone 1 Extra Handset / Ch Logo
21 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
